Everything posted by omar302
Attached are the cooling system component locations for the 2.0, 3.5 & 2.7 engines from the 2015 Service Manual. Each one shows the different configuration (Basic, Tow Package and/or Hot market). Engine Cooling - Component Location 20l.pdf Engine Cooling - Component Location 27l.pdf Engine Cooling - Component Location 35L.pdf
I remember I followed mid for the dark car mode (police option) in the 2GFusion sheet. https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true -
I'm not sure the 2018 is the same, but for the 2015, fans are the same, but from the service manual it seems for the 3.5L there is an engine oil cooler added while for the 2.0L a transmission oil cooler is added with the tow packages.
Did you change the whole fans & module or only the module? If only the module, maybe the issue is from the fans?
Did you install a MotorCraft fan assembly?
Found a video of the 2019 Mustang's horn:
Just to add, the 2018 Edge & 2019 Mustang now come with a single tone horn! And the replacement parts are relatively cheap. https://ford.oemdtc.com/3839/single-tone-horn-service-replacement-parts-available-2018-ford-edge-2019-mustang
They look nice, but what do they mean by "Flame-Out before installing"?!?
Unfortunately, Part 3 is the worst!! noting informative. A NASCAR driver having fun driving it and that it is quicker in a drag race than the Fiesta ST & Focus ST, no surprise! The Edge Sport (2015-2018) was already quicker than both!
Yes, there is a buton on 2015+ models to turn off interior lights when doors are open, but Dark mode also disables the exterior lights from coming on with the doors. You can also enable an option for it in the instrument cluster (named "Silent Mode") to enable/disable dark mode whenever you want. Good when washing/cleaning the car. -
Part 2 of 3 New info from the video: @0:54-0:56 Dedicated traction control off button next to the headlight switch with 4 mode selectable advance track. @2:01 The PTU is water to air cooled.
How come new unread posts from the "Super News Ticker" do not show up in the "View New Content" section? At least for me it does not!
- 1 reply
Heated and Cooled Seats
omar302 replied to Wedgeamatic's topic in Interior, A.C., Heat, Interior Trim
@1004ron, It is better than before and it does not heat up at all, that is sure, but it is still not like the bottom. There is still a considerable difference. -
First of all, thanks to tmarsh & Paul. Their posts were very helpful and I finally did the mod to the driver's seat. I plan on doing the passenger seat on another weekend. The job, after having actually done 1 seat, is not really hard. Also expect some to get some cuts as others stated when routing the hose, be very careful, the seat frame is sharp & will cause the type of cuts that see after you get them (what I mean is that you'd realize you got the cut after it actually happened because you did not feel that kind of pain). Also, flipping up and back the seat back upholstery turned out to be fairly easy, one issue I should have done better to fix the hose to the exhaust fix piece before installing. These are also a few comments on things I noticed. My Edge already came from the factory with the TSB fix, so the J-Clip mentioned is actually 2 smaller clips. They were short enough that I was able to slide the two sides of each to disconnect it. There is a plastic piece that seems to be a protective piece to protect the back from kicks. Paul mentioned it in his post, here is a picture of it & the pouch it goes into. The 2015 Service Manual does not make any mention of it, so it might be a 2016+ thing. As I already had the sock from the factory, I decided to only use the exhaust fix. I routed the hose to right next the the seat side frame & out through the slot like what Paul did. Only difference is the kit I received had the black hose & I was able to pinch the last 1-2 inches by hand so it will go through the slot. Then at the very end of the hose, I cut about 1/4" of half the opening, my idea is that if the seat cover flap on covering the hose opening, the exhaust air will still have an exit route. This photo is from tmarsh, only added the arrows to show my hose routing. The slot from inside: Hose coming out of the slot: Showing the hose behind the flap cover: Finished look: -
Here is video by MacT:
I'd ask are you sure it is 5w30? My dealer (the only authorized dealer in the country I live in) was about to use 5w20 oil in my Edge Sport. Even though it had 5w30 written on the oil fill cap, the dealer's Technicians are used to using 5w20 on majority of cars they get. Can you ask Blackstone if the measured viscosity would more in line with 5w20? If yes then that is probably your issue.
Steering wheel leather coming off
omar302 replied to Further North's topic in Interior, A.C., Heat, Interior Trim
Do you happen to have adaptive steering? If yes, did you get the airbag replaced? Or did you get the adaptive steering fault that required fixing? Why I am asking is because if you had the adaptive steering fault & it was fixed under warranty then you have already had a new steering wheel replaced, so it might have additional warranty period on it. Also, in case you had the driver's airbag replaced, on Edges with the adaptive steering, it required the dealer to make two slit on the back of both spokes, so there might have been a mistake that cut the leather? Just a thought as your Edge is relatively new to get such a defect in the leather. -
Ok, so I read this post on the F-150 forums and found out that the AFE can also be changed on my Edge. Still didn't try it as I need to calculate the actual mileage for several fill ups to calculate the AFE value. From the F150forums: LOM = Lie-O-Meter, they mean it is the MPG readout. For my Edge, to Engineering Test mode I followed the Lariat and up 8" procedure.
The airbag is installed on the steering wheel & is replaced separately. For the adaptive steering fault, they would be replacing only the steering wheel, not the whole column.
This has been incorporated since the 2011 model, it simply cuts off fuel when decelerating (coasting) since the vehicle's momentum will keep the engine running.
PTU is the Power Take-off Unit, basically it is gear-set that transfers engine power to the rear. Think of like the Transfer Case for 4WD vehicles except on the Edge it is always connected and has no low range (one ration only). Search the Forums & you'll find many posts on it. PTU fluid replacement
These are replicas 17" Escape wheels: https://m.ebay.com/itm/New-17-Replacement-Wheels-Rims-for-Ford-Escape-2013-2016-Set/332188898090
On the 2015+ models, 18" is the smallest diameter wheel available, maybe the 17" won't clear the brake calipers, anyone confirmed that they fit?
