Everything posted by omar302
I'm with Nick on this one, but that is my opinion, a opinion only. Ford's website for the 2019 ST doesn't even mention ST tuned, only "Sport Tuned Suspension". Then again, on Ford's Media website, it is clearly more than "just" a rebadged "Sport", with an ST-tuned sport suspension, but doesn't seem to be the full "ST" treatment, merely "Enhanced". Considering there is still no firm evidence of either way, I'd suggest to let it go till some new info comes up.
I already took it in for it, but the odor is still there. Our dealer is not a competent one, but we don't any other one here, so I have no other choice.
@lildisco Thanks for the pictures, do you get the exhaust odor under hard acceleration with climate on recirculating? Also, it seems the cut-offs on your liftgate are symmetrical on both sides? Location is not very clear on the first pic. Can someone else confirm? Especially on a year other than 2016? Maybe a bad batch?
I think it refers to the minimum wheel size. On my 2016 Sport ETIS has it listed as "Brake Disc 18 Fr Vent/17 Sol Rear", guess the ST brake package nets you bigger rear vented discs instead of solids.
Could someone with a 2015+ Edge confirm if this is normal or not? The weatherstrip for the lift gate has 2 places were it seems like a small piece is cut off. This is on the outer edge. Please see the photos. 1 cut is at the bottom right the other is at the left tailight.
Attached. Source. Liftgate.pdf
You mean the grille looking area on the bottom spoke? That is only a decoration. You have the adaptive steering wheel & the motor is behind it. Vehicles that don't have adaptive steering have an opening in that area.
- 1 reply
- 4
Any Windshield Wiper Rec's?
omar302 replied to chefduane's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I have recently tried cleaning the blades with a high concentrate mixture of MotorCraft windshield washer with water & it made a big difference compared to cleaning with water only. -
You need a special tool to remove the power outlet, then I believe you can replace the cover. https://www.amazon.com/Dorman-56457-Cigarette-Lighter-Removal/dp/B00G3YYSLE/ref=mp_s_a_1_1?ie=UTF8&qid=1528293696&sr=8-1&pi=AC_SX236_SY340_FMwebp_QL65&keywords=Dorman+56457+Cigarette+Lighter+Socket+and+Removal+Tool&dpPl=1&dpID=41jzz8XCo5L&ref=plSrch
SE with AWD come with 18" wheels standard (245/60R18). Probably due to the brakes as I recall AWD had larger front brakes.
Was the driver's side also recalled for the 2007-2010 models? It is not included in this list: https://owner.ford.com/tools/account/maintenance/recalls/frequently-asked-questions-regarding-takata-airbag-inflator-recalls.html
From the notice, it seems even with a rental you still keep your Edg/MKX with you till replacement parts are available, then you bring it in. @1004ron, the recall is different for the 2015+ Edge. Till now only the driver's airbag was recalled. No recall was announced for the passenger Airbag.
I'd guess it's cost & marketing. The F150's engine is mounted different, so it will require additional engineering to adapt the new technology to FWD mounted engines.
Not on the Edge, yet. The 2018 Edge Sport has the same engine as the 2015. The change you're referring to is in the F150 & Mustang.
2016 Edge Sport (G2) Front & Rear Sway Bars
omar302 replied to snmjim's topic in Brakes, Chassis & Suspension
This confirms that the procedure is the same, but not whether the parts are the same or not. -
Advance trac, abs, trac control
omar302 replied to Jeramie630's topic in Brakes, Chassis & Suspension
Try to reset the electronics by disconnecting the battery for about 10 minutes. -
Or simply upgrade mft to v3.8 as it includes the above mentioned fix.
Here is a mirror on ebay, the puddle lamp is clearly different than the normal ones. But if you're looking for a change, consider LED puddle lamps, they are much brighter & the white light really makes a difference, doesn't feel like cheap lighting anymore. I got these from China, they were ~ $10 when I got them, really good & cheap.
Instrument Panel Storage Box
omar302 replied to 4havnfun's topic in Interior, A.C., Heat, Interior Trim
This seems the part your looking for: https://www.tascaparts.com/oem-parts/ford-storage-box-fk7z5813546ab -
2015 titanium remote start not working
omar302 replied to jimbelk's topic in Alarms, Keyless Entry, Locks & Remote Start
on a 2015+, the hood switch is different. I think it is part of the hood latch. But if the the switch is acting up, you should get a hood open/ajar message in the instrument cluster. Check if you have any DTC codes. -
2015 Edge Sport Driver seat shifts when driving
omar302 replied to Clh64c's topic in Interior, A.C., Heat, Interior Trim
Go to another dealer. Worst case scenario, change the seat bottom and/or track. Would be cheaper than what loss you'll incur from trading it in. -
Congratulations. Enjoy the ride. Yes.. That quick steering... When going back to a normal steering you'll feel what difference is there. Makes my turns big.
