omar302
    230
Everything posted by omar302
  1. @ben senise, why look at an MKC? The Edge can have it as a factory option part of the "Cargo Accessory Package". So you might find an Edge with it at a dealer.
  2. From the "requires too much power", i'd suspect the cable. Try the original cables that came with the phone.
  3. That is a very good point enigma-2! OP should check for that first. Also, note that for the DRL to work in that case, the headlight switch needs to be in "Auto" & transmission out of "P". Link to owners manual.
  4. The 2015+ Edge's cargo cover is like that of the MKC in the video above. Only it has a flap on the other side, between the main rod and the rear seats to cover the area immediately behind the rear seats while also allowing the rear seats to tilt back without hitting the main rod. Compared to the older Edge's cover, it is a vast improvement, but it is bulky & long (wide when installed), you wouldn't want to remove it frequently.
  5. Yes. The sides were they are mounted to the side trim can be pushed in (make it shorter) and then can be removed. Similar to this:
  6. Just remember to back up your settings in case you wanted to revert the settings. Also, like some members have already done, you can make an excel sheet with the changes you want so that it'll be easier to look for the changes you want to make.
  7. I read that the Waze update on ios only work on Sync 3 with Navigation. The Nav icon would be replaced by Waze.
  8. Just in case, is the brightness slider up (to the right)? What I mean, are they set to high brightness?
  9. So today I figured out 2 more mods: 1st, is the country of the IPC: 720-04-02: XXXX xx - US default is 5553. On my Edge it was 5141. So what I found changing it is that I get different language options for the IPC. Like I had English (UK), French & Arabic, while US will get English (US), Spanish & French. Also, with English (UK) the door open warning states Door "Open" instead of "Ajar" for US. Just some language differences. 2nd: This is probably only a Sync 2 (MFT) thing: 7D0-01-01: xxxX xxxx xx - My default was "A", adding 4 changed it to "E", when you turn off the ignition you usually get a quick Ford logo shutdown animation on the MFT 8" screen, with this edit, you'll instead get a black screen with the date & time that will remain there for a while or until you lock the vehicle. Note that the date format depends on the MFT language pack, since mine has the EU pack the date is in EU format (month in the middle).
  10. Do the EcoBoost engines have the Water Pump installed in a different way?
  11. It is always nice to credit the source of the information. "Cargo Hooks" post.
  12. ForScan doesn't work on all aftermarket cameras. Your purchased Camera is probably not OEM. OEM cameras are very expensive.
  13. ford.owner.site stopped showing any updates for MFT for some time now. The only official way to update it to go to a dealer. Alternatively, you can find the files & download them for other sources. As far as I know, there are no real advantages for V3.10 over V3.8. Here is one source, you'll need the US version.
  14. Fords with BLIS don't come with the convex inserts, as far what I have seen. But it seems that we also got a difference here as my Edge also has the driver side convex mirror, like the passenger side (with BLIS).
  15. It is better to check the version in the settings' system information. Compare the version number to this list.
  16. Doesn't your Edge have MyFord Touch (aka Sync 2)? The discussion here is regarding Sync 3,the newer system that came on 2016+ Edges which is completely different from previous years. If your your still on V2.3 from the old system, then the latest upgrades to the old system do really fix bugs & stability issues.
  17. These maybe? or OEM 2011 Sport Taillights are a bit darker.
  18. On Android, go to Settings > Bluetooth > Sync (or whatever you named you car's connection). There should be check boxes for "Phone Audio", "Contacts" & "Media Audio". If there is a 4th one for "Messages", then make sure to check it. if it is already checked, un-check it & re-check it. If there is no "Messages" then you phone probably does not support the messaging Bluetooth profile that is required for Text message to be displayed on Sync. Edit: Searching quickly online, it seems the LG G4 does not support Bluetooth MAP (Message Access Profile), so it would probably not work to get messages on Sync.
  19. Congratulations, hope you enjoy your ride.
  20. rev-matched downshifts have been on the Edge since 2011.
  21. Highrule, the picture of the upgrade taillight looks to be from a Gen1 Edge (2007-2010). Notice a single bulb for the Turn signal & brake. Your Edge (Gen 1.5, 2011-2014) has separate bulbs for Turn signal & brakes.
  22. Ford recommends 9K or 20K mile PTU Oil change interval in the Middle East / GCC (Hot Climate):
  23. @thomashw If you can link the exact item or seller it would be of great help to others, as there are many sellers now on eBay for non-OEM cameras & at least you tried this one with positive results.
