omar302
    191
Everything posted by omar302
  1. If it breaks for any reason, it was not replaceable separately, the whole panel had to be replaced. Now the hook by itself can be replaced saving some of the cost.
  2. Seems it started to become available for ~ $ 37.84 (link).
  3. You have to register to get to see all the "Minor Features".
  4. Register here: http://www.etis.ford.com/ Then search for your vehicle and under "Minor Feature" you'll find "Tyre Pressure Sensors" it will state 315 or 433 MHZ. But as WWWPerfA_ZN0W mentioned above, yours is most probably 315 MHZ.
  5. Generally, the seat back`s cooling effect is weak & hard to feel, especially compared to the seat bottom. I had the same issue with my previous MKX. There was a TSB for 2015 models & early build 2016's, but later builds & 2017-2018 models already have the newer seat back TED units. If you turn on the seat hear, do you feel the heat in the seat back? If yes, then there is no blockage.
  6. You should be fine with the update. Also, MyFord Touch used the same update files for NAV & non-NAV equipped vehicles.
  7. I recently noticed that during acceleration in a turn, the AWD display will show more power going to the rear wheel than front. You can see it at 0:05-0:06 in the below video.
  8. The 2018 order guide was posted here: http://www.fordedgeforum.com/topic/22887-2018-edge-order-guide/ No real change, only repackaging of equipment groups & some color changes.
  9. Is the remote start function enabled in settings menu in the instrument cluster?
  10. Welcome to the forums & congratulations on your new to you ride. Hope you enjoy it, find the forum useful.
  11. The signature lights are the "triangles" in the bumper. They turn on with ignition or engine & cannot be turned off except by unplugging them. They do dim when the parking lights turn on. The actual DRLs depend. There are "configurable" types & non "configurable". Configurable, which are the default for US models, have a setting in the left instrument cluster to enable /disable. If enabled, DRLs will turn on when the headlight switch is in the "Auto" position with the transmission selector not in Park and there is sufficient ambient light. Non-configurable, are like that, they are either enabled or not from the factory. As for which bulbs act as DRL, if you have factory HID, then the DRLs are the inside bulbs which look like high beams, but they are only for the DRL. For non-HID factory equipped, the DRLs are the low beams with some sort of reduced voltage, which can cause issues with after market HID.
  12. I'll just add that this setting should only affect the current ignition cycle. On a restart it should revert back to default.
  13. I think what you need is Nav-in-motion (it is under Sync 2): Basically, your changing the country code to another country that does not have that restriction.[/size][/background]
  14. MacT had posted a video about it, but his Edge is a V6, sure if it is the same.
  15. Found this in the F150 sheet: Though, on my Edge Sport with factory HID it is set as follows: Edit: Also found this in the sheet: Mine is set as follows: I would try this one first since it seems to match, for my Edge at least.
  16. If you are into modding with ForScan, you can enable "Silent Mode" (sometimes call Dark mode or police mode). In the 2015+ Edge, you can enable a menu in the vehicle settings in the cluster for it. When enabled, all lights will turn off when a door is open with Engine off.
  17. Don't remeber reading any similar issue. Did you try this?
  18. Thoroughly cleaning will definitely help. You can also change the rear roof "legs" if yours are really bad: https://www.tascaparts.com/oem-parts/ford-slide-rail-front-extension-7t4z78502m78a/?c=Zz1ib2R5JnM9c3Vucm9vZiZpPU1XMDc0NzU1JnI9MTQmYT1mb3JkJm89ZWRnZSZ5PTIwMTEmdD1zZWwmZT0zLTVsLXY2LWdhcw%3D%3D
  19. Great that it worked. So now we know what it takes for an OEM Halogen to HID conversion. Direct swap plus As Built Data modifications using ForScan: 726-45-01 xxxx XXxx xxxx change value at XX to 7F 726-50-01 XXxx change XX value to 10
  20. Ignore the checksum error, it will correct itself (I'm not sure if it's done by ForScan or the module). As for 7F, my understanding is that your BCM is programmed with a certain fog light setting (low beams in your case) and the BCM would not allow you to change (the error you're getting), by setting the "7F" it is like your telling the BCM to accept other fog light settings, then you can change it.
  21. Congrats on your new Lexus, it is a unique car. Hope you enjoy it. Maybe you'll return in the future to the forums with an ST.
  22. Try changing this: 726-45-01 (2014+ MY) xxxx XXxx xxxx (Note: This setting enables all choices in the list for DRL options), the XX to 7F
