Everything posted by omar302
Leaving fob in car ??
omar302 replied to Blmkso's topic in Alarms, Keyless Entry, Locks & Remote Start
An easier way to test, leave the window open and work through it. Sit inside and lock using the keypad then test. Edit: note you have a 2015/2016 Edge, mine is a 2011. So they might work differently, but good to know how it will work. -
As far as I know, this part has many different part numbers, I don't why so many different variations, might be software/firmware issues, but all the posts I read (though few) that had them changed all claimed to have it as plug & play as long as it looks the same. Another thing, 2013-2014 models have a physical button for the Hazard flasher, so you might look for that better than 2011-2012 models. Finally, this part in no way affects the airbag operation, except for having an indicator for the status of the passenger side airbag (on or off based on passenger occupancy & weight) but never heard of it being part of the system. Disconnecting the panel does not cause the air bag light to come on, confirming it's not part of it.
You need this or this based on what your Edge has. It is too bad that it failed, but you can easily find a god deal on a used replacement online or at a junkyard. I think the Explorer also uses the same panel, not 100% sure.
20" to 21" wheels, do I need to reprogram my odometer?
omar302 replied to roots57's topic in Wheels & Tires
I recall the 2015+ Sport having a summer tire option, maybe those are the expensive set. Checking TireRack, a set of 4 Pirelli 21" is $ 754. -
I'll just add a note, if the fob is left in the car & locked using the keypad, yes it disables the fob, meaning the if someone breaks in, presses the brake pedal & push start button, the can would not run. BUT, if the intruder finds the fob & presses the unlock button on the fob, the fob will work, it will disable the alarm & the car will start. So, as mentioned earlier, it will not drain your batteries (car's of fob's), but it is a security risk. You either should really hide the fob or you can remove the battery from the fob to render it inoperable, though you would still be able to start the car after inserting the battery-less fob in the backup slot in the center console. -
Like what akirby suggested, don't worry about it. But, if you really want, you can change the tire size using ForScan, or a dealer should also be able to do it. -
Exterior Key Pad - No code...
omar302 replied to nittanydoug's topic in Alarms, Keyless Entry, Locks & Remote Start
Even with the fob inside it will lock with 7/8 & 9/0, no code required for locking. -
AC Suddenly Stopped Blowing Cold Air
omar302 replied to tamugrad2013's topic in Interior, A.C., Heat, Interior Trim
Thanks autom8r, the next day while sitting in a long traffic wait with temperature of about 110F my AC started blowing hot air. Once moving AC ran again, so I decided to change the cooling fans. Immediately after installing the new fans I got the old high noise of the fan, and in the next couple of days AC has been running fine. Seems my old fans were just not reaching the high speeds as they were before. Also being a 6 year old car, and with several members in the US reporting fan problems, it just seemed mine have reached the end of their life. -
I'll just add that earlier models like 2011-2013 Edge & Explorer (didn't try newer) also give you the option to reset the oil life meter to any value in 10's (10, 20, 30...100%) which is useful if you want a reminder in less than 10k intervals. For example, resting to 50% will make the oil life warning come after 5k miles (starts when 5% or 500 miles is left). Also, on another note, I wished if Ford programmed the oil life meter for our area, as here Ford recommends 5k intervals but 100% life still represents 10k miles.
Also the latest beta version of Forscan software can read the code. -
Out of experience with a 2011 MKX, 2011 & 2015 Expeditions, and a 2013 Explorer, all running in extreme conditions, a lot of idling, traffic and high ambient temperatures, the Ford oil life indicator comes on with mileage only. 100% for 10k miles.
Thanks autom8r. In the past 1-2 years I have noticed that my A/C wouldn't be as cold during idle as compared when driving & had attributed this to the car getting older (now 6 years & 68k miles). Reading your post got thinking I might have a Fan issue as I have been noticing that the fan was not becoming annoyingly noisy in the summer as I remember. I do have the factory Tow Package (with 2x 40A fuses) so Tested it as per your quoted post. Now just to note I do not have any overheating issue, only A/C in idle has noticeable reduced cooling, especially when temperature reaches exceed 110F. With the engine cold (or warm in our 106 F climate today), with no A/C no fan would be running. Starting the A/C caused both fans to run, though the driver side was blowing more air. Without A/C, also both Fans would run, but quieter (slower speed), still driver side blowing more air. As per ForScan lite, the FANDC & FAN_DSD, both readings are ~ 92% with A/C on & both would vary together with A/C off (in short testing from 18-35%). Does the above indicate I have one bad fan? The passenger side which is slower than the driver side? I also noticed it is the one closer to the exhaust manifold & has some heat shield on the motor, giving me the impression it faces more stress. It is the original fan that came in the car, never replaced. Any other test I could do to confirm it is bad? -
You can start the engine with the hood (edit: open), only not using the remote start function. Also the engine dies not turn off if the hood opens while driving. -
There is a Hood ajar switch, but no indicator. The switch is used for the perimeter alarm & remote start. Edges without remote start do not have the switch. AFAIK. -
Navigation removed after Sync2-V3.8 update
omar302 replied to Homer's topic in Audio, Backup, Navigation & SYNC
Check this thread. -
2011 Edge Bluetooth Module Failing
omar302 replied to Gortty-Pilot's topic in Audio, Backup, Navigation & SYNC
Try to test another phone before deciding it is a fault from the car. Do you have the latest update on MFT? Did you try to Master Reset MFT? Was your phone recently updated? may be that update isn't fully compatible, though I wouldn't think so. -
Finally purchased a 2013 SEL
omar302 replied to MemphisMike's topic in Audio, Backup, Navigation & SYNC
That was the earlier method. Then they figured out it out. The short version, change as built data to enable NAV, install the NAV application & License/hack, finally, get a maps SD card. Really simple, unfortunately for me, Ford does not have a maps card for the GCC/Middle East! Edit: Didn't see candurin's post above!! he already answered. -
Actually with ForScan factory NAV can be added quite cheaply & easily. Just need to know how to do it. If you're into hacking & modding that is. -
2013 has MyFord or MyFord Touch. If you have the small screen (non-touch) then it is Sync with MyFord only, if it is the 8" touch screen then it is MyFord Touch. The subscription nav is a voice turn by turn navigation, the 8" touch screen could also have offline full navigation. What does your 8" screen show in the top right corner? It should be when of these: 1- "Information": then it does not have navigation. 2-"Insert SD Card": Then you need the maps sd card to get NAV working. 3-"Navigation": then you should have NAV working. -
Ford recommends 10W30 for Middle East Edge/MKX, so it should not give him a problem. I would suspect that the low oil pressure is the symptom not the cause. Due to the engine cutting, combined with the low oil level (1/2 quart as mentioned by OP), it is causing the oil pressure to be low & get the message on the display.
ForScan Here is an old thread regarding the weights. 22" Stock was about 77-80 lbs each, 18" were about 58-60 lbs.
You should be able to program the new tire size, either yourself using ForScan or through a dealer. The AWD Sport had a shorter final drive ration (3.39) compared to the SE's (3.16), so that would definitely have an effect. Also the 22" are considerably heavier. No wonder early reveiws stated that SEL's were quicker than the Sport even though it had a larger engine.
Recreational Flat Towing - 2017 Edge
omar302 replied to BrentHG's topic in Cargo, Hauling, Roof Racks & Towing
Wouldn't that counter the reason why the battery was disconnected in the first place? -
From the above communication: Note that it states "If the PTU is determined to be repairable", so this "kit" does not repair everything with the PTU. Also this communication is related to the knocking/ticking noise only.
