2008 SE: Bilstein and H&R shocks and lowering sprins ?
enigma-2 replied to chrisg's topic in Brakes, Chassis & Suspension
I replaced my rears with Motorcraft. No complaints. Would never consider lowering, already running 20" rims; too many pot holes and bad roads around here. We like a quiet, smooth ride. -
Did you check the condition of the wiring and connector?
I carry my jump battery and a Dewalt tire inflator https://a.co/d/aZebBWZ in an insulated grocery bag https://a.co/d/fY9iZi3 , with the handles wrapped around the rear, drivers side, head rest. (Easy to reach from back seat). Bag doubles as a tote and insulated carrier when needed on hot days and coming home for grocery with frozen food. Little nervous about keeping it plugged continuously charging in as it contains a lithium battery. Besides, stays charged for months. Last used it last spring, came out of supermarket and car in lot had hood up, guy was tearing out back seat (battery was under back seat). I offered to get them started asap and he said he had jumper cables and didn't need any help. Offered again and he called my bluff. I got the jumper, opened his hood, located the jumper posts, hooked up the jumper, pushed the extra button and told his wife to start the car. Started right up. Should have seen his jaw hit the ground. He had been messing with the car for over a half hour (trying to find the battery). I smiled, took the thank you's in kind and we left. Feels nice to do a good deed. Literally, his jaw hit the ground. Eyes wide, stunned look on face. He had never seen one of these and had no idea that cars with hidden battery's have jump posts in engine compartment.
Video is a nice service perk. -
There is a button on your screen that's labeled "ALERT". If you're listening to a song and like it, click this button, and will take you into a menu that, once enabled, you can be alerted when either the song or artist is playing. Then when listening to SIRIUS radio, an alert will pop up on the screen to notify you when your song & artist is playing and ask if you want to tune to the station. If you don't want it, you can turn it off. P.S. don't set an alarm for Elvis or the Beatles or anyone who's playing all the time unless you love alerts ?
One of the newest YouTube videos from FordBossMe on installing a universal catch can. One very interesting feature was the method of removing the preformed ends of the OEM PVC hose to reuse with the Dorman tubing as supplied with the kit.
Sorry, memory, just got out of the hospital, still a little batty. Wrong sizes, but was talking about 1/2 sizes. Think it was one of Rainman vids. dabangsta got it right.
Seen in YouTube video where mechanic used a either 14.5mm or 15.5mm, 1/2" drive sockets on chrome-capped nuts. Worked perfectly. Think Amazon carries them
Page diwn and click on Save on required installation gear
Check these out. https://www.crutchfield.com/p_104BV960N/Boss-BV960NV.html?tp=20212 (They have better radios running well over a grand, but better functions and options like Sirus satellite radio and stuff. Look around while you're there). But this one lets you add a backup camera. Steering wheel control harness: https://www.crutchfield.com/p_104BV960N/Boss-BV960NV.html?tp=20212
2013 ford edge Sunroof Accordion Seals
enigma-2 replied to mitsos's topic in Ford Edge & MKX Member Builds
On 09 MKX the drivers side did this. Tried carefully reinstalling it and left it closed exposed to the hot sun to retake its shape. Worked for a while, but all it took is one close to again bend out of shape. Eventually bit the bullet and bought a replacment. Comes as a kit with the weather shield bellows and steel rods. As you found, expensive as hell, but there's no other choice if you want to restore OEM performance. Purchase appears to be as a weather seal. Replacement has been perfect for several years now. Wrote a description of the replacement here:- 1 reply
Hi bwguardian, read through this previous discussion where a fellow forum member did this on a 2008.
2018 Ford Edge 3.5L - idle is not so smooth
enigma-2 replied to bhamraS97's topic in Cargo, Hauling, Roof Racks & Towing
Engine needs a slight amount of knock to determine where the rich/lean setting is. Without knock, ecm defaults to a rich setting to protect the engine. MPG falls as well. 91 octane blocks knock and knock sensors can't send signal. -
Get a 2nd opinion from a different dealer. That quote smells like week old fish to me. Like they don't know what the real problem is, and quoted throwing a parts cannon at it. If the AWD coupling is locked up, it's either thr coupling unit or the module itself.
"The Media File Is Not Available"
enigma-2 replied to 23nautilus's topic in Audio, Backup, Navigation & SYNC
This issue has been seen in sync 3 as well. Seems to be a timing issue upon start up. Try removing the USB stick, then after starting, turn off the radio, waith for the various modules to connect (wait at least a minute), then turn on the audio then plug in the USB stick. -
2013 Edge AWD - AGM battery 124R fit?
enigma-2 replied to Braxus's topic in Accessories & Modifications
Water pump issues are generally thought to be the result of poor maintenance. Change your oil on schedule (or sooner) and coolant and should go a long, long time. All season for year around. Winter tires aren't recommended on hot asphalt. Noisy too. Besides, streets got plowed soon enough and you'll be driving an AWD. I run all season, have AWD and never been stuck. Biggest problem is it's a much heavier car than a stang and will slide a lotttttt further in snow or ice. (First time you drive on icy streets, wear a diper). Doesn't take long to get the hang of it. If you modify the exhaust, may not be able to get extended warranty (if that would ever be considered). 2013 is one of the years that are listed as having problems. 2014 is a much better year. As for the battery, been discussed here before. Don't remember what the conclusion was, think it was ok. Do a search in the forum. -
If it were me, I'd look for a vacuum leak. (Air leaking in after the maf and ecm trying to compensate with more fuel). Possible a vac hose isn't on tight enough or cracked when changing stuff?
I'm planning on a preventive maintenance water pump change out somewhere between 175k and 200k. My dealer drops the A-Frame as it's easier. (Easier means they charge more, lol) Believe it's also a good time to pop in new plugs as well. (Wonder if r&r the the PVC is worth considering as well.)
Check for corroded battery terminals. Then check CCA rating of battery (not just voltage).
Great news. But admit it, you're gonna miss those all-day trips to the garage. lol
My dealer took mine off during service and forgot to put it back on. I went back when i discovered it misding but they had already thrown it away. Hah! I made them order another and a week later they called to replace it. On them!
2.7L Aluminum oil pan Edge Sport - oil pressure issue
enigma-2 replied to Musketeer's topic in 2.7L EcoBoost
Well, the talk over there is the aluminum pan doesn't fit, seems I read some time back that someone tried it. Maybe there's a difference between the truck version and the CUV version? If I were you, I'd wait to find someone who's actually tried the install. I don't remember anyone successfully doing it, but I haven't really followed the subject too carefully. Perhaps if you talked with the local Ford Garage Service Manager? These guys are really knowledgeable on the basic problems and if anyone has done this, they may know about it. Never hurts to stop by and ask, I've done it probably too many times; got a reputation for questions, questions, questions. But I've found that my local SM loves to answer questions, including going to the area rep and even Ford Engineering, for answers. He has so much knowledge and no one ever asks him what he thinks. Another way to go, is to make certain the Ebay seller specifically states In the listing, that it will fit your exact engine (again, in writing) & that you can return it, if it fails to fit. I wish the best for you, i hate oil leaks, but it seams to me, that a good due job, on the existing plastic pan, is what's really required. If it was my car, I'd have the Lincoln Garage do the job and get a warranty on it. But for the cost of a 12 hour repair, it would have to be a lifetime warranty !!! -
Man was I out of it. Looked up AAA for my area and it showed $150/hr. What the sam hell? I'm so used to "got a warranty" and never pay, I wasn't paying attention. (saving face) "I was quoting pre-Covid" prices. (cough, cough). Also on the website "changing a fuse, $10 - $50. A FUSE! Damn. I'm coming out of retirement. -
number pad on door - can it be added?
enigma-2 replied to Bravo19's topic in Alarms, Keyless Entry, Locks & Remote Start
If it's not any trouble, any chance you could look in the IDS to see how to activate a rear camera in a 2009 MKX? They designed the car to use a camera, but never offered it as an option in US cars (just in Japanese cars). Like to add one.
