Everything posted by onyxbfly
Congrats! Welcome to the forum. I see what you did there! That's a good looking graphic. It ties the tint and rims together! It makes the ingot silver pop!
Intercooler Grill & AGS (2016 Sport)
onyxbfly replied to snmjim's topic in Accessories & Modifications
You got it! -
SNMJimm and Special K will sort you out! Here is a link for the front strut bar. https://www.ebay.com/itm/15-20-Ford-Edge-Vignale-Endura-Lincoln-MKX-2nd-Front-Upper-Strut-Tower-Bar-Brace/123608274036?fits=Model%3AEdge%7CMake%3AFord&hash=item1cc7a09474:g:yXgAAOSwoP9cckMU -
Thanks for sharing! We appreciate you!
Congrats and welcome to the forum!
Congratulations! She's pretty! Welcome to the forum!
Its not clear what year your Edge is. PTUs are not backwards compatible. You have to get one for your model. 2007-2010, 2011-2014, 2015-2018 etc. Everyone's financial tolerance is difference as well as their ability to make repairs etc. Personally I would not repair the PTU, I would replace it. If you do replace/ repair the PTU now is the perfect time to install a drain hole. A drain hole will infinitely make fluid changes easier. We change the PTU fluid once a year or every 15000 miles. With proper maintenance you should be able to get years of reliability out of it. HTH
Welcome to the forum! What part of New York are you from?
Congrats and welcome to the forum! She looks very similar hahah If you're interested in tuning check out Special_K's performance mod thread. Shoot Special_K a PM and ask him about JnCPerf........
She's a beauty! Welcome to the forum!
Congrats and welcome to the forum. Sweet ride for sure!
Congrats, and welcome to the forum!
Changed engine oil, transmission fluid and PTU
onyxbfly replied to ZZOOGG's topic in All Wheel Drive (AWD)
I would aim for once a year or no more than 15-20k miles depending on your driving habits. I would change the PTU and RDU while shes in the air. I'd also suggest draining and filling your transmission fluid and coolant while shes in the air. If you're local to MD,VA,DE are check out JnCPerFormance. They will do right by you. -
Some tuners can provide tunes that are adjustable on the fly based on the octane level in the gas. More often than not those type of tunes are not fully optimized to provide the best performance. If you are not able to use multiple tunes because you purchased one tune, I'd strongly suggest using the octane that the tune specifies. If you find your self low on gas or in a area that does not have the gas you require, please revert back to your stock tune until you are able to get the gas you are specified for.
Mud Flaps - Guards for 15-17 Sport trim
onyxbfly replied to NoDTMF's topic in Accessories & Modifications
Congrats and welcome to the forum! Point your browser in this direction..... EDIT: Unfortunately the eBay link is no longer valid. They have some other sets available on eBay but I would be leery of them as they do not seem like they are molded properly. Nevertheless Special_K performance/ mod thread that I linked you to is the place to sit back read and enjoy! -
When you select sport, it will ask you if it is a sport or not just like your picture.....then you get the unfortunate message..... -
I may or may not have seen you at the Wawa on Aramingo!
onyxbfly replied to ben senise's topic in Accessories & Modifications
Unfortunately it can be done via FORScan. A member here using HP Tuner (I forget which tuner was tuning his edge) was able to get the gear to displayed all the time. If it can be done on the edge it can (in theory) be done on the ST. -
Congrats! Welcome to the forum!
Congrats and welcome to forum! The 2017 explorer bolt pattern is 5x114.3 The 2015-2020 Edge bolt pattern is 5x108 The hub size is 63.4 You need to find wheels from 2015+ Edge, MKX, Nautilus, Jaguar, Volvo a few others that escape me at the moment. Once you check the bolt pattern, and hub size. You have to check the offset. Here is a link that should help. https://www.wheel-size.com/size/ford/edge/2015/
BCB or ZFG or possibly Unleashed are your next options. I'd call and see if hey have any used programmers available etc If not I'd enjoy the downpipes and save for the new tune. It will be a night and day difference. Its like getting the most bang for your buck.
Congrats and welcome to the forum! Shes a beauty!
Congrats! Welcome to the forum! Great color you have there!
You're going to need to go with a different tuner as Livernois does not provide support for custom read I.E not off the shelf mods. Or you can put it on their dyno and they will tune for it!
