garycrist
Everything posted by garycrist
I would search for a loose/bad ground.
@razziel24 it looks great. The work you did might not please all but, if you like it, it is great.
If your fuel additive does not have PEA in it, your, shall we say, "urinating into the wind". As far as oil, I would point you to Lake Speed jr.'s video on Valvoline's Protect and Restore engine oil. To go deeper, find his comparisons of oil tests too. Did not realize there was a pun till I proof read it.
- 31 replies
- oil
- consumption
(and 2 more)
Jack points and jack stand placements?
garycrist replied to Vortechtral's topic in Brakes, Chassis & Suspension
Get the poly hockey pucks that fit your jack/stand. ONLY jack at the spots in the owner's manual. -
I have 285 35 22s on my ST. Check out my "Black Mamba" in my profile.
Tire inner shoulder wear and no chamber adjustment
garycrist replied to Gibbs Garage's topic in Brakes, Chassis & Suspension
What brand of tires and what is the DOT code on the tire? It appears so one likes to drive what some would consider a little "sporty". The shoulder wear (both sides) indicates where the steel belt ends. If it was a toe problem, the edges of all of the tread blocks would have a feathered edge on one side. But, the pics indicate small chunks are being shed while at high steering angles. In the top image it appears that a little extra wear is indicated by the right side being a little more worn than the left. That would indicate about half a degree of extra camber to that side, providing that is about 12 K miles in normal conditions on that tire. Gary -
I think he is referring to Lane Keeping. I have turned it off because I drive the car, not the computer.
@Davidoo, I also have a 22 ST too. As you stated confusion exists but I will help you. Our RDUs have a drain plug and a fill plug and the tranny has a drain and fill plug too. AS for no lift, I used 4 ramps https://www.amazon.com/RhinoGear-11912-RhinoRamps-Vehicle-Ramps/dp/B0117EESNC/ref=sr_1_4?crid=R9MRLD01WYW4&dib=eyJ2IjoiMSJ9.4okd22uK9UE4fyiUUj08Slo6FXaiQHl7CDfDtOe6sUfcGRBJAgsX8MqPngrm9kJj4_3k1CFA6Tj8lj_S6e8kSUuSTfKfL3gifNAavPsy5QjQ8d7glVtjxGhLRXcCP5xovssfsIUDvyJ4RNRBKRRV7a7v0DqBTpW18rGk--538kcq-1PGrilqWVhHZfyIYVigRFrCLV_D8o756fLxqh10yHiJWildoqkhEio7Lu-oe1u3RCq-jffBN70GoWrpAU-YpLRZ3mWX2xMWnG01UCtJdanexSTKHq_awTxbnnfHug7tSZt43yLO8t8X8Ox5CDqcKOvO3NIVLqVk2cWpT9jm35ooQ3sB5zbEurysBH27zblI8fy18LW8xriFy3MuRQUnoUYKv5_n5Y_OVCdb9bA4TuXlUaXChZ9w9mkW_Dcj7k6KTmg84ncSQ3S2RLWiyFHr.ey3DhlG06_05QhLU4ioQXHO0ZfYSV2WxTZ0qQ3m43Lg&dib_tag=se&keywords=drive%2Bup%2Bramps&qid=1742655930&sprefix=drive%2Bup%2Bramps%2Caps%2C155&sr=8-4&th=1 to do all my service on a creeper to boot!
My 1st. plan expires @75K miles/ 2028. I just did a RDU service and discovered metallic glitteries! I am not as mobile as I once was. Do we keep the problem and extend the ESP or swap it out for an Exploder ST? I contact my guy with my wallet wide open! He told me keep your $$$ till 73K miles or 6 months before expiration date to renew. Hang onto your money!!! After that experience as well as other folks experience, I why people from across the US do some driving. GL
On my 2008 Edge 3.5L, I replace the spark plugs about every 75K miles. 210K miles now and I should inspect the OE belts.🤣🤣
What I could hear, it sounds like a heat shield buzzing.
2022 Ford Edge Titanium - Auto Start System Not Working
garycrist replied to OhhBnertt's topic in 2.0L EcoBoost
Don't believe anything a salesman tells you! Your battery needs to be replaced. I have the same issue and I am waiting to get into the dealership for that and some other issues. The new Edges have a "gas saving " feature that only charges an AGM battery so far. As a side note, it seems that a bunch of AGM batteries in 2022 were defective. -
Carrier Bearing oddity??? Please Help
garycrist replied to soundwav's topic in Brakes, Chassis & Suspension
Hate to tell you this but, sounds like a U-Joint or the Carrier bearing. Look closely at the u-joint's cups to see if any rust is evident. If so, that is what is left of the rollers due to "Fretting Corrosion". Also it is the "Down Fall" and the waster of several hours of grief, "It could not be _________ as it is new part"! If you decide to do the u-joints, spray paint the parts so you assemble them back in the same position. Even some times this does not work and a vibration is induced. Sometimes it can be fixed by rotating the assembly 180 degrees. Else the drive shaft shop. (do they still exist)? GL -
2014 Edge Defrost System Problem
garycrist replied to Beerfoot's topic in Interior, A.C., Heat, Interior Trim
I see this an old thread but, a continuing problem for some as well as someone's future. Water on the heater core is causing this problem. So, typically,the heater core is leaking or the A/C drain is plugged up. Water intrusion from a puddle or rain, might enter via the A/C or heater lines entry points of the Firewall.(Rare) Last but not least the A/C drain lines. If it is the Heater Core the fog on the windows will taste sweet else it's the drain line probably. GL Gary -
That is a SHARP color!
- 1 reply
Check the anti-rattle clips and/or pad shims. The "hum noise" you hear is the pad "rattling" from "kick-back" of the pad due to very small high spots on the rotor. In the past, I've cured disc-brake pull as well as noise by switching pads side to side as screwy as that sounds! Re-lube the mounts and refinish the rotors (sand them with a sanding disc) and if all fails, change to a different pad material. Sometimes the combination of parts do not favor a driver.
That is far more than I paid for 75K/ 5 years. We don't plan on buying another vehicle due to age. So, I'll enjoy the ST and let Ford fix it for $100 a whack and a free car to drive.
Here's an update. While doing an oil change (Valvoline Protect and Restore) and a 25K mile service on the the RDU, I noticed a nice bronze goldish color in the RDU fluid. (OH BOY). While draining the oil, I noticed the oil pan is leaking and the battery is shot after 2 years 3 months. Thanks too knowledge gleaned here about the oil pan fix, it was time to trudge to the dealership and talk to a service advisor. My ESP goes to 75K miles and 2028 but, if the RDUs and PTUs keep failing, should I trade in for an Explorer ST or can I extend my ESP out to say 125 K miles+ for a few thousand dollars? That question was answered promptly by my ESP guy in less than 30 minutes via e-mail. Save your $$$s was the answer! Wait till 73K miles or a few months before the 2028 deadline. One has to respect one's contact when one has the wallet wide open and he won't take your money! If you need an ESP Quote give me a PM I'll set you up with my guy (I make no money or bird-dog fee). After that I'll drive a ways to buy a new Ford (If we live drive that long).
Retrofit 360 Camera Into Ford Edge
garycrist replied to Wubster100's topic in Accessories & Modifications
You are a man after my heart! I've done this sort of stuff for a long time, a long time ago. But, there were no charts and obtaining parts from different auto manufacturers to modify to fit the current project. A real funny one was a Salesman came back and asked if I could install remote control mirrors on a 1974 Fiat 124 Spider. After a quick thought I said "Yes" and the sale went through. The mirrors came from an AMC dealership and the New Car Owner loved them! I applaud you to the MAX! -
I saw these on the news as we have snow in TEXAS. They can barely navigate rain but, snow???? Check out these Snow Socks... https://autosock.us/
- 1 reply
Weird acting rear light…
garycrist replied to FLvet85's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I guess a bad ground based on the voltages given. I've seen the direction indicators on older Fords "glow dimly" with a bad ground in the hear lights or tail lights. -
Labor hours to replace an oil pan.
garycrist replied to rjburer's topic in Dealership & Vendor Experiences
Real easy to calculate. Ask what oil pan R&R minus transmission R&R is. Then argue from there. -
Thank GOD bias-ply tires aren't on cars any more!
@TourGuide Search through this forum as all that needs to be replaced are the 2 fasteners. The part numbers and a member's remarks are also provided,.. Cheers
