Everything posted by handfiler
Went to dragstrip with my 2019 Ford Edge ST
handfiler replied to TT Steve's topic in EcoBoost Mod & Tech
Excellent results TT Steve. -
In my experience with differentials, transmissions, transfer cases et cetera; quite often overfilling results in the excess amount exiting the unit via the breather. I follow the factory fill procedure and save myself unnecessary headaches.
2019 Edge Titanium forgets dash settings
handfiler replied to AcousticTheory's topic in 2019-Current Edge & Nautilius
Welcome to the forum. Auto stop/start defaults to on when you start the car. Autostop makes a module that defeats this. Easy Entry and Exit can be disabled in settings - vehicle options. -
From one old guy to another: Welcome to the forum!
Exhaust tips: Y vs Offset for a 2016 Sport
handfiler replied to TheWall0211's topic in Accessories & Modifications
Yes I'm aware of that. The trapezoidal openings in the rear lower facia are meant to give the appearance of exhaust tips. I have no idea why Ford didn't make the design exhaust tip installer friendly. My best guess would be to eliminate the need to constantly clean the soot build up that GDI motors produce in abundance. -
Maybe it has to do with the fact that your looking for unobtanium. 2 5/8" is an odd ball size. -
2019 Ford Edge ST Replacement Tire Options
handfiler replied to PokeTheBear70's topic in Wheels & Tires
Now superseded by the AS Plus 3 -
Painting the rear wheel hubs to get rid of the rust would be a low cost high reward mod.
Sorry to hear about your misfortune. Glad it wasn't worse. Evidently "Built Ford Tough" applies to the Edge as well.
Cold Air Intake Edge ST & Sport 2.7EB
handfiler replied to Xtra's topic in Accessories & Modifications
Well that's a downer. Why not use EMT instead. Everyone here knows your reputation is beyond reproach. I sell audio gear on Canuck Audio Mart from time to time. 90% of buyers are okay with EMT. The other 10% are SOL. I absolutely detest paypal. -
I would upgrade the coolant to the latest specification and continue to drive it without worrying about it.
2016 Sony System Sound Issues
handfiler replied to AF_Vet's topic in Audio, Backup, Navigation & SYNC
FWIW I briefly owned a 2012 Focus with the 10 speaker Sony audio system. Through experimentation I ended up disconnecting the center dash speaker. That made a noticeable improvement. This was by far the worst sounding premium audio system I have experienced in a vehicle. -
CV Axel Replacement/ creaking noise
handfiler replied to ColinM31's topic in Brakes, Chassis & Suspension
Did it make the noise before the struts were replaced? Were the upper strut mount bearing plates replaced? If not that could be the source of the creaking noise. -
You might also want to consider performing a parasitic draw test to make sure it's not the battery that's causing your grief.
I had to look at that on my larger monitor. It looks like Chinese script to me.
It would need to tick all the right boxes boxes to entice me away from my Nautilus. 2 row seating, roomy, possibly electric and built in Oakville would be a good start.
Ford Edge ST throttle control booster
handfiler replied to ST-EDGE-ST's topic in Accessories & Modifications
No but a former ST owner installed the above. Thought it was pretty good. I just use sport mode when I want quicker throttle response.- 1 reply
Was hoping this thread had run it's course.
Or just check it with a gauge twice a year.
Hey Welcome to the forum. I'm in Canada but spent a year down there near Wausau setting up a window factory. I had a great time there!
Android Auto with Google maps. Always up to date, always gets me to where I need to go.
need more power on the wireless charging pad
handfiler replied to ben senise's topic in Audio, Backup, Navigation & SYNC
If your not in a rush you can get them from AliExpress for 1/3 the cost. USB 4 Magnet Adapter That's where I purchased mine. Delivery takes about 3 weeks. -
As much as I enjoyed the convenience of the AA wireless module, I stopped using it a while back. Using the module in conjunction with wireless charging put too much stress (heat) on the phones battery for my liking. Battery temperatures came down to low 30's from mid 40's (C) using a wired connection. My compromise solution was to fit my devices with magnetic USB quick connectors. USB C Magnetic Adapters Some things to consider if battery longevity is a concern.
