omar302
    230
Everything posted by omar302
  1. Not me, neither did I here about it before. Probably an isolated issue.
  2. With only 1 key, you need either a dealer or a locksmith with proper tool to program an additional key. I'd also suggest they erase all old keys.
  3. Ford Panoramic roofs are not the same. I see 3 different types: 1- Sunroof with additional glass extending to the back seat. You'll notice that the front (moving) glass panel is smaller than the rear, and when it opens, it slides under the rear glass panel. All Ford/Lincoln models with panoramic sunroofs have this except the Edge, MKX (<2016) & MKZ (2013+). Edit: I think the 2015+ F150 now has the both glass panels nearly the same size, but the front panel slides under the rear panel. 2-The "vista" roof, where the front glass panel is larger than the tears. Here when it opens, the front glass slides over the rear glass & would actually open over the roof. As far as I know, this is only present in the 2007+ Edge & 2007-2015 MKX. The 2016 MKX uses type 1 unlike the new Edge. 3- The full roof, which only the MKZ has (2013+). The whole roof is one big glass panel, when it opens, it slides over the rear window.
  4. If memory serves, if you have the 3.5 V6, then you have the standard skirts. With the 2.0 Ecoboost, skirts are different. Edit: Also Sport models have different skirts.
  5. I'd guess it is also because of the tranny. As far as I remember, the torque limit was 350 lb-ft for the 6F55 transmission. Which was supposed to be the reason why the FWD based 3.5 Ecoboost engines were all limited to 350lb-ft of torque. I was surprised to see them announce the MKX with 335hp & 380lb-ft, more than even the RWD based F-150 (325/375). So it the PCM might be cutting off power considerable at shift points to protect the transmission.
  6. Glad your ok. Yes it was bad, but I wouldn't call "Lethal". Anyway, if you don't need the "kick" option, I'd guess the easiest solution is to disconnect the sensors under the car.
  7. AWD will disconnect (turn off) when the spare wheel is installed. From the Owners manual:
  8. For a black Edge, I suggest the 20" wheels as I think the polished wheels would look better on an all black car, plus as others pointed out, cheaper upfront, better ride (even if slightly), and cheaper tire replacements.
  9. Version 3.8 has been working fine for most people. Your issue is not normal. I suggest you try a Master Reset & battery pull. If you still face the same issues, then it probably is a hardware issue. APIM replacement might be required, which is covered by the extended warranty.
  10. With enough resources & time, it should be possible. But it would probably (actually, definitely) not cost effective. Especially for the 1st generation (2007-2010). If it was a simple add on or replacement, Ford would have added it to the 2016 Explorer refresh.
  11. I know it has been nearly a year, but I just saw this & thought it might be relevant if the issue is still not resolved:
  12. Those images reminded me of one difference in projectors for HID & Halogen lamps. Notice the slight light glare above the cutoff line? This is intentional on Halogen projectors meant for some light to bleed upwards to illuminate road signs, especially overhead. When an HID light is retrofitted in a halogen projector, this "bleed" becomes much more (HID is ~2X brighter than Halogen). Some retrofitters covered these holes, also referred by some as squirrel finders.
  13. I think what the OP is asking for is part of the spoiler as per the diagram.
  14. I remember it was always like this, whenever the phone is connected, the audio from my HTC does not come over it's speakers, which is annoying, since I don't stream Bluetooth audio I just disable it from the phone to get notifications from the phone's speakers. You can also check google Maps' navigation settings. There is a setting to Play voice over Bluetooth added not long ago, uncheck it & try. Also the volume can be adjusted there.
  15. Did you report the install of V3.6.2? if not, try that first.
  16. This is for the Escape. The Edge uses a different AWD system, AFAIK. Though that is mostly true, the Edge does have software enabled torque vectoring. Braking one side to shift power to the other side. You can see as standard under Power & Handling . http://www.ford.com/crossovers/edge/compare-models/?models=titanium|sport
  17. I didn't try the new Edge, but on my MKX also with a touch sensor, though it looks like a button, I have no problem distinguishing the sound of the doors being locked. Also the hazard lights will flash once to confirm that the car got locked. Don't the 2015 flashers flash also? For the Lexus (and Nissan), their is also a beep sound (not the horn) to confirm the lock process. Though useful, I imagine where it would also be annoying for some. They do 2 beeps for unlock & 1 beep for lock (or the other, don't remember exactly). Also, since we are at it anyway, the Lexus (and Toyota since I tried a 2007 Avalon when new) would turn on the interior lights & puddle lamps when approaching the vehicle, kind off like the welcome feature that Lincoln is now advertising as a "Lincoln" feature on their newer models. On the other hand, Lexus'/Toyota's intelligent system will NOT allow you to lock the car with Engine running from the outside. So each system has their advantages & disadvantages.
  18. FYI, newer Lexus' are now similar to the new Edge where you touch a ribbed area on the top side of handle to lock the door. There is no more a physical button.
  19. Update, now 2 more times the screen brightness reverted after the system "Restart" thing. It took about 21 hours of drive time for the reset to occur. Will try to get a video next time to show the brightness change. The ambient lights, ringer & text notification all remained as selected, so that's good.
  20. As per the Build site, yes. But the 2016 order guide clearly showed it as a new standard feature on the Sport.
  21. enigma-2, in my opinion you should be fine since the MKX has projectors for the low beams.
  22. Did you try to update MFT to the latest V3.8? For me it has been fixed since V3.7 & is still fixed in V3.8.
  23. @engma-2, I didn't notice that there was additional glare in the Taurus, the headlight already had a cover inside it that covered the bulb. From the outside you couldn't see the bulb. For the Edge (2011+), since they have projector headlights, don't think it matters. Also, some Fords with projectors came from the factory with 9005 bulbs that also doesn't have the blacked out tip.
  24. Without knowing the make of the remote starter it will be difficult to diagnose. You can check under the instrument panel on the driver's side for a module that might indicate the make of the starter. Also, do you have the door ajar issue? Where the vehicle still thinks the door is open? Or the "Shift to Park" issue? Where the Vehicle thinks your not in park. Both issues would probably affect the remote starter.
  25. @Picturepro No need to wait for summer. Set the climate control to hear, maybe around 75 & make sure the air ducts are not directing air directly to the seats, turn on the A/C seats, then measure the seat temperature after a long drive. compare the temp reading to something that is not cooled, like the headrest or seat sides. Again, note that the seat back cooling is very minor & difficult to feel.
