Everything posted by omar302
Follow up, I just received my order and I can confirm they are the same lug nuts for the Ford Edge. So if you need a set of 5 or more OEM lug nuts, buy the Ford Performance part M-1012-M.
Actually it is "EDGE" under the Blue Oval at the back.
Ford should make a 2-row version of the Explorer to replace the Edge. Would be RWD based, add more sales volume to the Explorer nameplate and the ST version would be better than the Edge ST.
Impressive time. Seems the transmission was taking its time to shift. You would probably get a much better time with performance shift tune, though I personally did not like it and kept the stock shift tune for every day drivability. Did the tranny also shift 2-3 before 60? I was under the impression it shifted after 60. No wonder the 2019-2020 ST was slower if it had to shift 1>2>3>4 given the extra 2nd compared to the 2015-2015 Sport and shorted final drive ration (3.65 vs. 3.16).
I recently found that there is a Ford Performance part (M-1012-M - link) that includes 5 lug nuts for the Mustang (which has the same lug nuts as the 2015+ Edge) for a retail price of USD 15. Searching online I find it for even less (eBay listing for 4 sets - Levittown Ford Parts). Making each lug cost nearly half as much as buying them individually. I ordered the set from the eBay listing and will update once received & installed to confirm. I had previously installed black lug nuts from Veritek (link to thread about them) however they quickly started to show rust after a few wheel removals/installations.
2016-2018 look the same but the 2019 was a refresh, updates front/rear styling, 8-speed auto transmission, rotary dialer. The newer the model you get the better in my opinion.
Fill Up Issues and Trip Display Needs Tweak
omar302 replied to Dr. Evil's topic in Accessories & Modifications
On newer models unfortunately there is no "Gallons used" in the trip info and I haven't seen any way of enabling it, even though the info is available in Engineering mode (link to how to enter Engineering Mode). For the fuel consumption (mpg) inaccuracy, there is a workaround detailed in this post: -
I'll just link this post here for anyone with a 2015+ Edge interested in upgrading their cluster.
It is very expensive, however I have doubts on their claims as the images/videos they show appear to be for the stock 10" display from the MKX/MKZ (already being retrofitted to Fusions/Edges) with a modified inner mask (under the lens) and firmware already available. See below video sample. Also, not sure they will be able to get that same cluster to work on older vehicles (2011-2014 Edge, 2011-2015 Explorer, pre 2013 Fusion) due to the different vehicle electrical architectures.
2016 Edge - A/C water Drain location?
omar302 replied to omar302's topic in Interior, A.C., Heat, Interior Trim
Thanks @Haz for your usual detailed reply. Reading you reply had me wondering what the evaporator assembly housing looks like (P/N: K2GZ-19B555-BG), so I found a few on sale on eBay (example 1, example 2) and it sure seems there is a drain location built into the assembly housing, just apparently it would drain directly without going through a "drain pipe or hose", hence the no-part available for it. Also from the pictures it seems to be located below the heater inlet/outlet pipes. Have attached photos with arrows pointing to where I think it is. Will try to search again in below the heater pipes. My doubt is that the water drips on to the exhaust/catalyst heat shield, then is absorbed in to it and evaporates before dripping. The P/N of the housing is the same for 2015-2021 Edge and 2016-2020 MKX/Nautilus. Can anyone confirm if their Edge/MKX/Nautilus from those years drips water from the A/C? -
Does the Gen2 Edge have an A/C water Drain location? I don't see water dripping even though it is quite humid nowadays. Also couldn't find a drain pipe looking under the vehicle. I want to check for blockage as I am getting a slight mildew smell sometimes when the A/C starts blowing, however all the carpet inside is dry. My other car, the MKS, drips large puddles of water, as does most vehicles I see on the road.
Did you drive the vehicle? if not, drive it for 10 minutes or so to see if it fixes it. Also try disconnecting the battery for a few minutes.
Did the vehicle read the sensors automatically and show correct tire pressures or was there a procedure performed?
Small missing trim piece (liftgate area)
omar302 replied to Correy's topic in Interior, A.C., Heat, Interior Trim
Should be this part. -
07 Edge AC - Not Blowing Hard (AT ALL)
omar302 replied to cornelljl's topic in Interior, A.C., Heat, Interior Trim
Did you check the cabin air filter/screen? -
Project - Get Active Cruise Control functioning
omar302 replied to andyh1108's topic in Accessories & Modifications
This is for my 2016 Edge Sport: From Motorcraft ABD site: From ForScan (also abt file attached): 2FMPK4AP9GBB98478_PCM_20220310_144949.abt -
This is for my 2016 Edge Sport: From Motorcraft ABD site: From ForScan: -
I understand this and have not read anything to the contrary, however, in my testing it seems the Edge will "Auto learn" the tire positions. I previously made a short video showing it. Link to post.
2016 Edge Lift Gate Not Locking
omar302 replied to Maria's topic in Alarms, Keyless Entry, Locks & Remote Start
The liftgate will always open with the fob. To test if it is locked, lock the doors and keep the fob away from the vehicle, few meters away, the try to open the liftgate with button above the license plate, it should not open if it is locked. -
2015 edge FWD 2 liter front rotor size?
omar302 replied to Lincoln81's topic in Brakes, Chassis & Suspension
I don't think it is easy to determine which size you have by description only. If you want to confirm which size online, your best bet, in my opinion, is to check with a seller who will confirm if the rotors you intend to purchase are a correct fit by VIN. -
Add Nav to 22 Edge Titanium?
omar302 replied to Inspidship's topic in Audio, Backup, Navigation & SYNC
22 Edge has Sync 4A, I don't believe adding NAV is similar to Sync 3, at lease have not seen it done yet. However, Sync 4A should have Android Auto and Apple Car Play, they should be even better than the factory NAV.
