Everything posted by omar302
I thought the Lincoln MKS only got the Ti-VCT in the 2013 refresh.
Just had a thought about this, Ford usually states that using a dissimilar size spare for a long period could cause damage to the AWD system. Also, when using the mini spare that the AWD will switch off to protect driveline components. So what if using a tire that is smaller than regular, but still larger than the mini will put the AWD system in a bit good situation, AWD does not disconnect, but still compromises the system? From the manual: What I mean to say, is that as long as you still don't get a fully matching spare whee/tire size match, you are still restricted to the same shortcomings of the mini spare. So just keep the mini, save space & make its installation a bit easier being much lighter.
Will 2015 Explorer Sport rims fit 2011 Edge SEL?
omar302 replied to Edgingage's topic in Wheels & Tires
If I remember correctly, it was a slight rub, but it was concerning. Wouldn't try to drive with it. Buy it was small enough that I think the smallest spacers could fix. By the way, I tried Limited wheels, the aluminum polished ones, not Sport wheels. So they might be different. -
Are TPMS stems/valves removed when replacing tires on rims?
Valve stem removal is NOT necessary. As @1004ron stated above, and I had tires replaced on my previous 2011 MKX & current 2016 Edge, the valve stems were not removed. But, the official statement is to replace the valve stems when installing new tires. -
No. TPMS valves/stems don't need to be removed to remove/mount tires. I had my tires replaced without removing the stems, although the owners manual states to change the stems when installing new tires. Our local tire shops are not really well educated!! -
Though I am not in the US, for my earlier 2011 MKX I had with 1 key initially, I bought a used key/Fob from eBay and got a locksmith to cut it & program it. The locksmith has to have the proper equipment for programming the key. If you already have 2 keys, then programming can be easily done without any special equipment.
I once tried a 2013 Explorer Limited 20" on my previous 2011 MKX (similar to the Edge) and the wheels rubbed the front brake calipers. -
2017 Edge - Closing windows with remote
omar302 replied to ToeNuttz's topic in Alarms, Keyless Entry, Locks & Remote Start
No. The hardware doesn't include what is required to do it. -
Do you mean accessories connected to the 12V power outlet(s)? The Power outlets on the 2015+ Edge will turn off off after a certain amount of time, i think ~1 hour & 15 min (I did not time it). If you are into ForScan mods, there is an edit that can change the timeout.
I once tried 2013 Explorer Limited 20" wheels on my previous 2011 MKX and they rubbed the brake calipers.
One more observation on the LMS tune: When applying the tune, the tuner has a progress meter, and for the LMS tunes, it would go through three (3) blocks (erasing block 1 of 3, then writing block 1 of 3, erasing block 2 of 3, then writing block 2 of 3 finally erasing block 3 of 3, then writing block 3 of 3). But the stock tune has 16 blocks! And restoring the stock tune erases/writes all 16 blocks. I asked them about it and they responded: "The mention of only seeing a few BLKS writing when installing the tune versus pulling the stock read is to be expected, so no worries there. When it reads the stock tune it does a full file and when custom tunes are installed it only has to write the segments not the entire file"
@UrbanFree @onyxbfly Did you get any DTCs before the Spark Plug change? I have had the LMS tune for about 1.5 years now, no issues except unacceptable (to me) harsh shifts, even at low throttle, that they corrected by going back to "stock shift tune". Just got worried from your experiences and want to be pro-active to detect if anything might go wrong. My personal displeasure with them are mainly with the lack of "features" and updates. I have asked them several times to enable the current gear status which other tuners can enable, for which LMS claimed is not possible, and lack of updated tunes. I know they came up with V3 (for 2015-2018 models) but that was back in Nov. 2017. And the V3 tune is not available on 89 Tunes!.
You need to ask Ford that question. My guess is because of the much warmer weather here and that folks here assume crossovers are SUVs so they would still take them on sand dunes. Gen1: 2007-2010 Gen1.5: 2011-2014 Gen2: 2015-2018 Gen2.5: 2019-2021 1.5 & 2.5 are referred to as 0.5 updates because they are refreshed models with the same chassis & many shared components.
Now with ForScan 2.4.1 available, may I ask if anyone with a 2017-2018 Edge with the higher level Instrument Cluster (With 2 Screens & Speedo in the middle) if they can get the Firmware numbers? I want to try to flash the 2017/2018 Firmware to my 2016 Cluster. Below is a screenshot of my 2016 IPC, a similar screenshot for a 2017/2018 would be greatly appreciated as I would need to get the files manually, but without knowing the file numbers it would be impossible for me. Thanks in advance.
Ford's Owners Manual supplement for the Middle East specifies 20K miles for normal driving & 9K miles for severe duty.
AT&T's announcement of 3G shutdown was recent. I don't believe any other place outside of the US is shutting down 3G this early. I don't think there was any indication on the short longevity of 3G networks in the US when Ford up with its tech. But I do agree they should come up with replacement hardware for customers who want to continue.
Maybe the satifaction program was extended, especially considering the Covid-19 pandemic. But the fix was supposed to be the steering wheel itself, not the clockspring. Did they install a new steering wheel?
Yes. Engine cooling Fans have variable speeds. Fan speed is determined by the PCM based on several factors including coolant temp, outside temp & A/C compressor operation. -
mirror vanity lights
omar302 replied to mrmikesdeuce's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Check the below video, around the 1 minute mark. The 2015+ Edge is mostly similar. But note that replacing them with LEDs will make too white compared to the rest to the interior lights. -
The best available, in my opinion are the OBDlink adapters. EX for wired, MX+ for Bluetooth. EX has an extra benefit of support from ForScan team and a possible future ability to flash firmwares to Fords various modules. The MX+ is very capable and has the advantage of accessing OEM diagnostic codes and parameters for other brands as well (without additional cost). -
The dealer won't be able to add "Global Close". You can do it using ForScan using a compatible OBD2 adapter. -
It is not unusual to find information in the Owners Manual/Supplement that is not correct. The only shift light I've seen in the ST is when your close to redline the tachometer insert color turns red.
