Everything posted by omar302
Can Forscan enable showing the active gear?
omar302 replied to Jombi's topic in Accessories & Modifications
If you're planning to get a tune, I remember someone saying Torrie from Unleashed was able to do it with his tunes. LMS tunes does not. -
From this post on the 2GFusion forums, I was able to disable the feature where the HVAC blower speed would go to a low speed during a call on bluetooth. Also, at least on the latest build, ForScan already has this feature under FCIM. 7A7-01-04 x0xx (for my Edge, stock was "8", changed to "0" when disabled). -
The "mesh" part is actually "Miko" Suede leather. Don't remember anyone complaining of it's durability. I wouldn't worry about it.
They should give you corresponding part number for the rotor. From the part umber you'd be able to know which size you have. From here, it looks E1GZ-1125-F is 17" (smaller size) and K2GZ-1125-B is 18" (the bigger size). Also, if you register on http://www.etis.ford.com/, you can check with your VIN, Vehicle Summar, Minor Features, it should list something like "Brake Disc 18 Fr Vent/17 Sol Rear"
Unlike normal turn signal levers, the 2011-2014 Edge & 2011-2015 Explorers (and corresponding Lincoln models, maybe some years of the Taurus/MKS too, not sure) had a turn signal level that when pushing to signal would still return to the middle position (the lever would not remain up or down), but the signal would flash until a turn is made or the lever is moved again. That is why you have 2 settings for ABD for each number of flashes. This post from the F-150 Forum has better explanation.
- 9 replies
- abs
- traction control
Fluttering Noise from Undercarriage and Dashboad Rattle
omar302 replied to CCMAYES72's topic in Brakes, Chassis & Suspension
So the Ford recommended fix only lasted six months! That's not good.- 91 replies
- dash noise
- dash rattle
(and 4 more)
Although the 2011-2014 years have the same bolt pattern as 2007-2010 years, they have a different hub size. 2007-2010 uses 70.6mm 2011-2014 uses 63.4mm Not really direct bolt on.
Right side. Left side. They also Motorcraft. The Owners Manual states them as: WW-2755 (driver side) WW-2760 (passenger side)
LIncoln MKX to Ford Edge Instrument Cluster Swap
omar302 replied to onyxbfly's topic in Accessories & Modifications
@onyxbfly I tried to message you but seems you can't receive messages. Wanted to ask how did you get the Cluster programmed. Did you ship it to Dan or was it only a matter of ABD edits using ForScan?- 110 replies
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
? I'd like to have one screen with guages (round tachometer, fuel & temp) and the other for the balance scrollable information screens already available currently. Also, make the digital speedometer visible in a corner of the screen, with other selected information, instead of taking the whole screen. One more is to put a small distance to empty reading in the fuel gauge. I like my information to be always available. ? -
What makes this even sadder is that they have been using the same layout since 2011!! -
And the ST had a passenger with A/C and the cooled seats on ?.
From reading around, if your symptoms come after refueling, it might indicate a bad EVAP solenoid valve. This thread has some information on it.
For the 2015-2018 models with factory HID, the projector for the low beam (outer lights) has a shield that opens and closes for Low/High beam operation. Bi-Xenon is the more common name. In the inner lights there is an H15 bulb that is only wired for the DRL part. I came to know that the H15 bulb is a dual filament bulb designed for DRL and High beam operation, but the Edge only utilities the DRL part.
Summary of available LMS tunes for 2.7? and other questions...
omar302 replied to NoDTMF's topic in 2.7L EcoBoost
Anyone has news if there is any updated tune for the 2015-2018 Sport or is the V3 the last? I have sent LMS a request for update but still no answer. Also I asked if we can get the "Manual" mode disable by holding the "+" paddle for a few seconds like the newer models and current gear indicator in auto mode. Another thing I asked them, though got negative answer previously, is if it is possible to prevent 6th gear lockout in "Sport" mode as it really kills fuel economy or I have to keep shifting between "D" and "S" frequently. -
replied to your other post on this. Edit: Duplicate posts Merged.
Take it to the dealer? Since it is a 2017 I'd assume it is still under warranty. I had a similar issue in my previous vehicle, 2011 MKX, that some wind leaking noise come from the driver's side. Couldn't figure it out for several years until I took a chance and changed the driver's door window channel that finally fixed it because when pushing out on the window reduced the sound.
@Gadgetjq For for sharing. But like what @2FAST4U stated, even my 2016 had this from the factory, but I guess this is because I have factory HID and factory enabled DRL. Never the less, it is still very useful for those who don't have enabled from the factory. I have a suggestion/comment, instead using your Highbeams as DRLs and losing power with LEDs their, why not use the turn signals as your DRL? you already have switchbacks, so they will be white anyway.
The seat bottom controller can be used to raise/lower the whole seat or raise/lower the front part only. Try lowering the front part only by adjusting the front edge of the controller. Also if you have the 10-way seats you can raise the back part of the seat.
Welcome to the forums. Nice review. For hilly driving, did you try to put it in Sport? Press the S button in the shifter dial, it should hold gears more and even downshift as you brake. For the exhaust smell, turn on the circulate button so it doesn't get outside smells in. Also the HVAC would operate more effectively.
Hope it goes well. Keep us updated. I am really bored with stock cluster, been seeing it since 2012 and I hate the useless way the information displays are devided. With the round tacometer you can't get any other vehicle information.- 110 replies
- digital dash swap
- (and 3 more)
