omar302
    230
Everything posted by omar302
  1. As far as I know, only the Sport model has ANC it. It is also probably only for engine noise, to cancel out unwanted noises (frequencies) & to keep the better parts. Compared to the Escape, yes, the Edge is definitely quieter than the Escape, mostly due to the platform itself.
  2. Try to disconnect the car battery for ~10 minutes to reset the electronics and see if it helps.
  3. They have different part numbers, so they would be different.
  4. Is that confirmed? I have not seen mentioned in the articles I read.
  5. They should have changed the instrument panel. The one used has been on the Edge since 2011, only slightly changed.
  6. The 2011-2014 Edge has guide lines, but they are fixed. They don't move.
  7. Was it working fine previously? Is the check engine light on? Hood closed properly? Any body work done recently on the hood/front end? If all is OK, try the 2nd remote. I previously faced something close, turned out the flexible plate under the start button on the remote remote had moved & caused the button to get pressed a 2nd time.
  8. Most of 2015+ mods are different because the vehicle's systems have changed. I am not aware of any mod to enable the digital speedometer in 2011-2014 Edge. Changing the lane change's 3-flashes to 4, 5, 6 or 7 is possible on the 2011-2014 Edge.
  9. If you need a new APIM, consider upgrading to Sync3. Also Jason (jmr06) offers used APIMs for Sync2 & Sync3. www.fordpimods.com
  10. The Edge ST will replace the Edge Sport, my guess it that it'll be priced similarly. a 2018 Edge Sport tops at a hair under 50K before incentives, expect the ST to similar, maybe 1-2 grand more. Remember that the Edge ST is not a full ST model like the other ST vehicles.
  11. It might not be literally zero fuel, but close enough to get 0 L/100km in the instant fuel economy display.
  12. Yes, you are correct, Microsoft is not part of Sync 3. The listing is wrong, but still, it is made in China / Assembled in Mexico. You can see other listings.
  13. Update, disconnect the wire, or more accurately, ripped out the connecter as it didn't get out. Now no more Sunroof/Shade opening with Global (remote) Opening of the front windows. And with Global Open enabled, I have a useful feature to vent the heat out in the summer, close the windows & remote start.
  14. Thanks a lot. Yes that definitely helps. I'll try to get at it at the earliest.
  15. If you are up to changing As Built Data with ForScan, this might work:
  16. Sync 3 seems to be Made in China / Assembled in Mexico. No mention of Japan. eBay listing.
  17. Can I ask for help to locate the C210 connector and wiring route? I want to disconnect the Global Open feature from the Sunroof. The diagram I found shows the C210 connector, but not the location. I'd like to disconnect it if possible, or just to cut the wire if there is an easy access. 2011 MKX Edge Sunroof Wiring Diagram.pdf
  18. Chevy should hire him for one of their ads, "Real People, not actors"...
  19. There is actually a transparent sticky pad that is used to mount the rain sensor to the windshield. When removing the sensor it would probably get damaged & should be replaced. But, is you wiper acting up only when it is on the auto position? If it is acting up when the switch is off, then it has nothing to do with the rain sensor. This is what I mean with the pad: https://m.ebay.com/itm/201293056943
  20. Like what candurin stated, it is either the whole thing or just by the stickers. I did the stickers & it really looks good. Can easily be confused for it being factory. I remember posting photos but cannot find the post.
  21. What kind of vehicle awareness? I am not an expert, but this doesn't sound right. The camera(s?) is mounted on the windshield but shouldn't be affected by changing it. It's not like a new pair glasses that needs adjustment to. Makes me question whether they know what they're are doing.
  22. Having a 2015, first year of a major design, I'd suggest not to buy it. Also, you'd be stuck with MFT. Then again, it is all about the value & how good of a value you feel it is.
