omar302
    199
Everything posted by omar302
  1. Most of 2015+ mods are different because the vehicle's systems have changed. I am not aware of any mod to enable the digital speedometer in 2011-2014 Edge. Changing the lane change's 3-flashes to 4, 5, 6 or 7 is possible on the 2011-2014 Edge.
  2. If you need a new APIM, consider upgrading to Sync3. Also Jason (jmr06) offers used APIMs for Sync2 & Sync3. www.fordpimods.com
  3. The Edge ST will replace the Edge Sport, my guess it that it'll be priced similarly. a 2018 Edge Sport tops at a hair under 50K before incentives, expect the ST to similar, maybe 1-2 grand more. Remember that the Edge ST is not a full ST model like the other ST vehicles.
  4. It might not be literally zero fuel, but close enough to get 0 L/100km in the instant fuel economy display.
  5. Yes, you are correct, Microsoft is not part of Sync 3. The listing is wrong, but still, it is made in China / Assembled in Mexico. You can see other listings.
  6. Update, disconnect the wire, or more accurately, ripped out the connecter as it didn't get out. Now no more Sunroof/Shade opening with Global (remote) Opening of the front windows. And with Global Open enabled, I have a useful feature to vent the heat out in the summer, close the windows & remote start.
  7. Thanks a lot. Yes that definitely helps. I'll try to get at it at the earliest.
  8. If you are up to changing As Built Data with ForScan, this might work:
  9. Sync 3 seems to be Made in China / Assembled in Mexico. No mention of Japan. eBay listing.
  10. Can I ask for help to locate the C210 connector and wiring route? I want to disconnect the Global Open feature from the Sunroof. The diagram I found shows the C210 connector, but not the location. I'd like to disconnect it if possible, or just to cut the wire if there is an easy access. 2011 MKX Edge Sunroof Wiring Diagram.pdf
  11. Chevy should hire him for one of their ads, "Real People, not actors"...
  12. There is actually a transparent sticky pad that is used to mount the rain sensor to the windshield. When removing the sensor it would probably get damaged & should be replaced. But, is you wiper acting up only when it is on the auto position? If it is acting up when the switch is off, then it has nothing to do with the rain sensor. This is what I mean with the pad: https://m.ebay.com/itm/201293056943
  13. Like what candurin stated, it is either the whole thing or just by the stickers. I did the stickers & it really looks good. Can easily be confused for it being factory. I remember posting photos but cannot find the post.
  14. What kind of vehicle awareness? I am not an expert, but this doesn't sound right. The camera(s?) is mounted on the windshield but shouldn't be affected by changing it. It's not like a new pair glasses that needs adjustment to. Makes me question whether they know what they're are doing.
  15. Having a 2015, first year of a major design, I'd suggest not to buy it. Also, you'd be stuck with MFT. Then again, it is all about the value & how good of a value you feel it is.
  16. Van you see the edge of the glass if it is clearly laminated glass? I have not seen one myself (laminated vista roof) so I don't know if it looks like the front side windows where it is clear that they are 2 thin layers with a thinner insert between them.
  17. I remember reading somewhere that the 2016 Edge Vista roof switched to a "dual panel" type for sound insulation. Also, there is at least 1 revision to the the part number, Tasca Parts shows FT4Z-58500A18-C as the latest & that it replaces FT4Z-58500A18-A. So make sure you get the latest revision.
  18. Do you mean that with the LED working you don't get the hyperflashing but when it is out you do? That is interesting.
  19. Like what @Burrcold stated, only you see it. This is how we see it:
  20. Can they be checked without removing the rear bumper?
  21. Titanium. Otherwise her car will still be jealous from your car! Titanium is better, and the fact that she doesn't care for speed means the 2.0L Ecoboost is a better choice, should get a little better mileage. Also, just having memory seats is enough!
  22. omar302
    She’s dead :(
    Sorry to hear what happened. at least your fine. I'm also with chefduane, lower mileage is the way to go, especially with 40K difference. Then again, the lower mileage could have been abused & the higher mileage taken good care of (MacT style). May I also suggest an alternative, a 2013 MKX (example) is about the same price of the Edge Sport. Same 3.7L Engine, but with more features.
