omar302
    230
Everything posted by omar302
  1. You don't need the code. When you select the BCM module, there 2 choices, one with "As Built" & one without. Select the one without & you'll have settings for selecting DRL.
  2. On the topic of washer nozzles, any experience with the Dorman replacement? Is the spray pattern different from oem? I just hate how the oem spray high & hence don't get enough washer fluid at the bottom of the windshield at driver's side hence wipers doesn't clean good unless a lot of water is sprayed.
  3. ForScan seems to be able to program the OEM camera only. So your left with the dealer only. But if my memory serves me right, some members had the factory camera's image get upside which required a replacement to fix it. I'd recommend returning the camera & try another seller.
  4. Or they could have figured out a way to have both, power back AND flat folding. You know, innovate! I had the fold flat passenger seat on the 08 Taurus, and it was useful, but having passenger seat bottom that goes up/down is more useful!.
  5. The Focus has always been Euro inspired & the 2013 Fusion had the European Mondeo in mind.
  6. This was added in 2015. For older models it's old school, have to unlock the door for the door handle to work.
  7. Can't say if it correct or not, but I recommend check-in the 2016+ Explorer sheets. Especially the IPC of the non-Platinum model is closer to the 2015+ Edge than the F150. This is one sheet I saw: https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2011-2018_Explorers And another: https://docs.google.com/spreadsheets/d/1JHLK2oCBe-E5om9VNeY6e3NwboO9Em0dDBZIgUVyGxc/edit#gid=0
  8. Are the front clips broken? If, yes and the motor still works, I'd open it slightly and get get help from 2 persons (total 3) one would press the close button while the other 2 push the glass panel from the back, one on each side simultaneously. Hope it works for you.
  9. Tried to do a master reset of the MFT? If that doesn't work, try a cattery disconnect, if that also doesn't work, try a re-calibration using ForScan. Try to toggle the setting after each try. If non-work, you might need a new camera.
  10. There are no known issues, I believe the only issues used to come when the phoned had software updates, then they'd be corrected. But no issues now.
  11. As far as I know, Ford vehicles for a long time do not have horizontal adjustment. Let your dealer check it out.
  12. Yours has a 3.7L naturally aspirated engine. They are talking about the 2015+ Edge Sport with the 2.7L EcoBoost Engine (Twin Turbocharged). So the numbers aren't the same.
  13. I know the stock engine idle speed is 600 RPM, but I also remember reading somewhere (can't find it now) that with the Tow Package the idle speed was 640 RPM. I have a 2011 MKX with the factory towing package & with checking recently with ForScan it seems that my idle speed is set at 600 RPM. The desired speed is 600 and actual hovers around 600, but definitely not 640. Can someone that has the Tow Package confirm what their Edge/MKX has? Thanks. This is a screenshot from ForScan, at the bottom, RPMDSD is the desired RPM. Edit: Found the spec sheet that showed the idle speeds, attached. 2011_MKX_Specs.pdf
  14. Seems to be the mat for the area under the console, the gap/pass through under the shift lever. It is part #20 here.
  15. Replacement filters for the previous years have shifted to so called lifetime filters (no filter in reality). The same basic design is applicable to older & new Fords, the seatback cooling/heating device is confined to a limited space which eventually gets filled with hot exhaust air and thus cooling becomes non-existing. I think the main difference between the old cars & newer ones is the the seatbacks are now much thinner, amplifying the same issue. In my MKX, the seatback cooling is barely noticeable, especially compared to the seatbottom (which is open from the bottom towards the floor).
  16. The only solution that I know of to upgrade the existing system (the 8" MyFord Touch) is to go for a Sync 3 unit. This will give you Android Auto. But I do not know of, or heard of, any aftermarket replacement system to the stock 8" system.
  17. As far as I know, they added it from the factory in 2013 models & above. Also there was an extended warranty up-to 10 or 200k km for 1 replacement at which time the replacement would have the drain plug. Edit: it is 190k km. Here is the thread about it: http://www.fordedgeforum.com/topic/13533-13m01-middle-east-ptu-extended-warranty/
  18. Maybe because that specific update can only be done by special equipment that is available at a dealer?
  19. Rear defrost (with the heated mirrors) & heated/cooled seats always default to off after turning off the ignition.
  20. A camera image at night is not a good way to judge lighting performance or differences unless you use the exact same manual (exposure?) settings. With auto, the camera will adjust based on available light.
  21. There is no separate setting for the heated mirrors. At least none that I know of.
  22. Does the rear defrost turn on? The mirror heaters are tied to the rear defrost. What might be the issue is that the mirror heaters don't get power with remote start.
  23. Though I do agree that the double honk is very annoying, and would definitely disable it without question, Akirby's suggestion works by closing the door to the first latch (not fully closed) so the door would be locked, but not fully closed.
