Ummmm, yes and no. What are you basing your remarks on? I've never seen any real staticists regarding what percentage of Ford and Lincoln PTU units have actually failed. (2%, 5%, 10%, 25%, 50%?) Do you know of a website that posts real numbers? I would be interested in knowing. That said, older PTU units are a source of concern. Maintaining the unit "should" extend its life. I have just over 100k and never had a problem. Had the fluid changed once & service found the seal leaking and had it replaced. Service technician told me, he thought that once the seal starts to leak, the unit looses its lubricant and what's left gets gummy and fails to lubricate the gears and bearings properly. Then it fails. But all things considered, it's still only designed to last the life of the car, which is conversely the "life of the warranty".
Wonder if one were to use helium, would that make the tires sing a higher pitch? -
Interesting website discussing the advantages and disadvantages of using nitrogen in tires. (Test results, studies, etc.) Spoiler: not worth the cost unless your driving a race car or preserving and classic for years and doesn't get driven much. http://www.tirebuyer.com/education/nitrogen-vs-air -
I ran across some idiot who had one of these light bars' on his car last week. Although he had his dims on, the light bar blinded me. It was pointed straight ahead on the car ( not aimed down) and was extremely bright. I flashed twice then just threw my brights on (figured if he was going to blind me, I would return the favor). Called the sheriff's office and was told that here in Indiana running with these lights is illegal (exceeds max allow light output).
- 24 replies
The owners manual for my 2009 MKX is 12 oz.
After Market Adaptive Cruise Control
enigma-2 replied to davidceder's topic in Accessories & Modifications
Ahhh, I miss ribs at the Haunted Hamburger in Jerome. Best rims in the west. -
For oil filter, Motorcraft is at the top on Bobistheoilguy.com. (He has tested all of the filters.) For gas additives, I use Chevron 65740 Techron Concentrate Plus Fuel System Cleaner. If you use gasoline with Ethanol in it, remember that it starts to break down in as little as 30 days in hot weather. And it draws water to itself, accumulating in the tank. In winter it can separate and freeze. Best to throw in a can of Heet in the late fall to get rid of ant water in the tank. Techron. https://www.amazon.com/dp/B00092893E/ref=cm_sw_r_other_apap_b2plmdZ83K4NR For oil, I have my oil changes done by my local Ford-Lincoln dealer. Use the $30 service which the includes synthetic blend, rotate tires and look over. The synthetic blend is more than adaquate. Personally I would bump up to full synthetic is my engine was a turbo do to the increased heat. (My car has a 3.5).
- 15 replies
- ecoboost 2.0l
- fuel additives
This service repairs your existing radio http://m.ebay.com/itm/152426688204?_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20150313114020&meid=438a278505f1474da7adcd24be3d8a09&pid=100338&rk=9&rkt=30&sd=301940286504&_trksid=p2141725.c100338.m3726&_mwBanner=1 Probably would be better off going to an aftermarket unit and get all the latest features such as Apple Carplay, navigation, bluetooth, etc. http://www.connectedcarlife.com/upgrade-your-car-with-today-s-technology Crutchfield has a lot of good information on adapting aftermarket units, amps and speakers to the Edge: https://www.crutchfield.com/S-AkrtVdhvrln/carsystems/Ford-Edge-Stereos-and-Speakers.html If your looking to add bluetooth to your existing system, try here: http://www.installer.com/cars/by_car.php?carid=6417 As for adapting an 2009 head unit, probably would get too involved and for the money you would probably be better off going with a good Pioneer unit.
enigma-2 replied to jmr061's topic in Audio, Backup, Navigation & SYNC
I have it in my 09 MKX.(Added) Checked and it's vs. 2.1.4. Sorry, was thinking it was vs. 1.x.x -
2014 Edge Defrost System Problem
enigma-2 replied to Beerfoot's topic in Interior, A.C., Heat, Interior Trim
Crud can build up in the hvac drain and clog it. Been discussed before, easy fix. See this previous post: http://www.fordedgeforum.com/topic/21053-clogged-air-conditioning/?fromsearch=1 -
Could be as WWW stated or a bad CV joint. A CV joint will click and grind while turning at low speed (quiet when going straight) and a sway bushing will thud or clunk. Look under the car at your CV joint boots to see if either is cut or cracked.
What are you trying to achieve with aftermarket oarts? What was it about OEM struts and sway bars that you didn't like?
My guess it's sticking to the inside walls and parts. You try sucking out the old goo and refilling?
There is no easy answer as to whether these will fit or not. (By "not", they will fit, bit it may throw off the offset by a certain amount. Whether this will affect the drivability or not is the question). You may find the following link informative "Everything you ever wanted to know about wheel spacers." https://www.bimmerforums.com/forum/showthread.php?1364210-Everything-You-Ever-Wanted-To-Know-About-Wheel-Spacers Here's a link to understanding offset: http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
Would an emblem like these work for you? https://www.realtruck.com/defenderworx-billet-tailgate-emblems/R184832P2016Y203MA.html
What tores are on your car?
Some other thoughts, mounting hardware, a/c belt getting old - wobbles when the extra load of a/c engages. Idler pulley bearings.
I don't think it was covered under the federal requirements. https://www.epa.gov/air-pollution-transportation/frequent-questions-epas-office-transportation-and-air-quality
Good you caught it under warranty. Does the new unit have a drain plug?
Varies with location. KBB stares the fair market price is $38,639 base in my area. Need to check price in your area. Also considerations on price include FWD,AWD, engine, paint color, option, and availability. https://www.kbb.com/ford/edge/2016/sport/?vehicleid=414920&intent=buy-new Look at what's bring offered in your area and offer $1000 less. One dealer may have a fat invent and be looking for a way to move product. Another down the street is sitting ok and is not movitated.
No Red Illumination on AC "My Temp" (+) Button & Tight Volume Dial
enigma-2 replied to Mister-Edge's topic in 2011 Edge & MKX
usually all of the interior back lighting is on one fuse. -
https://youtu.be/ku9cy0oqrK8. <snort>
Popular Mechanics how to break in a new car engine: http://www.popularmechanics.com/cars/how-to/a3113/how-to-break-in-a-new-car/
I remember reading about the fuel aspect years ago, but I think your right about the Firestone (Eagle wasn't it) tire problem. Forgot all about that, lot of people were killed because of low tire pressure. Caused a big hullabaloo in congress. And yes, it applies to all vehicles (under 10,000 GVWR if I remember correctly).
