2FAST4U
    8
Everything posted by 2FAST4U
  1. My girlfriend just bought herself a 2014 Mustang GT and I saw that pipe on the tube for the air intake system running back to some kind of valve…but I didn't see it going through the firewall… Maybe it's me who didn't look close enough I dunno, but the car is all original and isn't very loud… I wonder what would happen if I disconnected it?…would it be louder or quieter? and Does that mean that if it wasn't for that "noise cancellation system" that the vehicle would actually be louder ? Anyways, I find this a little "gimmicky"… Claude.
  2. Are you saying that the engine's sound comes inside the cabin through the speakers?? …If yes, then WHY??? What's the use for this?? and So no more V6's at all?... No option either? (except for the ST)?... Claude.
  3. Yes. Only the Sport and Titanium have the center bar that lights up. Also, they have different taillights to match the lighting pattern of the center bar. When not lit they look the same but when turned on, only the contour lights up and when using the turn signals, the taillights on the Titanium and Sport models flash in yellow as opposed to the SEL which lights up in red. Hope this helps in clarifying things up a bit... Claude.
  4. They should be a direct fit, no adapters needed. Claude.
  5. Yep!…Very disappointed that it'll be only available with a 4 cyl. engine… …So glad I have the V6 in mine! Claude.
  6. I have a '16 Titanium with the 3.5 engine and I don't remember if it has the paddle shifters or not… I don't really care as I've never felt any need for them… I put it on "drive" and just do that… DRIVE. Claude.
  7. Starting with the 2015 model year, the bolt pattern on the Edge changed from 5 X 114.3 to 5 x 108 Claude.
  8. To my knowledge, they come with the wheel, not sold separately… Claude.
  9. Rick, consider yourself lucky. A lot of Ford vehicle owners are very annoyed by that "double honk" and have to have someone turn it off by using a laptop with the Forscan program…. You got it for free! Claude.
  10. Go to your Ford dealer. I bought 4 of them for my "summer" wheels and they were about $45.~ $50. each. Claude.
  11. --> To answer your question, YES they will fit…. and again YES the wheel wells are the same. How do I know? Because I did it on my girlfriend's 2011 MKX (which has the same wheel wells as an Edge. Good luck, Claude.
  12. I have a '16 Edge Titanium and I bought a Huawei P10 android phone three months ago and it connects immediately to the SYNC as soon as I start the car… Works fine. Claude.
  13. You have your answer right there… so NO they won't fit. Ford changed the bolt pattern starting with the 2015 model year…. Claude.
  14. "too long"?? …Funny 'cause I find this not long enough…in fact, I want mine to stay ON ALL THE TIME!… I have a friend who has the Forscan program and he will be changing the settings so it always stays "on". That way, my cell phone will be charging when I'll leave it in the car. Claude.
  15. Mmmm… sorry but NO. I prefer the original grille…but that's ME. Claude
  16. I don't think it would look ok…because the width of the side black plastic pieces is wider than the one on the "sport" model's rear bumper… One solution to that would be to remove your pieces from your doors and have them painted the body color…Bingo! Claude.
  17. Thanks for your reply… Is your Edge an "SEL" model?… If yes, then could it be the reason why you didn't have the buttons on the home screen?.. Mine is also a Canadian model but a "Titanium" and the heated steering wheel and heated seats controls are accessible from the home screen… I doubt that you can have access to the heated steering wheel controls through the cluster though… (I've already had the "Climate" controls enabled by my friend "cv27")... Thanks, Claude.
  18. In the list from the link you posted, I have a question: On the 11th line, it says "Heated Seat AND Heated Steering Wheel icons on home & climate screen "…aren't they already there from the factory?… I can already access the heated seats and steering wheel on the big screen but what difference does this specific code makes? Thank you, Claude.
  19. Yes…I'd like the codes to "enable climate section on right cluster"... Thank you, Claude.
  20. Dirt does accumulate at the bottom of the doors on mine too but like you, I wash it off and wipe it dry every time I wash the car I guess it pays off because I have a 2016 (2 years old now) live in Canada and don't have a single spot of rust anywhere on my vehicle. Rust will form if you allow the dirt to accumulate get moist and leave it there…but nothing beats prevention like a yearly spraying with an oil-based antirust product. Claude.
  21. Thanks to my friend Claude ("cv27" on this site) my horn's double honk is now disabled! He also turned on the "Average Speed" display function as well as making the lane changing signal feature flash 6 times intead of 3... Thank you my friend, I appreciate! Claude.
  22. I took the habit of always flushing this area off every time I wash my Edge… Problem solved. Claude.
