omar302
    197
Everything posted by omar302
  1. Ford should make a 2-row version of the Explorer to replace the Edge. Would be RWD based, add more sales volume to the Explorer nameplate and the ST version would be better than the Edge ST.
  2. Impressive time. Seems the transmission was taking its time to shift. You would probably get a much better time with performance shift tune, though I personally did not like it and kept the stock shift tune for every day drivability. Did the tranny also shift 2-3 before 60? I was under the impression it shifted after 60. No wonder the 2019-2020 ST was slower if it had to shift 1>2>3>4 given the extra 2nd compared to the 2015-2015 Sport and shorted final drive ration (3.65 vs. 3.16).
  3. I recently found that there is a Ford Performance part (M-1012-M - link) that includes 5 lug nuts for the Mustang (which has the same lug nuts as the 2015+ Edge) for a retail price of USD 15. Searching online I find it for even less (eBay listing for 4 sets - Levittown Ford Parts). Making each lug cost nearly half as much as buying them individually. I ordered the set from the eBay listing and will update once received & installed to confirm. I had previously installed black lug nuts from Veritek (link to thread about them) however they quickly started to show rust after a few wheel removals/installations.
  4. 2016-2018 look the same but the 2019 was a refresh, updates front/rear styling, 8-speed auto transmission, rotary dialer. The newer the model you get the better in my opinion.
  5. On newer models unfortunately there is no "Gallons used" in the trip info and I haven't seen any way of enabling it, even though the info is available in Engineering mode (link to how to enter Engineering Mode). For the fuel consumption (mpg) inaccuracy, there is a workaround detailed in this post:
  6. I'll just link this post here for anyone with a 2015+ Edge interested in upgrading their cluster.
  7. It is very expensive, however I have doubts on their claims as the images/videos they show appear to be for the stock 10" display from the MKX/MKZ (already being retrofitted to Fusions/Edges) with a modified inner mask (under the lens) and firmware already available. See below video sample. Also, not sure they will be able to get that same cluster to work on older vehicles (2011-2014 Edge, 2011-2015 Explorer, pre 2013 Fusion) due to the different vehicle electrical architectures.
  8. Thanks @Haz for your usual detailed reply. Reading you reply had me wondering what the evaporator assembly housing looks like (P/N: K2GZ-19B555-BG), so I found a few on sale on eBay (example 1, example 2) and it sure seems there is a drain location built into the assembly housing, just apparently it would drain directly without going through a "drain pipe or hose", hence the no-part available for it. Also from the pictures it seems to be located below the heater inlet/outlet pipes. Have attached photos with arrows pointing to where I think it is. Will try to search again in below the heater pipes. My doubt is that the water drips on to the exhaust/catalyst heat shield, then is absorbed in to it and evaporates before dripping. The P/N of the housing is the same for 2015-2021 Edge and 2016-2020 MKX/Nautilus. Can anyone confirm if their Edge/MKX/Nautilus from those years drips water from the A/C?
  9. As per my understanding, the recall is to replace the bushing with a new one made of a different material and install a protective cap so it does not deteriorate and cause the roll away risk. So they will replace the bushing under this recall if if the current one is not currently damaged.
  10. I don't have experience, however this PDF (same one from my post above) has photos of the procedure. Just need to remove the intake air filter box.
  11. Does the Gen2 Edge have an A/C water Drain location? I don't see water dripping even though it is quite humid nowadays. Also couldn't find a drain pipe looking under the vehicle. I want to check for blockage as I am getting a slight mildew smell sometimes when the A/C starts blowing, however all the carpet inside is dry. My other car, the MKS, drips large puddles of water, as does most vehicles I see on the road.
  12. Did you drive the vehicle? if not, drive it for 10 minutes or so to see if it fixes it. Also try disconnecting the battery for a few minutes.
  13. Did the vehicle read the sensors automatically and show correct tire pressures or was there a procedure performed?
  14. Hi Haz, I was surfing on NHTSA site and found the letter dated July 5th, 2022 to dealer (link). However, the part numbers in Attachment II of the letter are gibberish. Where the Part Numbers released?
  15. This is for my 2016 Edge Sport: From Motorcraft ABD site: From ForScan (also abt file attached): 2FMPK4AP9GBB98478_PCM_20220310_144949.abt
  16. This is for my 2016 Edge Sport: From Motorcraft ABD site: From ForScan:
  17. I understand this and have not read anything to the contrary, however, in my testing it seems the Edge will "Auto learn" the tire positions. I previously made a short video showing it. Link to post.
  18. The liftgate will always open with the fob. To test if it is locked, lock the doors and keep the fob away from the vehicle, few meters away, the try to open the liftgate with button above the license plate, it should not open if it is locked.
  19. I don't think it is easy to determine which size you have by description only. If you want to confirm which size online, your best bet, in my opinion, is to check with a seller who will confirm if the rotors you intend to purchase are a correct fit by VIN.
  20. 22 Edge has Sync 4A, I don't believe adding NAV is similar to Sync 3, at lease have not seen it done yet. However, Sync 4A should have Android Auto and Apple Car Play, they should be even better than the factory NAV.
  21. I remember when people complained when it DID reset. Mine was like that until a Firmware update to the FCIM made the heated and cooled seats remember the last position. Seems it is a feature not liked by all. They should make it user selectable.
  22. Probably a software bug. Something similar happened several years ago when ambient lights would revert to the default color every few days, the fix was a software update to the then MyFord Touch (Sync 2) center screen. It is better to report it so that Ford becomes aware of it.
