Everything posted by omar302
Front & rear door trim panel removal procedures for the 2015 Edge are attached. I believe the 2017 should be identical. Front Door Trim Panel.pdf Rear Door Trim Panel.pdf
The noise is certainly strange, but if it is leaking vacuum then the booster needs replacement. There is an extended warranty on it for a one time replacement. www.fordedgeforum.com/topic/13888-13n02-extended-warranty-coverage-on-brake-booster/
128 GB is not much nowadays, you need 1 Tera or more. For the USB-2, shouldn't old drives still work on USB-3 ports since they are backwards compatible? Maybe you meant USB-C? Even for that you can get an adapter. Maybe what I'm trying to say is don't let the USB ports limit your options.
HID Bulb Replacement Cost
omar302 replied to CMOS's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
If the Edge is like the 2011-2015 MKX, which I expect is, then the HID bulbs can be replaced without removing the headlight assembly. Just like what tamugrad2013 stated above, unscrew the cap, disconnect the cable, then twist the HID bulb (counterclockwise?) to remove it. 2011's, if like my old 2011 MKX the bulb size is D3S and had the old OSRAM 66340. In 2012 or 2013 they started using an improved (slightly) model, HBI. Also as tamugrad2013 stated above, the CBI are much better, but there are now even more option. From OSRAM you also have the HBB. From Philips there are the Xenon X-tremeVision gen2 and Xenon Whitevision gen2. Too many options. But if you are just looking for cheap replacements, you can get these for example for cheap. -
The below procedure worked on my 2016 Edge. I would only add that I had initially over inflated the tires by ~5 psi and drove it for a few minutes to make sure the sensors were not in sleep mode.
Never read of anyone attempting it. It probably will not be easy, if possible. Will require added hardware (sensors & module obviously, and wiring) and software programming to enable them to work with the vehicle systems.
May I ask, how do you get the boost reading? A dedicated gauge or through a connected device? I'm asking because in ForScan I can see 21 psi boost with stock everything and at partial throttle, try to get the reading at WOT.
I was answering akirby on the Platinum membership that it works. It's actually a platinum theme. It looks just like the regular theme only add are removed in the full web version of the forum.
Platinum membership for me enables a premium theme on the desktop that removes all ads. So it does work in one way at least.
New to a 2012 SEL, 3.5l, need to tow.
omar302 replied to ORradtech's topic in Cargo, Hauling, Roof Racks & Towing
You can check on www.etis.ford.com for the features included in your build. It will mention class II tow package if it is included. As for parts, probably only what you listed us different, though I think the trans cooler is part of the condenser and is the same for both, tow & non-tow. But, sometimes there is more than what is advertised, for example the MKX (the Edge's mechanical twin) gets a larger opening behind the grille to allow more airflow when equipped with the tow package. Also, the engine tuning is different, I know with tow package you also get trailer sway control and I believe a higher engine idle speed (650 Vs 600 rpm). -
Ford 2016 AWD Titanium with 20" wheels + 18" spare tire
omar302 replied to t0lkman's topic in 2016 Edge & MKX
As far as I know, the same spare is for all trims, but in the parts list there seems to be a steel & aluminum spare wheel. I don't know on what basis which is included in any trim, that is if they are even supplied differently as it could be a parts list thing and/or market dependant. My 16 Sport has the steel spare. -
Highway mpg will differ a lot as speed increases. Someone driving 65-75 mph will easily see better economy than another driving 75-85.
The Edge has a normal brake system. Do you wear shoes that have deep groves in their soles (tread?)? I notice the same thing which is due to the horizontal rubber strips on the "aluminum" pedal surface. Seems that the shoes grabs it. Wearing different shoes with flat(ter) bottom makes braking normal.
I meant what was the miles per gallon (mpg) or km per liter (km/l) or liters per 100 km (l/100km).
So what was the mileage for the trip?
Ford Edge 2013 SEL Cargo Security Shade
omar302 replied to peaje's topic in Cargo, Hauling, Roof Racks & Towing
This is not an OEM cover. Also this only fits an Edge without the power liftgate that raises and closes the liftgate electrically. -
This link is for the part. I couldn't find the procedure for removing it, the speaker grille can be pried off & the speaker has 2 bolts (procedure attached). But looking at the parts diagram, there are clips for the cover, so it might just pry off (probably after removing the speaker). Instrument Panel Center Speaker.pdf
- 1 reply
- 2
Yes. The Spare has a different tire that is for temporary use only and max speed of 50 mph (if I remember correctly). AWD will probably disconnect when using the spare & you should revert to the original wheel/tire as soon as possible. It is mentioned in the Owenr's manual, though not in a clear section. It is under the information messages, All Wheel Drive. -
Procedure for removing the seat back blower is attached which of course goes into removing the seat cover. I believe if you are attempting to install the seat cooling fix, you wouldn't have to go all the way. Post pictures and details while doing it. My Edge already has the sock from the factory & was wondering how hard & how effective it would be to install the exhaust side of the fix. Front Seat Backrest Blower Motor.pdf
On older models (maybe the new ones too based on the market), there was no sensor for the PTU temperature. So no way AWD will disconnect due to PTU temperature. And yes, the owner's manual does state that AWD will turn off due to high tempreture, but I believe it would disconnect due to the coupling itself overheating as the Edge has the AWD coupling as part of the rear differential (RDU) and it is responsible for connecting the rear wheels & managing how much torque is sent to the rear.
For the 2007-2014, there is an OEM cover (non-retractable). This thread has some photos. -
Ford Adaptive Cruise Control Explained
omar302 replied to blitz118's topic in 2015+ Edge & MKX Generation II
I understand how ACC could help, but the test in the video is not really good. First, now we how with no ACC the cars are following with very small gaps. Second, even with the "phantom" traffic (no ACC) the last car still cleared the way before the other test with ACC. So ACC came out as a convenient feature rather than traffic reducer, which it is. -
Dual Climate Control Repair
omar302 replied to finzup's topic in Interior, A.C., Heat, Interior Trim
I believe this is what you want, left side (driver):https://www.tascaparts.com/oem-parts/ford-mode-motor-7t4z19e616b/?c=Zz1odmFjJnM9ZXZhcG9yYXRvci1jb21wb25lbnRzJmk9TVcwNzExMDUmcj0xMiZhPWZvcmQmbz1lZGdlJnk9MjAxMiZ0PWxpbWl0ZWQmZT0zLTVsLXY2LWdhcw%3D%3D -
With my Edge Sport (Middle East - Hot Market version) there is a PTU oil change interval recommendation by Ford, 9K or 20K miles based on operating conditions (attached). Also, there is a PTU temperature sensor and I can get the reading through ForScan. But I do not know what would happen if the temperature goes high, a light in the gauges or warning message? I don't know. This article about the Police Interceptor Utility (Explorer) has a section about the PTU, and it seems there might be a warning message:
Congratulations. Hope you enjoy the ride and welcome to the forums.
