omar302
    230
Everything posted by omar302
  1. This is from IIHS ratings for the 2017 Lincoln MKX: Factory LED: Factory HID: This case is similar for many other cars, factory HID illuminates more than factory LED. Edit: Direct comparison:
  2. Even if the doors are already unlocked, you'll still hear them clicking when you unlock again.
  3. I think they added this indicator half through the 2013 model year Edge. I have not seen any mod to add it for 2011-2012 models. Edit: A thread about it. Apparently early 2013 build also did not have it.
  4. Are you sure it will lock the car? It should not.
  5. For example, in the middle east, Ford advertises it on their website. Though, we know that navigation maps here are ALWAYS old!
  6. I still didn't get why you removed it? Only for the increased noise? That doesn't sound like you. I guess your next video will be on how to change the brake light bulbs, Blueberry right top bulb is out (seen @ 17:52). Also, maybe you already know this, but with ForScan you can monitor the individual tire pressures as reported by the TPMS through the BCM.
  7. Does it read MS-CAN? I didn't see this on the description page.
  8. They did implement engine auto turn-off after ~45 minutes of idling.
  9. The real solution to the double honk is to just use a soft beeper, mmm..., like most other car manufacturers. You get both, a reminder AND not be annoying to others around you. Nissan for example has been doing from 10 years. Also, take into consideration that Ford only added this feature midway through 2012, all 2010 & 2011 Ford & Lincoln vehicles with IA key did not have the double honk, how many complaints where there of people forgetting their keys? None that I have seen in any Forum I follow. Never did I also see anyone with a 2011/2012 trying to enable this feature.
  10. You should get an OBD2 scanner to read the codes. It will pay for itself. Also, if the wheels were submerged by water, it is highly recommended (maybe necessary even) to change the PTU & rear diff oils ASAP. Also expect your wheel bearings to wear out much quicker.
  11. The MKX's hood looks shorter, the Edge's seems to have a longer downward curve at the end where it meets the grille.
  12. There should be a "write all" at the bottom, this should do it in case there is no write button at specific lines.
  13. No. They have different part numbers, so they are different. 2007 MKX 2007 Edge
  14. No. They have different part numbers, so they are different. 2007 MKX 2007 Edge
  15. Just take it back to the dealer & tell them the wipers are not working properly. Don't point to the broken motor, let them just fix it.
  16. If the traction light came on briefly, then it might have been the stability control system engaging, which uses the ABS to modulates individual wheel brakes to prevent or reduce a skid. It would also make sense since you were turning.
  17. The iPhone X will also have the usual port at the bottom. https://www.apple.com/iphone-x/specs/ See it under external buttons & connectors.
  18. Yes, the glass fits. There was a very long thread on it. As for the housing, they probably interchange, but you need to check if the wiring is there for the puddle lamps.
  19. If I don't lock the vehicle from the outside (remote, keypad or IA), the displays remains on for quite some time. As for the battery dying after a week or so, the 1st question will be how old is the battery?
  20. Using ForScan with a compatible adapter you can re-program the camera yourself.
  21. Yes lildisco, your right. B not A. I edited my post accordingly.
  22. Looking at the price difference, w/level 2 trim part ending with "B" is the lighted one. https://www.tascaparts.com/auto-parts/2016/ford/edge/titanium-trim/3-5l-v6-gas-engine/electrical-cat/reflector-scat
  23. This link is for a 2013, for some reason the 2012 is not appearing, but the 2013 mirrors should be similar to 2012.
  24. If I remember correctly, only the filter cover & tube, not the whole Air filter box, maybe only the tube from the throttle body end. Are you using Internet Explorer? I remember facing the same issue on Internet Explorer, now i'm using Chrome & all is good.
  25. How about take a video of it & show it to the dealer.
