enigma-2
    303
  1. After reading the Ford coverage again, I see that it was extended to five years from initial service date. So I imagine it did end in 2017. Even though you still have to pay, there is still one good point it makes. And that is to make certain you are running the latest update. As it's not currently working, I would imagine the dealer will need to do it. The Ford letter required the dealers to check the software (latest or reload) prior to going further.
  2. Before you install the engine, I would recommend changing the water pump, guides, timing chain, spark plugs, PVC, and anything else you can think of prior to placing it in the engine bay. These engines are "good-used", not rebuilt. Who knows what parts are good now only to fail in 5k? And while it's out, how about the TSS & OSS in the transmission? Easy to get to now.
  3. Hi Edward, this site has an article and pictures describing the spark plug seals and offer more info on their replacment. It's on a 2009 Ford Flex, but same 3.5L engine. https://www.fordflex.net/forums/viewtopic.php?t=7809
  4. Try shifting the gear shift through all the gear positions, and then back to park. Just the see if you have the dreaded shifter not recognizing park position. I was thinking that it was the shifting into neutral that allowed the NSS to engage and not that pushing it backwards had anything to do with it.
  5. Fweeeeeeettttt. Foul, you can only have ONE hate. Rules are rules.
  6. If your certain that the Accessory Protocol Interface Module is at fault, I'd talk to your dealer first. There's an extended warranty on your year's Edge. https://ford.oemdtc.com/1745/12m02-warranty-extension-covering-accessory-protocol-interface-module-apim-software-and-hardware-2011-2014-ford-lincoln .
  7. Everything I've read says stay with Motorcraft. One point, if you do change, do a triple flush. Never leave any of the old coolant as they don't play nice together and can even turn to goo and clog your heater core and do other nasty stuff. Another thing to consider, if you ever have a warranty claim (extended in our case), and they find a different coolant than what's registered for the car, it's up to you to prove that complies with Ford specifications.
  8. Can't say about the durability, made of leather and they have a rug-type insert, that's removable. Personally I don't think they're practical for winter areas with all our salt slush and the link. Rain shouldn't bother them, if you periodically pulled out the inserts and cleaned them. They're meant to be used as a luxery accessory in a luxury car. And honestly, they WOULD impress anyone who got into your car for the first time. Not something a person could easily ignore - handmade floor liners ..... !!!
  9. I use something similar to ones in the link below. They fold into a circular shape approximately 22" Diameter and unfolds into a rectangle. Takes two to fill the windshield. Works well enough and stores easily. https://www.amazon.com/dp/B018ERRLU2/ref=cm_sw_r_cp_apa_aZwjBbBG9K80G I've also used an exterior cover simular to the one below. Fastens easily, locks in place when you close the doors and blocks the sunlight BEFORE it enters the windshield. 2-sided, black for winter, (only really useful as an ice shield) aluminum for reflecting summer sun's infrared rays before they pass through the windshield. https://www.amazon.com/dp/B01AOHYT50/ref=cm_sw_r_cp_apa_r9wjBbBVJFSS7
  10. So you say you want the best? http://www.manicci.com/product/manicci-luxury-custom-fitted-auto-mats-dark-brown-diamond-free-delivery/
  11. I'm curious, what feature, design or function, do you hate most? Not a long laundry list, just the absolutely one thing the Ford or Lincoln should have (or not have) done differently. As Im still driving a 2009 MKX, I'll start. My biggest urk is not including a rear-view backup camera on domestic vehicles (the Japanese version appearently had the camera). And additionally, not offering a aftermarket kit to add one.
  12. As it's extensive, consider purchasing a service manual off Ebay. Money well spent on such an important undertaking. Example: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F372292377918 or https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F113045533851 For the complete set.
  13. Told me they use the same machine to change the lubricant in the PTU as they use for differentials. Apparently it can both suck out the old and pump in the new. note: he made me feel as if it was a common piece of equipment in any Ford service shop.
  14. I had this with mine, they replaced the brake booster, helped a little, but still near floor. Strange enough, took it in for an oil change about 3-4 months later, casually mentioned about the pedal going to floor (but not requesting service) and when I got the car back, had a high, stiff pedal. Thought about turning around and going back to ask what the technician did, but didn't. Whatever he did, it didn't take any real time and nothing on the service sheet to indicate what he did. Had the brake fluid changed at the same time I had brakes put on the front. I always suspected that there was air in the lines. That really helped. Still not what I've experienced with previous cars, but acceptable.
  15. Plenty of people that converted to LED bulbs. I personally haven't seen any that's worth buying..... yet. Found it interesting that he replaced the entire headlight assembly in his Lexus.
  16. Meguiar's G17804 Keep Clear Headlight Coating, 4 oz. $8.44https://www.amazon.com/gp/product/B01M4RVVX6/ref=as_li_tl?ie=UTF8&tag=scottykilmerc-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B01M4RVVX6&linkId=c4bc4701eb2fada65a84bfb28cbd0698 Meguiar's G12310 PlastX Clear Plastic Cleaner & Polish - 10 oz. $6.47https://www.amazon.com/gp/product/B0000AY3SR/ref=as_li_tl?ie=UTF8&tag=scottykilmerc-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B0000AY3SR&linkId=189d90e6c4346eb1a8b8abab623734e5 Scotty Kilmer's video. If Scotty recommends this products, they should be good. (Just ordered one of each, been using 303 protectant and have no yellowing or cracking, but always ready to try something new.).
  17. As for the key, I bought mine off Ebay from a Ford dealer. Here's one listing for an OEM key blank. (Personally I would avoid the cheaper Chinese knockoffs. (Too important an item should you be in a distant location and find it's gone kaput). https://www.ebay.com/itm/OEM-2011-2012-2013-2014-2015-FORD-EXPLORER-4B-KEYLESS-REMOTE-UNCUT-HEAD-KEY-FOB/351871465451?fits=Year%3A2013%7CMake%3AFord%7CModel%3AEdge&epid=1611236637&hash=item51ed2c77eb:g:XToAAOSwzaJX-oWt:sc:USPSFirstClass!46526!US!-1 You WILL have to take the key to either a locksmith or local dealer to get it programmed to the car. You could also price the FOB, cutting and programming through the locksmith and see if there's a big difference in price or not. And here's a video on where to find the factory door code. Remember that the previous owner's code is still programmed into your car and should be over-ridden as soon as possible (for security purposes). The procedure is simple and in your owner's manual.
  18. It looks more like a gasket used to prevent water from migrating under the front of the spoiler. Item Part Number Description 1 W651016-S Spoiler nut covers (2 required) 2 W621926-S Spoiler nuts (5 required) 3 010807 Spoiler 4 Spoiler retainers (part of 010807) 5 021A46 Spoiler gasket 1. Remove the liftgate trim panel. For additional information, refer to Section 501-05 . 2. Disconnect the electrical connector and the rear windshield washer hose from the rear spoiler. 3. Remove the 5 rear spoiler nuts. ° Remove the 2 nut covers. ° Remove the 5 nuts. ° To install, tighten to 6 Nm (53 lb-in). 4. Place a piece of tape on the liftgate to protect the paint. 5. NOTE: There are 4 pin-type retainers on the bottom of the spoiler. When removing the spoiler it is difficult to access the retainers to release them from the liftgate. It may be necessary to pry upward on the rear spoiler to release it from the retainers. Do not pry on the window. ° Remove the rear spoiler. ° Place a pry bar between the liftgate and the spoiler. 6. To install, reverse the removal procedure. edit: this was for a 2009 edge, think it's the same.
  19. Thats surprising. What purpose, drain slots?
  20. Door stills pop off. Pry with body tool slowly. If clips stay on the sill tabs, take off and replace before reinstalling the sill. (Service manual requires replacing clips when sill removed). BTW why are you removing the door sills. Door lock ground wire does not run through there?
