Everything posted by omar302
Group 65 Battery in 2nd Gen Possible?
omar302 replied to omar302's topic in 2015+ Edge & MKX Generation II
Now that's an auto enthusiast. Have to improve on stock ?. Maybe also consider changing the battery type/size in ForScan for the bigger battery. -
For me, we we have short driving cycles hence the benefit of a larger battery, As for the 65, its because it is actually cheaper here, so it seemed like a win-win. However, I found out that the battery terminals are on opposite sides meaning the fit will also require re-arranging the wiring. Will see if it is possible once my battery actually dies. -
What about the BMS? I know the battery model or type can be changed using ForScan, but I don't remember reading what would happen if the battery type in the BCM doesn't match the actual installed battery?
Issue happened again today. No response from the keyfob or the engine start button. Yet when I opened the door using the emergency key the alarm went off! The Horn worked and I was able to turn off the alarm by entering the keyless entry code on the outside keypad. Disconnected the battery for a few seconds and then reconnected it, vehicle started completely fine. This time the only code was from the BCM related to something with the steering column lock (B1026) which probably was due to the battery disconnect/reconnect as always see a bunch of similar codes.
How did you install it and wire it?
looking for part that attaches the strut to the wheel
omar302 replied to perez758's topic in Brakes, Chassis & Suspension
Lower control arm? Or knuckle? Check this link for a diagram and parts: https://www.tascaparts.com/v-2007-ford-edge--se--3-5l-v6-gas/front-suspension--front-suspension -
My 2016 currently has ~38K miles. Original front pads. Rear pads were replaced ~500 miles ago.
Your Edge is also a 2016, right? Mine dis not have that icon on the stock cluster, nor in the MKX. I suspect it started showing up in your Edge due to some ForScan change as I see you have done some other changes to your cluster. -
Lane keep assist I know is the bigger one next to the fuel gauge, my question was about the small one below. My 2016 Sport also has lane keep assist but I haven't seen this icon. If it is also for the lane keep, what does it mean? -
What is that small icon to the right of the battery light? -
We have AC Delco, Motorcraft, Panasonic, Hyundai and then some other unknown brands. We had 3 models/sizes of Optima batteries, non fit. The market here is very oriented towards Asian make vehicles, so not a lot of options. Also, they universally have 1 year warranties except the Motorcraft BXT that get 3 years. Since we get about 1.5 -2 years life out of batteries, the Motorcraft warranty means I'm basically buying 2 batteries. My current battery is nearly 2 years old, so I'm expecting it to go out soon and just trying to be prepared and decide what to replace it with. -
Thanks to all. My problem is that we don't have many choices for batteries here. The BXT-65-650 being more common is actually cheaper than the BXT-90T5-590. Hence my desire to use that, being cheaper, bigger & easier to find. -
Ford Active Noise Control
omar302 replied to niceonept's topic in Interior, A.C., Heat, Interior Trim
If you have cooled & heated seats, then there are fans in the seats. 2 fans per seat, one at the bottom and the other inside the seat back. When the cooling or heating is on max (3 LEDs) the noise is easily heard. For me it's clear as fan noise, but others might think of them as white noise. To test if the noise is really from the ANC, open a door to the first latch. If the vehicle detects a open door the ANC will turn off. -
As per the title, anyone tried installing a Group 65 Battery in a 2nd Gen Edge? Specifically the Motorcraft BXT-65-650? Price wise it is close to the stock (BXT-90T5-590 in my Edge) but has much more Reserve Capacity. The other battery specified for the 2nd Edge (BAGM-48H6-760) is 2-3X more expensive here. I know it is bigger than the stock battery (BXT-90T5-590 or BAGM-48H6-760), comparison is attached. For the earlier 1.5 Gen, both would fit.
I don't get that noise in my 2016 Sport. I remember reading of a member or two who had some issues due to the Active Noise Control (ANC) and the solution was a software update to a module. Maybe this also applies to this noise too. Edit: Found this: -
And only for those with butt dynos ?. I then misunderstood your post.
You SHOULD feel a difference. The owner's manual also states "For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended." A lot of newer vehicles, Ford's EcoBoost engines included, are designed like that. They can work with regular fuel, but using Premium fuel would yield better performance. Ford also had started advertising their Horsepower & Torque number when using 93 Octane fuel.
Help please! Acceleration stops on freeway!
omar302 replied to Jennifer Grebing's topic in 2016 Edge & MKX
There is no video posted in your post. Any warning lights comes on when the issue happens? -
How often do you put on your emergency/parking brake?
omar302 replied to flymore's topic in Brakes, Chassis & Suspension
I used to put on daily whenever I park as it was along time habit, but recently with it being electrical on the Gen2 Edge I just felt that the actuator might fail sooner if I kept engaging it every single time. So now I judge when I park, if it is a level surface I'd skip engaging the parking brake. -
Maybe try to have someone hold the lever pulled while another tries to pull up on the hood.
I am not into tuning, came across this post from the Fusion Sport Forums, the OP seems to have went through a lot to get his tune & misfires sorted out. Maybe he can help you out seeing how the Edge Sport is closely related to the Fusion Sport.
As @ben senise stated above, the "distance to empty" figures are predictive. They use the average MPG of the past few hundred miles, so if your current driving uses has a lower mpg compared to the average used for calculation, the "distance to empty" number will go down quickly. From you posts above, seems your driving is for short drives which will definitely reduce your mileage.
Under hood temps and hood heat extractor install
omar302 replied to poontanghooligan's topic in 2.7L EcoBoost
If you have access to the 2019/2020 service manual you should be able to see the engine cooling components. That's how I found it on the 2015 model.
