Everything posted by omar302
I have the same issue. I think it is related to the chimes sometimes being diverted to the instrument cluster instead of the speakers.
Is you coolant level OK? Engine temperature in the normal range (mid point in the gauge)? I think other than that you might be looking at a blocked heater core. Though I don't remember reading about similar cases for the 2011-2014 models. I am sure @WWWPerfA_ZN0W will chime in with a better (more educated) answer.
If they work for a while after resetting them, it probably indicates you need a new actuator for blend door.
Furthermore, and in the last post in the thread @Gadgetjq linked to, even the taillights on the sides are different. SE/SEL have different lights than Sport/Titanium models as they illuminate differently. If you want a full bar, you'll need all three light assemblies and also programming through ForScan. In the SE/SEL side taillights, only the middle part illuminates. Low intensity for normal parking light function and full brightness with brakes/signals. In Sport/Titanium side taillights, the surrounding illuminates as the parking light (completing the middle bar) and middle part is split, top is red for brakes and bottom is amber for signal. Couldn't get better pictures, but should give an idea.
I am sure you'll get more answers from more knowledgeable members, but I think you're asking if it would be "harmful" if you don't run 93. In that case I think asking Torrie is your best bet as he would know how he tuned it and how it react on a lower octane. In a stock tune, it is programmed to take advantage of higher octane levels and to run fine (with reduced power) on lower octanes without any harm.
Welcome. Have a nice trip and enjoy the new ST.
The attached should help. I would check under the rear seat cushion as there are 2 (i think) connectors. I would think that if come out from their fixture they could cause some rattling. Rear Seat Cushion.pdf Rear Seat Backrest Cover.pdf Rear Seat Backrest.pdf
New 19 ST - No remote start on fob?
omar302 replied to Jclewis84's topic in Alarms, Keyless Entry, Locks & Remote Start
As per the 2019 Ford Edge Order Guide, for the ST, remote start is not standard. It is part of the "Convenience Package" and 401A package. One telltale to know if you have either, do you the 110V AC Power Outlet? If not, then you don't have Factory remote start. -
HOW DELETE LINCOLN MKX ERRORS CODES
omar302 replied to zhuory's topic in Brakes, Chassis & Suspension
I don't know the answer to your questions, but it was discussed in an another Forum (2G Ford Fusion) that to get Stop & Go Adaptive Cruise Control it requires an additional sensor/camera on the windshield, which also means a new windshield to attach it too. In short, it is not a simple ForScan edit. -
Welcome and congrats on the new ride. The Fusion Sport is a sharp vehicle, too bad it is going to be discontinued.
Low Oil Pressure warning keeps coming on!!!
omar302 replied to vtchopperdude's topic in EcoBoost Mod & Tech
Just in case you didn't already do it, but did you try to clear the code and see if it then comes back? Might just be a stored code from before. -
I wasn't aware that there is a safety switch connected to the oil pressure switch. Is that confirmed to be correct on the Edge? It would be really good to have the piece of mind that it is there. This is what is stated in the 2016 Owners Manual: -
As far as i know, no. This can only be done on newer models (2015+). -
Ever remove the rear seat bottoms on the 2nd gen Edge?
omar302 replied to Chipster's topic in 2015+ Edge & MKX Generation II
You push back then up at the rear end of the (under the backrest) in order to clear the rear hooks. See the attachment for better understanding. Rear Seat Cushion.pdf -
There is no cooling or heating for the cup holders.
Not possible. As you have stated, the temperature gauge is only displayed with the round engine RPM gauge.
If I am reading this correctly, the oil pressure light is coming while the engine is shutting down and the engine shutdown happens at slow engine speeds. I feel that the engine oil light is coming because the engine was shutting. In other words, it's the opposite of what you think. You need to find out why the engine is shutting down. Check for codes stored in through the OBD port. If no codes are present, try cleaning the throttle body and the mass air flow sensor. -
2013 Edge Limited 3.5L AWD Fuse Box Questions
omar302 replied to J. F. Cunningham, Jr.'s topic in Accessories & Modifications
Yes. But not all features would work by just enabling them. For example, to have one touch non-driver auto window will need different window motors and switches (in addition to the wiring, also door modules depending on years, not sure). Same goes for Power Folding mirrors which also would require completely different mirror housings (I don't think any even exist for pre-2015 years). -
2015 ford edge 3rd brake light replacement
omar302 replied to Rick Jasnica's topic in 2015 Edge & MKX
See this post. -
Headlights replacement. LED Chinese version
omar302 replied to Fegnattack's topic in Accessories & Modifications
Ok. Now it is clear. See this from the 2GFusion ForScan sheet: 726-45-01 (2014+ MY) xxxx XXxx xxxx Note: This setting enables all choices in the list for DRL options (BdyCM) Set value at XX to 7F 726-50-01 (2014+ MY) xXxx (BdyCM) 01 (Disabled - Default (USA) / No DRL) 02 (Enabled - DRL Low Beams) 04 (Enabled - DRL Front Fog Lamps) 08 (Enabled - DRL Front Turn Lamps) 10 (Enabled - DRL Dedicated) - Enables BCM DRL Outputs - C2280C Pins 36 (Right) and 40 (Left) 20 (Enabled - DRL High Beams) 40 (Enabled - DRL Low Beams and Dedicated) So my suggestion is to first try (726-50-01 XXxx, change the "XX" to "08"). If it doesn't work, then you might need the other one (726-45-01 xxxx XXxx xxxx change the "XX" to "7F")
