Everything posted by omar302
Make sure you at least get a new water pump on the replacement engine.
Doesn't the TSB involve flashing the PCM? Shouldn't you get an updated tune from LMS and stored the new stock tune? I am not really sure how it is supposed to work, but that was my understanding.
The 2016+ Explorer low beam LEDs are much better than the HIDs on 2011-2015 Explorers or even my 2016 Edge HID. That's from my own experience. Though it is not much a case of LED being better than HID, but rather Ford's HID being really bad. Even the HIDs on Lincolns are better. My previous 2011 MKX had better HID than my Edge, and newer 2015 MKC & MKS I tried had even better HIDs.
Did not hear of something similar before. Maybe see where the rear wiper goes the the glass, there should be a bushing to allow the wiper motor shaft through the glass but prevent water & dust from going in.
What I posted is the only thing I know on this. -
2007 vs 2017 option to leave keyfob in car
omar302 replied to nc_edge's topic in Alarms, Keyless Entry, Locks & Remote Start
You can do as @SUV-Esuv stated above. Also note that to lock the car with key fob inside you should use the keypad by pressing the 7-8 & 9-0 buttons simultaneously. This would lock the doors even with the key fob inside. -
Fix the inaccurate MPG display in 2 minutes!
omar302 replied to omar302's topic in Accessories & Modifications
Yes. Average on both sides. -
It is better to get an average of at least three fill ups to have a better base line. A calculated mpg from a single fill might be off due to over or under filling. -
This ForScan edit does not apply on your Edge. Only on 2015+ Edge models. As far as I know, there is no way to change on 2014 and older models. For 2011-2014 Edge ForScan edits, look at 2011-2015 Explorer sheets. That is the closest sheet.
I don't think it was released by Ford to Owners directly (V3.10), was only a dealer update (if I recall correctly). Being this is the internet, people found it, uploaded & installed it. This is one post from XDA Forums that has a link to a US version (direct link fro the post). This goes with the usual disclaimers to proceed at you own risk ?.
From the owners manual:
It is not about the wired vs. not wired. The MX is better, considered the best for such things. Even the wired readers don't necessarily read all protocols. They would require a switch to allow it to read MS-CAN. Also the OBDLink SX (the wired version) from them can't read MS-CAN. -
It is probably due to the limitations of the OBDLink LX. It cannot access MS-CAN and hence would not see the modules working on MS-CAN, also there are newer HS-CAN2 & HS-CAN3 which i am not sure if the LX can see. The SCCM is on MS-CAN so you won't be able to change that, but for the Double Horn Honk just follow @ben senise post above. -
This is a feature enabled/disabled in the vehicles settings in the left instrument cluster display. Had it on my 2011 MKX and also in the 2016 Sport ?. Edit: Just looked in my 2016 Sport & the menu is not there! But the feature is working. Not sure if it was there & maybe due to ForScan edits it disappeared or not.
click/tin sound from underneath when opening door
omar302 replied to cv27's topic in Exterior & Body
Is it only when first opening the door to go in the car while it is off? And it does NOT come if the engine is already running? Is so then it is probably the fuel pump priming to build up pressure getting ready so when you start the engine it starts easier. -
It was this article from MotorTend when they reviewed the 2011 Edge Sport AWD and found it slower 0-60 than a SEL with FWD. https://www.motortrend.com/cars/ford/edge/2011/2011-ford-edge-test/
Like this:
Wrong year showing on Calender
omar302 replied to Awoodworker57's topic in Audio, Backup, Navigation & SYNC
If know correctly, the date is set from data received from GPS even if you don't have navigation. Try a master reset or disconnect the battery for a few minutes. Maybe a reset will sort it out. -
Is it possible to change the sign out button on the mobile site? It is very prominent especially when going for the "Mark site read" button many times I accidentally tap on "Sign Out" instead of "Mark site read".
What if there is no car in front?
I have the procedure for the 2015 which is different. But I think the same principle applies. need to wait 40 minutes. NOTE: No factory equipped vehicle should have more than a 50 mA (0.050 amp) draw. Check for current drains on the battery in excess of 50 mA (0.050 amp) with all the electrical accessories off and the vehicle at rest for at least 40 minutes. Current drains can be tested with the following procedure. Battery Drain Check.pdf
I have on my 2016. Had on my previous 2011 MKX & 2008 Taurus. It's a Ford trademark ?. To reduce it, like what @Fingernip stated above. If it still shakes, from my experience, it is because the hood is not seating properly at the back, on the weatherstripping at the cowl. But there is no adjustment on that end so I try to bend the hood slightly from the middle so it seats better to the cowl area. With the hood open I just pull back the hood from the rear middle with two hands. It helped a lot in reducing the shaking.
Many other cars/SUVs do it. Even my 2016 Edge does it, though My DRLs are not the LED signature lights. Also there is a ForScan mod that can disable/enable it for modern Fords. I think this link would answer your question better than I did: https://jalopnik.com/heres-why-modern-cars-turn-off-one-of-their-lights-when-1792394567
