Everything posted by omar302
Dual Climate Control Repair
omar302 replied to finzup's topic in Interior, A.C., Heat, Interior Trim
Keep us updated after the visit. -
Horn sound/warning
omar302 replied to Kleber Gomes's topic in Alarms, Keyless Entry, Locks & Remote Start
@Tacyon Do it yourself, there is no official way to disable the double honk. It is really simple using Forscan & a compatible adapter. Newer Fords, as far as I know, still have it with no option to disable, but I think they started switching to a different noise on new Lincolns, a more tolerable noise not from the horn. -
Could also be a loose battery connections.
Wiper(s) question
omar302 replied to Chipster's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
It might be a 2015+ thing. Though the owners manual doesn't show that. http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O31263&languageCode=en&marketCode=US&viewTech=IE&chapterTitleSelected=G1675940&subTitleSelected=G1675947&topicHRef=G1448435&div=f&vFilteringEnabled=True -
2015 Edge fob self actvates in pocket
omar302 replied to rurick's topic in Alarms, Keyless Entry, Locks & Remote Start
I recently saw a video review of a 2017 Edge & the remote design seems to have been changed similar to the 2017 Fusion. Maybe it will work on a 2015 Edge. http://i.ebayimg.com/images/g/HnsAAOSwJ7RYSZOM/s-l300.jpg -
SyncGen2 v3.8 and Android 7 Issues
omar302 replied to cubanB's topic in Audio, Backup, Navigation & SYNC
I have an HTC 10 & it was updated recently to nougat, no issues with SMS notifications or reading of messages by MFT. It also announces from who the is if it's from a saved contact & SMS notification is set to text to speech. -
Horn sound/warning
Glad to have helped. -
If both sides change temperature, i.e. goes from warm to cool (or the other way) when changing the temperature setting, then they are probably fine. Possible issues: A little low in A/C charge, happened to my MKX and caused the driver side to be noticeably warmer. Most probably this is your issue. HVAC module needs a reset. The DBA, though working, is not functioning to spec. -
Mac, nice videos, great as usual. On the exhaust smell issue, Ford does have an issue on the Explorer mainly & to a lesser degree on the Edge/MKX. I had it on my car, it was very clear; A/C on re-circulation, full throttle or hard acceleration (10-20 seconds) and then you start smelling exhaust fumes in the car. Accelerating with the A/C off or with a cracked front window or with A/C on outside air will not cause the smell to come in. I have tested this on open roads with no other traffic to ensure that what I smelled was from MY car as i initially thought it was from others. Ford's issue is that the HVAC actually sucked in the exhaust fumes at a higher rate than acceptable. Even the TSBs for the issue involve reprogramming the HVAC modules in the Explorer & Edge. My guess would be to allow outside air in during hard acceleration. Now I say exhaust smell, because this is what I smell, is it carbon monoxide or not, I don't know. I didn't have a meter, and I will definitely not argue with experts who know better, but it was an annoying issue, and performing the TSB reduced it an acceptable level, just hope the fix lasts.
- 668 replies
- 2
- 2011 Ford Edge
- Limiited
(and 4 more)
FS-106 is new to me. When I ordered mine, I ordered FS-104 as per the owners manual & got the plastic covers & even the boxes they came in were FS-104.
Taillight Led Turn Signal Hyperflash
omar302 replied to Decastro458's topic in Accessories & Modifications
The ForScan windows PC version (free) you can use it to change vehicle parameters (as built data), some options would already be shown by default if the programmers already know it. This is their website. Here are some threads about it: http://www.explorerforum.com/forums/index.php?threads/double-honk-disable-enable-with-forscan.449385/ http://www.explorerforum.com/forums/index.php?threads/new-forscan-update-allows-module-programming.442848/ -
Using ForScan you might be able to turn off the bulb out option. I know I get this option for my MKX, by default it is turned on for the front signals which use normal bulbs & is turned off for the rear signals since the MKX has led taillights. -
The new "so called" filters are not actually filters anymore, just a screen. They even use the same part numbers. Posted about them some time ago. I believe in newer models they are now "lifetime".
Akirby, you're right, for front seats with cooling & heating. Those with front heated seats only (SE/SEL and base Titanium/Sport) I believe have the old fashioned heating elements. Also, if equipped, rear heated seats are with heating elements.
Heated mirrors not working
omar302 replied to vrdublu's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Maybe they are working, only not warm enough for the freezing your getting. When there is no ice on them, feel them for heat after a while from turning the rear defrost on. An infrared thermometer would come handy to check. Do the mirrors have the heated mirror symbols on them? -
2014 Edge Defrost System Problem
omar302 replied to Beerfoot's topic in Interior, A.C., Heat, Interior Trim
If the dealer is a family friend, just ask them to re-program the Climate Control Module to the latest calibration using the latest IDS release as mentioned above. No need to diagnose unless the issue is still present after the update. Here is post by WWWPerfA_ZNoW with details of a TSB on the same issue. -
Did you check the pad clips? Are you sure the noise is from the front? The rears could also cause the noise, especially if the rear caliper piston was not aligned correctly as there are two groves that should align with the notches on the pads.
Ford Edge 2012 SEL - Radio frequencies
omar302 replied to malammouri2015's topic in Audio, Backup, Navigation & SYNC
http://www.forscan.org/forum/index.php http://www.explorerforum.com/forums/index.php?threads/double-honk-disable-enable-with-forscan.449385/ http://www.explorerforum.com/forums/index.php?threads/new-forscan-update-allows-module-programming.442848/ Edit: The same mods are usually the same for 2011-2014 Edge & 2011-2015 Explorer. -
1st, make sure your vehicle is actually equipped with heated mirrors. If it does, check fuse# 50 in the engine compartment fuse panel. It is a 15A fuse only for the heated mirrors as per the owners manual. -
@malammouri2015 I am not sure if it is MS-Can or HS-Can, probably HS-Can as my first cable was not capable of reading MS-Can & i remeber using it to change the ACM's ABD. I suggest you get a cable with switch ready, it would come in handy in the future. I bought one like this from the same seller and it is working fine. For DRL, once you connect Forscan, you will get built in options to select DRL on or off in the BCM, no need to mess with the As Built Data for this mod. -
As Akirby said, you need to reprogram it. It can also be done using a free program called ForScan with a cheap compatible OBD2 connector. You can read about the program at www.forscan.org You will need to change the as built data for the ACM in block 727-04-01 , the second digit would be 0 in us vehicles & 1 for GCC vehicles. But you will lose RDS as it is not enabled in GCC Edge models (2011-2014). -
It is probably one of the door actuators, to figure out which it is manually change HVAC settings & listen for the noise. For example, change from defrost to front registers to floor. Try fresh air/recirculate, and check each side temperature settings (driver/passenger), go from full cold to full hot.
- 1 reply
