Wishful thinking but the reality is very different. You’re talking about millions and millions of acres. 193 million acres in fact. And who would pay the billions needed? Taxpayers? Care to guess how many people would be needed to "clear out the dead brush"? Also consider whats green today can be dead and dry in just a few days. There are actually more wild fires in the east. But the west has more open land and the fires there are more difficult to get to and furniture larger areas. Couple that with the winds (think Santa Ana) and its easy to see why the quickly get out of control. According to the Congressional Research Service, in the United States, there have been 1.5 million wild fires since 2000. And there have been 1126 wild fires (on average) between 2916 through 2020. Its just not an easy problem to solve. Impossible actually. That's why California has hundreds of people working on thd problem. Universities, state offices, local authorities and .... the list goes on. -
Install rear camera in Edge 2009 ltd
enigma-2 replied to edgemaster's topic in Audio, Backup, Navigation & SYNC
Think it was Lex that did this in his 08 (???) Edge. Anyway here's the link where he explains how he did it (used this cavity, attached camera to cover): -
Cruise Control Speed Increments, possible to change?
enigma-2 replied to ben senise's topic in Accessories & Modifications
Why do I picture a Ford Engineer sitting in front of his computer reading this going, heh, heh, heh. -
MACTFORDEDGE just released a new video where he claims to have found the source od the exhaust smell entering the cabin on some cars. He isolated to the original equipment exhaust pipe flex pipe section and discovered that it had pin holes "all over it". After he changed his, he longer had any exhaust smell in the cabin. He states it wi run around $250 to fix.
Question? Why do you want "brighter , much brighter, much much brighter LED lights" in the first place? You don't need them for seeing. The only purpose would be to blind oncoming drivers. (Yes, even in daylight, bright lights can dazzle or blind oncoming drivers). Concerning safety, doesn't make you more visible, as standard DRL work just fine. And it may violate the maximum amount of light permitted at the front of a car (depending on your state laws).
Cover for heated steering wheel
enigma-2 replied to Brad Lingo's topic in Accessories & Modifications
Don't cover the steering wheel with a cover. It will sense the heat being retained and stop heating. Don't recall Ford publishing anything on this, but Chrysler states "Do not place anything on the steering wheel that insulates against heat, such as a blanket or steering wheel covers of any type and material. This may cause the steering wheel heater to overheat." Consider a comfortable pair of driving gloves.- 1 reply
"Pre-covid", how true. Forevermore we'll be referring to this as a turning point in history.
Why not just switch to tires and rebalance.
I'm still carrying a PremiumCARE on my 2009 Lincoln MKX for two more years, and it's covered. Everything except the usual, glass, tires, battery, etc.
- 22 replies
- 2.0ecoboost
- extendedwarranty
Check your lock to make certain your key still works. Someone may have been trying to break in.
One other thing Haz didn't mention, switch to the towing maintenance schedule when towing. Things like modified changing transmission, PTU rear axle fluids, etc. Whatever's specified in your manual.
Parking brake limited function
enigma-2 replied to sjskowron's topic in Brakes, Chassis & Suspension
Wiring harnesses rarely go bad. Almost always it's related to corrosion in a connector. -
Theres a TSB 21-2081 on a 8F35 transmission requiring a software update. Talk to your dealer and see what he says.
Remote Windows
enigma-2 replied to seanmarshall's topic in Alarms, Keyless Entry, Locks & Remote Start
Interesting. Does the UK Edge rear windows have one-touch up/down? -
This page states its for 07 thru 21 Edges. Approx 1 mph or 2 kph. http://www.fosuvs.com/focont-284.html#:~:text=The set speed will change,2 km%2Fh) increments.&text=Press the accelerator pedal or,you reach the desired speed. -
First ask "why do you want to modify the car"? There is cost involved, loss of warranty, lower resale value, etc. What real value are these modifications bring to the table? Why not just drive the car as is for a few months until you reach a point where you are making a change because this is something you just can live without. If its nothing more than new car infatuation, buy Weathertech floor mats and a cell phone holder. Then wait to see what moves you.
Man that's fantastic. Love to travel, see strange and foreign lands. Had no idea about the costs to visit places like the Serengetti. Never thought about the costs of places like this. Bet its an interesting ride in the living area when underway; inasmuch as how high up it sits. Thanks for posting
:Big thumbs up: Very ingenious. Great times, but that first step looks like it's something you'd find on TicToc. AAAAAAaaaaaaaaa Thud!
FordeEdge 2011 AC blower turns on and Off
enigma-2 replied to TARiQ's topic in Interior, A.C., Heat, Interior Trim
Start by reprogramming the HVAC module. With the doors closed, press the climate control power button simultaneously with the defrost button. Hold for 10 - 20 seconds and release. Then press climate control power button one more time and the HVAC should reset. If it's a glitch, this should fix it. If not, I'd suspect the module itself. -
Ahhhhhhhhhhhh, yes. A brittish motor home!
Several videos on YouTube. But don't fool yourself, its off-road capabilites are limited. It's still built on a car platform, not a truck.
Wonder if the ignition switch is failing. Try testing it by turning key to "RUN" position. Check what voltage you get at the + ignition wire that goes to a coil. Should be 12 Volts. If not, the ignition switch is suspect. (If no voltage, try turning off, removing key and back to run. Perhaps it's intermittent.
