Everything posted by omar302
Those are weep holes for water condensate to drain out.
Check the attached for more details on what is covered under warranty. I'm guessing you have a 2019+ Edge and it is the rear fixed glass that is broken, the OEM glass replacement is only $700. The dealers quote seems quite high. I know that the procedure is a bit more labour involved, but still, $1200 seems too high. If it is not uncovered by warranty, suggest you check with glass replacement shops. G0000179 -Window Glass Ford.pdf
Looking at pictures of it (here), it seems it is attached with screws.
Attached is the service procedure for removal of the antenna. Satellite Radio Antenna.pdf
No owner's manual or keyless entry PIN?
omar302 replied to Davidoo's topic in Buying, Leasing & Ordering
The info regarding the digital manual replacing the paper one seems to be correct. See this link from Ford, the footnote states the following: **On vehicles with digital owner manuals, the paper manual will be dramatically reduced but not fully eliminated. As for your worry of accessing it with a dead battery, you can also access it through your phone (link). For the key code, I couldn't find any info, as far as I can tell, there should've been a card provided. If where you I'd raise a serious concern with the dealer on its whereabouts as it can provided access it's holder access to your vehicle. They should provide it to ensure no one else took it. -
Found out that the 2020+ ST Wheel Centercaps are a 100% replacement for my 2016 21", only they are black instead of blue. Part number FR3Z-1003-A. Got them for about $11 each. I had previously purchased an aftermarket set like those available in eBay or Aliexpress (set of 4 for about $12), but they did not fit correctly, the tabs were shorter and they would be loose and easily fall off. I also found a site that sells the set (4 pieces) for $34.95 (link), but as I still had to ship them overseas, my local dealer's price made more sense. -
2010 Tail Lights
omar302 replied to AllFordsForMe's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I am guessing because the Sport taillights are darker (blacked out), hence if you install only one side it will be different compared to the other (stock) side, hence the incompatibility (different part numbers). -
I do. Going over speed bumps I get the exact same feeling you described. I remember it this way since new. Reading Ford's introduction of the Edge Sport, they did state upgrading the rear shocks compared to the standard but no mention of the front struts.
'18 Sport, and it hates my iPhone...kinda
omar302 replied to TheyCallMeTheMayor's topic in Audio, Backup, Navigation & SYNC
I am not sure how it is on iPhones, but with an Android, you'd go to the Bluetooth settings and disable "Media audio" for Sync. But that would also disable Bluetooth audio streaming. -
Apparently fuel Tank drilling has started to make news. https://jalopnik.com/fuel-tank-drilling-is-the-hot-new-car-theft-trend-sweep-1848653956
My opinion: Nautilus or Edge: Test drive first. Generally speaking, the Lincoln will be the nicer more comfortable ride, but will depreciate more (percentage wise). In my experience, my 2011 Lincoln MKX though was more expensive than all Edge trims, but after 6 years it's value become slightly below a 2011 Edge Sport with the same engine. 2019 or 2020: Newer, lower mileage is always better, but will be more expensive. V6 or 4 cylinder: I haven't tried the 4 cylinder, but previously had the 3.7L V6 in the 2011 MKX and now have the 2.7 V6 EcoBoost in the Edge Sport, I definitely wouldn't go for the 4 cylinder. Buyer's remorse: Get a V6 2020 Nautilus. You won't regret buying the best option (highest trim, Engine, model...etc.), only your wallet will hurt. ?. Again, Test Drive. This is the biggest deciding factor, in my opinion.
The part number "BU5Z-9C268-B" (for the 2015+ Edge) supersedes (BU5Z-9C268-A), I found one (1) piece of the older part number available on eBay for $27.29.
I have a 2015 Lincoln MKS with the 3.5L V6 EcoBoost and the stock exhaust system sounds good, unlike the 2.7L EcoBoost in the 2016 Edge Sport I have. There is a vast difference in exhaust sound between the two even though both are Twin Turbo V6s. Probably its just the nature of how each is designed, I guess one of the reasons being the 2.7 being designed for more stringent future emissions regulations.
You stock "F" setting should work. Do not change it. Did you try the "Reverse Tilt Mirror Calibration" process? Did the option show up in the cluster under vehicle settings and it is enabled? Nothing else comes to my mind now. -
Just as @Wesow stated above, it is better to add you Edge model/year to you signature. I assume you have a European Edge as from you screenshot it shows to be a diesel model. The default value is different (not 7) because you also have folding mirrors. So you have 720-02-01 as FBA4 AC78 1E08 and you'll need to change the A to E (A+4 = E). The line then becomes FBA4 EC78 1E08. When writing the value you will get a "checksum" error, just ignore it, then the last two digit (08) will change to the correct checksum value. -
Enable Reverse Side Mirror Tilt: 720-02-01 (2013+ MY) xxxx Xxxx xxxx (IPC) 3 (Disabled - Default) 7 (Enabled) Add Hex 4 to Existing Value: 3+4=7 740-03-01 (2013+ MY) Xxxx xx (DDM) 6 (Disabled - Default) 7 (Enabled) 740-13-01 (2013+ MY) XXxx (DDM) 00 (Disabled - Default) FC (Enabled) 741-03-01 (2013+ MY) Xxxx xx (PDM) 6 (Disabled - Default) 7 (Enabled) 741-13-01 (2013+ MY) XXxx (PDM) 00 (Disabled - Default) FC (Enabled) Select left/right mirror, put vehicle in Reverse and mirror will automatically tilt down toward curb and then return to normal position when gear is changed or mirror switch is unselected. Reverse Tilt Mirror Calibration: 1) Switch the ignition on 2) Press the memory button 3) Select the mirror you want to adjust 4) Put your vehicle into reverse (R) and let the mirror automatically tilt until it stops 5) When the mirror is in its tilted position and is no longer moving, adjust it with the controls 6) Hold the memory button for 5 seconds to save the setting 7) Press the mirror button and return to park (P) ? Hold memory button again Although there is no specific list/sheet for the For Edge, you can generally follow the same codes as other Ford vehicles. For the 2015+ Edge, you can follow the 2015-2020 F-150, 2013+ Fusion (2nd Gen) or 2016-2019 Explorer. -
Use ForScan with a suitable OBDII adapter.
Welcome. Hope you enjoy your new ride.
LIncoln MKX to Ford Edge Instrument Cluster Swap
omar302 replied to onyxbfly's topic in Accessories & Modifications
Here two "Swiss" spec'ed EU Edges listed for sale with VIN# included in the listings: Black (07/2020 build) ST-Line (2FMTK4A32LBA77409). Brown (07/2019 build) Vignale (2FMTK4V32KBB84369).- 110 replies
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
Edge 2019 SEL Place for Towing Hook
omar302 replied to BaZZaD's topic in Cargo, Hauling, Roof Racks & Towing
Do the hooks attach to the steel bumper or the frame? I've seen several videos online (other makes) where the bumpers are stripped off when attempting any real recoveries using the recovery hooks. I know the Euro Edge (Gen2) does have the bumpers with holes for the recovery hooks. My "GCC" spec Edge (basically a NA spec with few changes) also has the holes and recovery hook stowed in the cargo area, but I would be afraid to use it for fear of damage to the bumpers. -
Just an update, I found that the below are the EU Edge firmware files: EU Edge (I think for later 2016 up to 2018. dated Aug. 25, 2016, they are with the thin needles and center digital speedometer? GM2T-14C026-NE GM2T-14C026-ANE GM2T-14C088-NE GM2T-14C088-ANE Also found these for earlier build UK 2016 Edge (with thick needles but without center digital speedometer): GM2T-14C026-NC GM2T-14C026-ANC GM2T-14C088-NC GM2T-14C088-ANC I also found out that with the Ford graphics and new "thin" needles, if the Cluster welcome startup was enabled the startup animation would show the thick needles (during the animation) and then change to the thin needles. This seems to be because when Ford started to use the "thin" needles on newer vehicles, the clusters were configured without the "welcome" animation turned on, hence the graphics animation for the welcome screen were never updated. So if you use any firmware with "thin" needles you need to disable the welcome screen. Anyway, I have eventually settled (for the time being) on the FS7T firmware of the Fusion/Mondeo listed in the 2gfusion thread that include the thick needles, outside temperature display and correct animation. The Ford graphics & blue needles, in my opinion, are better looking than the Lincoln's. They also make them easier to read.- 110 replies
- digital dash swap
- (and 3 more)
How to remove the glove box
omar302 replied to ed_radz's topic in Interior, A.C., Heat, Interior Trim
OP has a 2018 model, see the below linked video. Hopefully opening the glove box this much is sufficient to get what fell behind. -
For many years American models didn't have any hooks, especially for cars & crossovers. For recovery, it is still possible. See this channel where they do a lot of recoveries by hooking to the lower control arms. https://youtube.com/c/MattsOffRoadRecovery
