Everything posted by omar302
open windows with key fob?
omar302 replied to mrmikesdeuce's topic in Alarms, Keyless Entry, Locks & Remote Start
What @Cerberus stated. Just make sure it is enabled under vehicle settings in the left instrument cluster screen. I think it is referred to as "Global Windows" or "Remote Windows". -
Learn something new. Maybe look if there replacement stem mounted TPMS sensors that replace the band style sensors.
My '20 Edge ST Towing Experience
omar302 replied to poontanghooligan's topic in Cargo, Hauling, Roof Racks & Towing
Ford's ECU measures to protect the AWD has been present since at least the 2011 Edge model year, yet many PTUs have failed. Ford even made later versions of the PTU with oil drain plugs to allow for oil changing on some newer models. -
If I were you, I would definitely drain & replace the PTU & Transmission fluids, maybe even the RDU. Getting 11.6 mpg driving 62-64 mph over 1000 miles means your Edge was really working hard. -
0.8 mpg is nothing. it can simply be different fuel, driving style, ambient temperature,...etc. For the name/brand, I don't remember that there is any Ford "approved" intake cleaning brand/method. So if the brand you used claimed to be "approved", they should be called out to warn others.
- 11 replies
- 2
- crc
- valve cleaning
"No Key Detected" and Car Won't Start
omar302 replied to Shockwavesix's topic in Alarms, Keyless Entry, Locks & Remote Start
For me it sounds like a bad vehicle battery. I wouldn't even be doubting it. The "click click click" sound is typical of the starter not receiving enough voltage to crank. Being a 2 year old battery, start by replacing it before trying to diagnose it as another cause. Also, this is not related to the "no key detected". -
@ANoid: Electronic Stability Control. From the Edge Owners manual:
Congrats on or new ride and welcome to the forums.
Power Locks not completely working
omar302 replied to LM1989's topic in Alarms, Keyless Entry, Locks & Remote Start
If I remember correctly, Pre-2015 (Gen 1 & 1.5) Edges, the rear doors do not open like that, they have to be unlocked either by the power unlock or by raising the lock "knob" by hand. Front door locks open simply by pulling the door handle. The "Pull twice" for the rear doors is applicable on Gen 2 Edge (2015+) & MKX (2016+) -
It depends on how hard you drive & how much you let it idle because it affects fuel mileage a lot.
If @akirby's suggestion doesn't work, try to disconnect the vehicle's battery for about 10 minutes then reconnect it. Also, a low voltage battery would prevent remote start, so that's also a possibility. A long drive should recharge the battery sufficiently.
Windshield NOT acoustic Glass ?
omar302 replied to DNBush's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Seems that Carlex & Carlite used to be different companies, both related to Ford, but eventually Carlex purchased Carlite. Found an article in this AGRR Magazine about it. Too complicated and I don't know what that means to this issue, but if your vehicle never had a windshield replaced before, then it has to be acoustic glass as it is a standard equipment on the Edge, regardless of what is written on the glass. On another note, the side glass might be "branded" as acoustic because it is not standard equipment, hence the differentiation. What puzzles me more is that the 2021 Edge does not show acoustic glass anymore in the Order Guide.- 10 replies
- windshield
- glass
Maybe a tire tread starting to separate?
How to remove liftgate panel
omar302 replied to Starting to hate this car's topic in 2015 Edge & MKX
See this: Liftgate Trim Panel.pdf -
As per the 2020 Edge Order Guide, the acoustic windshield is standard equipment. Seems the 2020 windshield is made by AGC Automotive, while the previous models were from Carlex and the "Soundscreen" branding is apparently part of Carlex. AGC Automotive also makes acoustic glass as per their website.- 10 replies
- 4
- windshield
- glass
What is written on the windshield? Does it say "Soundscreen"? Here I had posted a photo of the windshield on my 2016.- 10 replies
- windshield
- glass
Locking Out Higher Gears without being in Sport Mode
omar302 replied to chipdog4's topic in Accessories & Modifications
Keep it in Sport mode without pressing any of the paddle shifters, the transmission should hold gears more & would lockout the highest gear or two. -
Dome lights
omar302 replied to mrmikesdeuce's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Make sure the switch is not pressed on the overhead console. See the video below around the 50 sec mark. -
As far as I know, it's in the PCM. The IPC only resets it and shows it. There is a PCM PID to show the oil life percentage. Message Center - System Operation and Component Description.pdf
Did not read about it anywhere. Would be good to be able to change to a custom interval.
Page 432 of the manual "NORMAL SCHEDULED MAINTENANCE". You can download a "PDF" version of the manual or browse an HTML (website). Link to 2020 FORD EDGE OWNER MANUAL, WARRANTY & OTHER INFORMATION. In short, the manual states to follow the Oil change reminder which should come up at a maximum interval of 10K miles or 1-year. From the manual:
As per the attached document, they'd look at the ignition cycle counter using mode 9. But the LMS tuner does not reset the counter, neither on a performance tune or when returning to stock. I have seen this myself. So it won't be detectable. G0000128 Gas Engine Performance Modifications.pdf
How to lock fob in vehicle?
omar302 replied to KrazyIvanUSA's topic in Alarms, Keyless Entry, Locks & Remote Start
As @1004ron stated above, you can lock a fob inside using another fob from the outside or using the kaypad by pressing & holding the "9-0" & "7-8" buttons. The kaypad will still unlock the door. -
You can use https://www.etis.ford.com to check using the VIN how the vehicle was equipped. But you need to register first. Also, you can contact US Ford online parts sites. They can sell you the correct parts based on your VIN. For example, https://www.levittownfordparts.com/ They are also active on this forum. Benny. @LevittownFordSuperCenter Another good site I use sometimes is Tasca Parts.
