Everything posted by omar302
@akirby I agree on the Explorer, the police version already outran the AWD & RWD 5.7 Charger Police versions, in acceleration, top speed & track. https://www.autoblog.com/2018/10/04/2020-ford-police-interceptor-utility-performance-tests/ The regular 5.7 charger is quicker than the Edge, though, the Police Charger has a 5 Speed auto versus the 8-speed in the civilian version.
2013 heated steering wheel
omar302 replied to prokidon's topic in Interior, A.C., Heat, Interior Trim
I don't think the Edge offered a heated steering prior to the 2015 model. -
If you still have the 2015, I believe it is a simple swap. On the other hand, how do you feel the power difference between the two? Also, how are the LED head lights at night compared to the HID on the 2015 (assuming you had factory HID)?
Sync 1 is the basic model with the small screen. Sync 2 is MyFord Touch with the 8" screen. Sync 3 is the new version that only came on 2016+ Edge in the US. So since you have a 2011 Limited then it has MyFord Touch which is Sync 2.
Did you try the codes from the 2GFusion sheet, under Power Point Timeout?
You have Sync 2. For 727-04-01, you will need to change the "0001" to "0101".
There are several threads in multiple threads on how to use ForScan. This is one of them: https://www.explorerforum.com/forums/index.php?threads/new-forscan-update-allows-module-programming.442848/ And this: http://www.2gfusions.net/showthread.php?tid=4573&pid=80488
Yes, you can change it using ForScan, this is what you will need to change: 727-04-01 x*xx xxxx xxxx Tuner Region, Set the "*" to the following: 0=NA (North America), 1=GCC, 2=Japan, 3=Europe, 4=Asia Pacific
If you ask me, it is something with Ford's programming of the 6F55 when mated with the 2.7L (or the other way). The same thing is there with the Fusion Sport & MKX, they all seem to underperform relative to what they should be. The same transmission has been in the SHO & MKS since 2010 and they performed better despite being slightly heavier than the Edge & Fusion. I know that the SHO/MKS had the 3.5, but it's just to show that the tyranny has the ability to deliver.
2018 had Shadow Black. 2017 had Shadow Black. 2016 had Shadow Black. 2015 had Tuxedo Black. If you want to bother them less, buy touch up paint for both colors & then ask them which is theirs, give it to them & return the 2nd.
You need to do all the codes you quoted to enable the reverse mirror tilt. First code is to enable the option in the cluster to be able to select to turn it on/off. The other codes, 2 are for each door module (driver & passenger). -
Head Rest Adj.-For/aft-2012
omar302 replied to quincy's topic in Interior, A.C., Heat, Interior Trim
You could also look for a set of the newer style headrests, they are plug & play. -
How to remove Lane Keeping camera cover on 2018
omar302 replied to ccutaia1's topic in Interior, A.C., Heat, Interior Trim
See the attached file. Interior Rear View Mirror.pdf -
Sorry, wrong thread.
SSM 46025 - 2015-2016 Edge - Roof Opening Panel Slow To Close
omar302 replied to jmr061's topic in Recalls, TSBs & Warranty
Any updated info on this? -
Nothing really concerning. The AWD is nearly the same, only it has the added benefit of a drain plug to make draining the PTU easier.
I didn't notice it was only for the 6F50/55. Sorry. Searching now I couldn't find it for the 6F35.
From the 2015 Service Manual, "Torque: 106 lb.in (12 Nm)". Transmission Fluid Drain and Refill.pdf
FYI, the glove box door is large because it houses the passenger side knee airbag.
I think they were 8mm. I used a screwdriver that attaches sockets at the end.
One more thing to consider, the rear hooks in the cargo area on the side panels, they also might be loose in their position.
OK, then. That makes it more mysterious. Like what @WWWPerfA_ZN0W stated above, maybe take it to another alignment shop. Also, did the dealer provide before & after alignment readings? Might give an indication of what they changed.
Why were the tires replaced by the dealer and alignment done? Was there another issue? If everything was OK before, check the wheel lugs are tightened.
This is from the factory service manual: Liftgate Trim Panel.pdf This is for the removal of the rear light bar: Reversing Lamp RI.pdf I noticed there is sometimes a squeaking noise from rubbing between the lightbar and the rear lift gate. Might want to check it. Pushing on the lightbar against the liftgate would sometimes produce the squeak. Another possibly squeak, is from the pano roof between the glass and the wheatherstripping, especially the rear end, cleaning & silicone spray lube fixes it.
Just a comment from my experience with the 2011 MKX, although the fans come on with A/C, they run at a faster speed when ambient temperature was 30-32 degrees Celsius.
- 10 replies
- 2
- cooling fans
- radiator
