Everything posted by omar302
Attached. Headliner - Lowering.pdf
1. Yes,, two types. One for Edge with towing package and one without. 2.A. Not available. 2.B. Not available. Not advisable. Change complete assembly with Motorcraft/Ford only. Others have faced many issues with other makes.
- 2 replies
- 3
- edge 2013
- cooling fan
You can try the other method to disable Auto Start/Stop. See this post. -
Disappoinment - PTU drain and fill - capacity
omar302 replied to flymore's topic in All Wheel Drive (AWD)
Until someone knowledgeable chimes in, my take is the extra capacity was simply from the the previous overfill due to the front wheels up only, and the red/pink tinge is due to the mixing with leftover Royal Purple oil that was still in the PTU from previous change(s). -
I recommend the ones I installed a little over a year now. Posted about them here (link). They are brighter than stock and have the LED blinking effect. Makes the Edge feel a bit more modern. The same manufacturer/brand has an updated/upgraded bulb design, but I have not tried them. With the older design that I have, I can some areas when the signal is flashing how theoretically a full 360 degree illumination would make them even better.
Is it turned on in the settings? Maybe change it to high?
There is no zipper. See this thread for more details.
start car after lost FOB
omar302 replied to gonesail's topic in Alarms, Keyless Entry, Locks & Remote Start
You can hide a fob with the battery removed so the vehicle would not recognize it. Then, when needed, to start the vehicle just insert the fob (without the battery) in the backup slot in the center console and the vehicle will start and run. -
Congrats on your new ride. How is the difference between them?
I am not aware of any. However, I did not look for any, so maybe there is and I don't know about it. -
Found this new comparison video:
HOW TO add OEM Remote Start (2015+)
omar302 replied to colinc755's topic in Accessories & Modifications
I never had to try. However, on the private Beta ForScan (this post if you can open it) forum someone with a 2019 Edge confirmed it worked for him. Edit: post is quoted below. Big success today with 2.4.10 and PATS programming 2 new keys for my 2019 Edge. Warning: I take no ownership for anyone following in my footsteps. You're at your own risk. I'm just sharing my experience as there doesn't seem to be a lot of posts about successfully using this feature in the same scenario, except for a post I found on a Mustang forum. _______________________________- 45 replies
- guide
- remote start
You may want to try ForScan as they added BCM/BdyCM "PATS Programming" for erase and program keys function since version 2.3.56 (2023-09-07). I successfully tried PATS programming on older Fords, however, I have a paid license, not sure if it is a requirement for PATS or not.- 45 replies
- guide
- remote start
RDU Motor Actuator, failure advice? Part number?
omar302 replied to Gnerffed's topic in Brakes, Chassis & Suspension
Given how the RDU has a clutch pack and that it has a "calibration" setting that has to be entered into the PCM after installation, I don't expect it to be serviceable outside a factory.- 13 replies
- 2
- speed and position sensor
- rdu actuator motor
(and 2 more)
If your problem is only that the distance to empty (DTE) is showing more miles than before, then that is normal after the battery is disconnected. This is because after a battery disconnect the average mpg used to calculate DTE is reset to a default value. It will then become more realistic after a few fill-ups.
Sunroof auto close
omar302 replied to Oldone88's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Maybe a initialization will get the sunshade to close in one touch operation? The procedure is attached. Power Roof Opening Panel Initialization.pdf -
Sunroof auto close
As described above. However, the shield (sunshade) does close fully in a one touch close. At least it does on my 2016. -
*delete* double post.
Actually, the 2016 Edge does show individual Tire Pressures for each wheel. check this video at 5:28: https://youtu.be/th9tmsntRSw&t=5m28s
Long Story and Dealer Shaming
omar302 replied to Cerberus's topic in Dealership & Vendor Experiences
Normally extended warranties coverages are calculated from the original warranty start date. So make sure that yours starts from the current milage. -
May I ask, why change the tensioner or idler?
2017 EDGE TITANIUM STEERING BIND
omar302 replied to dukester4413's topic in Brakes, Chassis & Suspension
You need a different dealer. If the issue started just after the transmission repair/replacement, then it is probably something they did wrong. Raise to the Service Manager and also seek an another dealership. -
If the key fob is with you, you don't need to unlock the doors first. The button should work even if doors are locked. And yes, they did decontent the rear door intelligent access sensors. Just don't remember which year I personally like the hands free lift gate and I don't have issues with it accidentally opening or closing, maybe a few times only during the ~6 years of ownership.
