2010 Ford Edge strut and brake replacement
enigma-2 replied to tanman_2006's topic in Brakes, Chassis & Suspension
Btw, as your having the local Ford dealer do the service, request a Ford Credit card, they can apply right at the service desk, and if you spend over $200, you will get a Debit card back in tbe mail for $25, plus a year to pay it off with no interest. !!! They also run specials from time to time on brakes. The current specials are $100 for just pads or $180 for pads and turn disks. The coupons can be found here: http://owner.ford.com/maintenance/service-coupons-and-offers.html?gclid=CjwKEAjwm7jKBRDE2_H_t8DVxzISJACwS9Wb658oE-bDzlRXMgJ3O5rZCgQ1dw2jAsbUpg98fmVjBhoCWeLw_wcB&searchid=160581195||&s_kwcid=AL!2519!3!101616081795!e!!!!ford%20coupons&ef_id=WAFcsAAAAbKsCuFU:20170624233100:s -
Believe I would get the spark plugs replaced first. Then fluids, especially the coolant and transmission. I would regard this as essential, more so than the drivetrain. Then brakes for safety and lastly struts. -
May want to keep a eye on the power steering fluid just in case. When these little stinkers start leaking they rarely stop on their own. Wonder if a can of Lucan power steering stop leak would do the trick for $10? (Worked for me on a car I once owned). Lucas 10008 Power Steering Stop Leak - 12 oz https://www.amazon.com/dp/B000ARPVNO/ref=cm_sw_r_cp_apa_YZutzbFKQGGC5
You can look them up on tirerack.Com. They seem to have a good selection. https://www.tirerack.com/suspension/brand.jsp?to_desktop=true&gclid=CjwKEAjw-LLKBRCdhqmwtYmX93kSJAAORDM6QLIuMx3DjZhWw8-ykg_FhZCfNFfoUyYW_dMUhNCSSRoCV8Xw_wcB&brand=KYB&s_kwcid=AL!3756!3!201371895782!b!!!!+kyb%20+struts&ef_id=WAFcsAAAAbKsCuFU:20170623170440:s
Just think. Soon will all be driving Lincoln's and Ford's made in China. Theeeeeennnnn let's see you replace your thermostat. HA. You'll be trying to replace part number ?????????㊙.
If there's any possibility of a water pump, check the color of the oil on your dipstick. It should look like clean oil. If it's milky colored, get it in asap.
Fantastic. Good going. You mechanic like me, T-15, no problem, putty knife, kitchen fork, pocket knife, T-20, T-10, pliers, ha!
Wheel bearing wear and disappointed in failure rate
enigma-2 replied to macbwt's topic in Brakes, Chassis & Suspension
Oh man, and I've already got 100k on my MKX. Now I'll lay awake again tonight wondering when my bearing are going to fail. Thank goodness for this group, else I'd never have known about the bearings failing at 200k. Just one thing after another.- 7 replies
- 2
- mactfordedge
- mact
(and 2 more)
BAMR accordion gasket
enigma-2 replied to enigma-2's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Followup Thought about this thread I had started last May and thought I'd chime back in by saying that it's still connected and working well. It appears that the sun heating the accordion gasket is what caused it to loosen ans closing it when disconnected caused it to deform. Re-engaging the gasket with the rod reinstalled, closing and allowing the sun to reheat, reformed it to the original shape (which it continues to hold). -
If you are certain it's the windiw, my guess is the two clamps that secure the glass to the mechanism have loosened. To check this, you will need to remove the door trim and check the clamps for tightness. Here's a video from MacFordEdge on how he replaced a window glass. May help you to understand what's involved.
OEM HU signal processing options
enigma-2 replied to Bobcajun's topic in Audio, Backup, Navigation & SYNC
Not a recommendation but may provide a starting point. https://www.crutchfield.com/shopsearch/Automotive_5_Channel_amplifier.html -
You can initiate the process from either the key FOB unlock or the keypad on the outside of the door. You can set two different seat & exterior mirror positions into memory, one for you and one for the wife Once you press the key FOB to unlock the door, the seat should NOT move until you put the key in the ignition. To prevent having to react to the seat moving, hold off putting the key in the ignition, until your ready. The movement of the seat (how far foward, etc.) and the exterior mirror are fully programmable. And you can also turn this feature off. The full procedure starts on page 135 of your owner's manual.
Vista Roof question
enigma-2 replied to zrt8355's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Oh. I thought that was the duty of the wife. -
Uuuuuummmmmm, verrrrrrrreeeyyyyyy introsteningggg. Why would timing upset the PVC system?
Anything under the back seat?
AC blowing hot when sitting but cold while driving?
enigma-2 replied to 4x4's topic in Recalls, TSBs & Warranty
Not a place to go cheap. Use only Motorcraft fans. -
Vista Roof question
What's an owners manual? -
When either of the front side windows are lowered slightly (1/4 to 1/2), do you notice any additional looseness of the glass, when wiggling the top of the glass? (As compared to the back side windows which do not exhibit this sound). If not, it would eliminate the attachment of the glass as being the source. With the door(s) open, is either of the lower guide channel bolts', loose? (Lower down, below the latch). If not, that would eliminate the back, lower window guide channel. Unlikely, but when you press in on the door inner cover panel, the upholstered cover. can you reproduce the sound? What is the condition of the window weatherstripping? Is the sound, speed sensitive, i.e. more so at higher speeds or at lower speeds? Have you tried wiggling the exterior mirrors? Also the exterior mirror glass. When the sound occurs, try partially pulling open the door handle (not fully enough to actualky open the door. Eliminating the handle linkage).
Before you do that, get a cheap VOM or 12 volt test light, and check to see if power is getting to the switches.
I Agree with Ironpeddler, shop around. Even if you find a dealer 100 miles away, use their quote to bargin the price down (most dealers will meet any legitimate quote). My 09 have >100k and no problems other a they found a seal leaking around 92k. When it ha around 80k I had the PTU flushed and changed (they charged me around $60 or $80, forget). Ford mechanic used a suction device to suck out the old gunk and them replace with new. (Believe that also replaced the fluid when they changed the seal.) Ford dealer told me they thought that the seal starts to leak, causing a loss of lubricant. This causes the remaining oil to get gummy and stop lubricating. All comes down to catching the seal as soon as it starts leaking.
Kind of a shot in dark, works sometimes, try disconnecting the battery's negative lead for 5-10 minutes. Allow the electronics to reset themselves.
{I think we should ask him the cut a tranny (ah, transmission) in half next. Always wanted to see how they work internally}.
- 13 replies
- mactfordedge
- mact
(and 3 more)
Vista Roof question
I have a 2009 MKX and that's normal operation (make certain that the kids don't have their fingers in the opening when closing.) You w also notice that the interior shade also stops short when closing. Again, normal. Drove a 2016 Edge loaner a couple of days last week and the roof closed all the way with a single press. Don't know which years the changeover occured however. -
I'm curious, are you hypothysizing or do you know for certain that the seal fails do to not changing the coolant? Actually it makes sense, inasmuch as my serice dept urged me to change my coolant to a different type, before it was do to be changed. Said that the original type did not protect again corrosion (think that's what they said) and the new stuff was now what was needed. This was 2-3 years ago and all I remember wad it was a different color. Perhaps that has something to do with this? Great video and clear explanation, Mac. Keep up the great work, I'm certain I speak for evertone here that these videos are very much appreciated. I know I learn alot by watching.
- 13 replies
- 2
- mactfordedge
- mact
(and 3 more)
