Everything posted by omar302
They should recall all the previously shipped hoses from the same batch, even if the customer did not complain.
2011 Ford Edge Sync Replacement
omar302 replied to magnum3672's topic in Audio, Backup, Navigation & SYNC
Replacing the MyFord Touch screen with a used one should be relatively cheap. MyFord Touch is refferd to as "Sync 2". You can upgrade it to Sync 3 if you want a good upgrade (link to a thread). The Sync system is actually a module (APIM) and screen. You will need both in case of upgrading to Sync 3. Your vehicle might only have a bad APIM, a used replacement on eBay is like USD 150 only (example). You will need to program it using ForScan with a compatible adapter. Or contact @jmr061 who is a member here who might sell you one programmed ready for your vehicle. -
HVAC and ambient lighting issues
omar302 replied to stevie's topic in Interior, A.C., Heat, Interior Trim
The touchscreen is called the APIM. The faceplate with the touch buttons is the FCIM. As far as i know, the HVAC module is not related to, and does not control, the ambient lights. maybe check the fuses if there is a common circuit for both. -
Given your Edge is at the edge of Powertrain Warranty coverage (5 years or 60K miles, whichever first) and with a TSB already issued for it, maybe try to contact Ford customer service if they would cover it under warranty.
No, it can't. I have not found anything related to it in ForScan.
Cargo lid max opening height
omar302 replied to Edgingage's topic in Cargo, Hauling, Roof Racks & Towing
Maximum heightight is not adjustable on the 2011. For the Edge it was added on 2015+ models. For OP, I'd suspect that the lift struts (the normal gas ones) are weak, hence the motor is not able to get the liftgate to the maximum height. Especially considering they are now ~ 10 years old. -
13M01 - Middle East PTU Extended Warranty
omar302 replied to omar302's topic in Recalls, TSBs & Warranty
This recommendation started with the 2013 model, if I remember correctly. That is when they started having drain plugs for the PTU for Middle East models. That's why this extended warranty was issued. -
anyone have real world experience with Pre-Collision Assist?
omar302 replied to ben senise's topic in Lounge
There is a setting in the instrument cluster for sensitivity. At high, you'll probably get a lot of warnings. -
There are these from Veritek Performance, cheaper than Gorillas or McGards, for $40, but maybe stay with the chrome finish version, not sure the black paint will survive long term.
If you dissemble the remote completely, you'll find under the number pad small flexible "discs" glued to the button pad that make contact to the board when the buttons are pressed. I recall in some cases with this Fob design (used on 2011-2014 Edges) that the discs move from their positions and then would cause unwanted button presses. If that's your issue, try to positions them back correctly & maybe use a tiny amount of super glue between the discs & the button pad.
Member's details not shown anymore?
omar302 replied to handfiler's topic in Forum Help & Site Suggestions
Problem is that signatures don't appear in the mobile view of the site. -
In Sport mode, if you shift manually it'll stay in manual mode and the display will remain on until you exit manual mode. Other than that, there is no way except with a tuner that supports it, Livernoise is NOT one of them.
Service Charging System Now
omar302 replied to Nick Halstead's topic in Interior, A.C., Heat, Interior Trim
See the attached from the service manual, in case you haven't already. P065B doesn't look easy to diagnose. Charging System - 2.7L EcoBoost 3.5L Duratec D and T.pdf -
Any DTCs? Use ForScan with a HS/MS-Can capable adapter so you can read codes from all modules, not just the PCM codes. -
would forscan code mods be the same on a 2020 as a 2016?
Just don't do changes no one tried before, even though you can revert the changes, there was at least one owner who made an irreversible change because of some security issue. I don't remember what it was exactly, but it happened to him when he used ABD mod data from a different generation on his Ford. -
2014 Cup Holders - no rubber liner?
omar302 replied to DavidE's topic in Interior, A.C., Heat, Interior Trim
This (link)? It looks like there is only one part number, so both might be using the same one. -
What I was referring to is not a user selectable setting and I did not try it.
Asking for opinion. I have the ESP Premium coverage on a 2015 MKS, the heating function on the driver's side outside mirror is not working and the dealer diagnosis determined that the fault is from the heating element that is part of the mirror glass. ESP Premium (attached) states under "Electrical" the following coverage: "Power Mirrors (Electrical Only – Not Mirror or Glass Damage or Bulbs) Dealer declined to fix it under ESP stating that the mirror glass is not covered. In my opinion, since the fault is electrical and can only be fixed by replacing the mirror glass, which is not broken or damaged, then replacement should be covered. I had raised my concern to our area Ford representative and they sided with the dealer. Do you think they are right? 516069_01_PremiumCARE_6_15.pdf
With ForScan, I recall there is a setting in IPC to use imperial gallons. Also, usually such settings change with the country setting of the IPC, again using ForScan. Things that change with country for example, in US it says "Door Ajar" instead of "Door Open", "Hood Ajar" instead of "Bonnet Open".
thinking of trading my '16 Ti for a '20 ST and I have a few questions
omar302 replied to ben senise's topic in Edge ST
Congratulations. Enjoy the new ride. If the 16 has a black interior, might want to consider taking the left drawer from it and replace it with the cover from the 20. It just pops out/in See this thread. -
Locked out with both keys inside
omar302 replied to 1004ron's topic in Alarms, Keyless Entry, Locks & Remote Start
That's good to hear. Try again to get the code using the 2 key method stated in the owners manual, I just tried it on my 2016 and it worked. (comments in red are mine). -
I am actually surprised it locked. If a keyfob is inside the vehicle, it is supposed to unlock automatically if you close the door with it locked, unless you locked it using the keypad (pressing 7/8 & 9/0 buttons simultaneously) while the doors where closed. I suggest you then remove the photo or blur out the code. In many cases, the keypad code is with the owners manual, if you happen to have it outside the vehicle, check inside the owners manual pouch for the card. For a 2016, this is what the card looks like:
