Everything posted by omar302
2017 backup camera blue screen
omar302 replied to Skwerlee's topic in Audio, Backup, Navigation & SYNC
Master reset will reset the settings & erase user data, sometimes reffered to as a Hard Reset. The CD eject button + ">>" will simply restart the system, a Soft Reset. -
OBDLink Announces New Wired OBDII Reader
omar302 replied to Gadgetjq's topic in Accessories & Modifications
As per the ForScan Dec. 10 update, the team was involved in the development of this adapter. So it should good. -
You can enable a small vertical tach to be displayed next to the fuel gauge when the round tach is not selected. It should be under Settings>Display>Gauge Display.
I remember that on 2013 they changed the rear seat center arm rest. For the front they started using a different type of headrest in 2012, but that is interchangeable so you can use the new style on older models.
On pre 2015 models the battery management system can be reset by leaving the vehicle uninterrupted for 8 hours as @WWWPerfA_ZN0W stated above. Newer models need ForScan or a dealer to reset the battery age. At least that's what I understood from my readings on the systems. Also, on my 2016 with a new Motorcraft battery, it does not go above 80-85%. So it is either programmed like this, which makes sense as it is generally followed not to keep batteries charged to near full capacity to get a longer service life, or that even my Edge has a fault. Another thing, there is a As Built Data setting in the BCM that has to do with battery type/model, but with both my current Edge and previous MKX it did not match the actual installed battery from the factory.
Rear window shattered today
omar302 replied to Bwfulton4's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Found a copy of 17B39. Attached. CSP 17B39 Rear Hatch Glass breakage.pdf -
Keyless Entry 2017 SEL
omar302 replied to Needle's topic in Alarms, Keyless Entry, Locks & Remote Start
Welcome to the forums. To answer your question, if you lock a fob inside the car you wouldn't be able to open the from the outside, unless you have the other fob with you of course. The door intelligent unlocking feature of the fob only works when the fob is outside the vehicle neer a door. -
Yep, that's how it works, I must've miss-understood what Jombi first posted.
Sorry, I don't know. But I'm sure someone will sure be able to answer your question.
I believe it is the computer assisted cranking system.
If I'm understanding correctly, you supposedly got the TSB done? Shouldn't the LMS tune be updated to the new PCM strategy before loading the it?
Is it a mistake to purchase OEM size tires (22)?
omar302 replied to Cedarburger's topic in Wheels & Tires
Since you already bought them, don't ask ?. -
2016 Edge Titanium - Lower Doors Full of Gravel
omar302 replied to cleekoguy's topic in Exterior & Body
The TSB @2FAST4U is referring to was posted in this post: -
Welcome to the Forums. A very long first post ?. Hope it remains fixed. I don't remember a similar issue being reported before due to the MAF Sensor or cleaning it. There is always a first time (or my memory is is not good).
Just noticed this. On my 2016 Edge, when the low fuel pop warning comes up it does NOT show the distance to empty. I have to clear the message and then go to a screen display that shows distance to empty. The 2011 MKX I had before showed the distance to empty like above, was annoyed by this in the 2016.
I dont know if my horn is weak or broken
omar302 replied to Carmen S's topic in Audio, Backup, Navigation & SYNC
If I remember correctly, the horn for 1st Gen Edge is behind the bumper on the passenger side and removing a headlight requires removing the front bumper. But I also remeber it that the horn was accessible from the wheel well, just remove the screws holding the wheel liner to the bumper. -
It is mentioned in the owner's manual that running out of fuel causes damage not covered by warranty, though I know of several owners of late model Fords that continuously run very low on fuel and actually ran out several times with no I'll effect on the fuel pump. I guess the cats would be more affected due to the misfiring caused by running out of fuel.
Once you get to "0" miles to empty, you will still have few miles to go. There is a considerable reserve.
Yes. Exact same issue. Very annoying. On the hole idea, I remember some early Edges (previous gen) had a whistling noise caused by an incorrectly sealed mirror at the bottom. With how aerodynamically mirrors are designed I would be worried from the side effects. Also I've noticed water coming from in-between the folding part.
2016 Ford Edge Rear Camera Is Not Sharp
omar302 replied to RBM328's topic in Audio, Backup, Navigation & SYNC
Usually the Edge's rear view camera is considered a very good one, at lease from my observation. But also on my 2016 Edge I started to notice that depending on the angle of light that is coming from behind it would show the image and as though the lens is dirty. Probably a defective camera that had some moisture come inside. -
Can Forscan enable showing the active gear?
omar302 replied to Jombi's topic in Accessories & Modifications
If you're planning to get a tune, I remember someone saying Torrie from Unleashed was able to do it with his tunes. LMS tunes does not. -
From this post on the 2GFusion forums, I was able to disable the feature where the HVAC blower speed would go to a low speed during a call on bluetooth. Also, at least on the latest build, ForScan already has this feature under FCIM. 7A7-01-04 x0xx (for my Edge, stock was "8", changed to "0" when disabled).
