Everything posted by omar302
Didn't find the updated Edge on Ford's China website, but found the brochure for the 2016-2018 style. Some very interesting pictures there. Download page. The PDF is 30mb and I couldn't attach it. Note: Weelbase is 2850mm (112.2") which is identical to the US Edge. While length is 4878mm (192") that is 3.9" longer than the US version.
For me, when it failed i did get the message. But having no red light come up definitely means something is wrong. To check if your vehicle was reading the old keys correctly, you try the procedure for displaying the factory set keyless entry code. It reads the 2 keys then, if successful, displays the code in the message center. -
Sorry to hear that. Are you getting a message in the cluster that the programming failed or nothing at all? -
Can't really answer your first 2 points, though probably there won't be any solutions, for the time being at last, as these feature are still relatively new. But for Start/Stop, the button is for the engine shut-off during idling while in "D" with your foot on the brake pedal to save fuel. It has nothing to do with the cruise control "Stop and Go" feature. These are 2 separate features.
Who doesn't like new things ?. I needed an extra "spare key" and thought of getting the new style. It is of higher quality, built sturdier, the LED is more visible and the buttons are less likely to pressed by by mistake while it is in your pocket. -
Want to do a few changes in my signature...
omar302 replied to 2FAST4U's topic in Forum Help & Site Suggestions
Assuming you are on the desktop site, click on your name at the top right. From the drop down menu, click on "Account Settings". On the left, you'll find "Signature" at the bottom of the list. -
Today I went to one of our "professional" wheel shops and asked them to toque the wheel lug nuts to 220 NM (162 lb-ft), and all the workshop guys were surprised. They were afraid it would strip the studs and only went to 200 NM, gradually. So my question is how many here actually torqued their wheel lugs to 162 lb-ft and for how long? Also, did they have to remove the wheels later on for any reason, confirming out of actual trial that there is no reason for concern torquing them as specified?
Update on the remote, I had the blank key from the new style remote cut and it works smoothly unlocking the driver's door and the glove box. Also, As I now have an extra fob, I removed the batteries from one of the old ones and hid it in the car. Now the car would not recognize it, but if I get in using the keypad and place the remote (without batteries) into the back up slot in the center console I can start the engine and drive. Did it work? If not, to test if the remote works (at least partially) is to do a remote start, it should fail and then the led would flash red several times. -
For whats its worth, Ford's TSB 18-2339 for fixing "Dirt/Dust And/Or Ice Accumulation At The Bottom Inside Of Doors" also involves replacing the rear door "rear portion" weatherstripping with updated parts and a "Grip Tape" that helps hold the said weatherstrips better. In addition a "Foam Patch" is also installed on the door itself to better "push" against the weatherstrip. TSB 18-2339_2015-2018 Edge dirt, dust andor ice accumulation at the bottom of the inside of the front andor rear door openings.pdf
Changing 2019 Edge's weak single horn to dual horn
omar302 replied to 9mmbullitt's topic in Accessories & Modifications
Nice work. I think there is some confusion around the 3:10 mark, the step for removing the original horn comes after trying to install the new horn. Maybe an error during stitching of the video clips. -
I programmed a 3rd intelligent access key. Used the new 2019 style fob. Read how many Raptor & F-150 owners did it, so decided to try it myself. Mind you, my fob is different from US versions having no "Panic button" and using the 868 MHz frequency, US use 902 MHz, if i remember correctly. I purchased this FOB and this blank key from eBay (same seller). Followed the instructions in the manual, took many tries until finally it worked. My problem was with the last step, after putting the new fob and pressing the ignition start button nothing would happen so i'd press it a second time thinking I did not press it correctly and then a message comes up that programming failed. The last time after pressing the ignition button (nothing would happen) left it a few moments and it programmed successfully. Another note, the manual states to have the buttons facing back, but that is not correct, they need to face UP with the key ring facing towards the back of the car. Another thing, when programming the new style key, remove the key so it fits better in the back up slot. Edit: Update on the remote, I had the blank key from the new style remote cut and it works smoothly unlocking the driver's door and the glove box. -
It is my car. Took the video myself ?. What is different?
First Photo Shoot - "The Eagle"
omar302 replied to JacobZ06's topic in Appearance - Detailing, Wash & Wax
Nice ride and nice photos. Take care. -
On my 2016 Edge I found out that it will relearn the positions of the tire automatically after a tire rotation.
It is normal to have 3-5 psi change between readings from a cold tire (parked overnight) and a hot tire (ex. 10 mile ride). Also, the TPMS low light would come on when the tire is around 25% under recommended pressure, for the Edge the recommended pressure is 35 psi and the light would come on around 26-28 psi (not sure exactly). From what you have explained and see anything unusual. Also remember that the readings are sent from each sensor every 2 minutes or so, so there might be bigger differences between tires depending on when the system updates. One last variable is the rounding of numbers, 35.4 & 34.6 will both probably read as 35, but then one will read 36 psi much quicker.
Welcome. Nice pair.
This is what they did with the previous generations of the Edge & Explorer as part of a TSB to fix exhaust odor that was entering then cabin at high acceleration cases. Edit: I just remembered I posted pictures about it when it was done to my old MKX.
2015 Edge Sport 2.7 Ecoboost - Code P1450 - Purge valve
omar302 replied to druegeme's topic in 2.7L EcoBoost
@Scott98 See the attached if it helps. Evaporative Emission Canister Purge Valve 27l.pdf -
2019 ST instrument panel update to 2020 ST??
omar302 replied to Ryno99's topic in Accessories & Modifications
Ours would have KPH on the outside and MPH on the inside. I'd always know it's is not the correct one! Bad case of OCD. -
Did someone had to ORDER their Edge?
omar302 replied to 2FAST4U's topic in Buying, Leasing & Ordering
Congrats @2FAST4U, nice ride. Also those wheels are amongs the nicest on the Edge. Definitely better looking than the ST's wheels. -
Is it possible to remove that orange banner at the top (Edge ST enthusiast)? Or suggest to make an option to dismiss it. It just feels like there is a warning every time I access the site.
There was a message on it with Ford foe a fix. Though it seems what @onyxbfly suggested might be a similar fix. https://ford.oemdtc.com/3616/remote-start-selections-grayed-out-for-heated-steering-wheel-heated-seats-2015-2018-ford-edge-2016-2018-lincoln-mkx
