Everything posted by omar302
Adding Photos / Media to a Post
omar302 replied to Edge Guide's topic in Forum Help & Site Suggestions
How do you post a YouTube video in the post? Previously all I did was paste the link & it automatically embedded the video, now it just leaves it as a link. -
On the 2015+ model, there is no raised area, only a ribbed area that is easily touched by mistake when holding the door handle, especially if try to open the door at an angle from the rear, like when near the rear door and reach out to open a front door. Here is a video of a Fusion that has the same design door handles:
I don't know if it does have a sound tube, probably not since it was not mentioned before. Does the sound come when you in Sport mode? If yes, try shifting to Drive and see if it goes away. In Sport mode, the transmission only goes to 5th gear, so the engine would be at a higher rpm and that might be what's causing the sound. At least that's what I feel in my sport.
- 1 reply
You'll need to compare the ABD for 2019 vs previous models to see what changes are there. I would think it will will require a software upgrade, not just an ABD change, would be hard to believe that the software from 2015 had the feature 4 years before being implemented, but everything is possible. A good person to ask is DAN from the 2GFusion forums.
- 1 reply
- 2
'15 SEL remote start options
omar302 replied to dexmann1's topic in Alarms, Keyless Entry, Locks & Remote Start
I wouldn't rely on a phone call with the dealer. They should look at it & try. If they can't fix it, they should ask Ford how to fix it. Since your warranty is close to ending, take it to a good dealer so at least it will be in their records that you have an issue before the warranty expires. -
Congratulations. Hope you enjoy it.
With my 2016, something I don't like I just remembered, the rear camera. 2 things: It shows a good portion of the rear license plate, feels like wasted space that the camera could have shown more from the top. What you see above the license plate is actually part of the rear hatch. You cant see the rear bumper! This is what I mean (not my Edge):
GPS not working in navigation
omar302 replied to riche_guy's topic in Audio, Backup, Navigation & SYNC
I'd disconnect the battery for about 10 minutes & then see if it fixes it. -
Congratulations on the new ride. Hope you enjoy. Good review. For the fuel door, it does not lock. Most (all?) Ford vehicles are like this. You can get a locking cap if your worried & need to. For the headlights, you can also go for factory HID by replacing the complete headlights & making a few edits in ForScan.
I don't recall reading a similar issue. Was the replacement windshield OEM? If not maybe it doesn't have the noise isolation layer.
This topic has good info regarding the Active Noise Control on the 2015+ Edge Sport.
The 2020 Explorer based Interceptor Utility with the 3.0L TT was quicker in 0-60, top speed and lap times than the Dodge Charger Police versions (both RWD & AWD). And it is expected that the the Explorer ST will be based on this Interceptor Utility. So the future of Ford Performance SUVs still looks bright ?.
Yep. 0.35 L to 0.7 L. Silly mistake.
I am surprised dealers don't know that Ford now has a new much cheaper solution.
I didn't know that. Thanks for the info, just checked the owners manuals of the 2011 & 2016 the fluid capacity doubled, from 0.35 ml to 0.7 ml.
Just as what Nick said, 2015+ models use the same Bolt pattern. Your 2013's wheel are different. Another thing I am not sure of nor did I see it mentioned before, is whether the ST's Brake Performance Package has bigger brake hardware that might not fit in a 18" wheel.
I have had the Vredestein Ultrac Vorti (summer tires) on my Edge Sport for about 9,000 KM, and they are good. They are not listed on Tirerack, so they might not be known in the US. They are made in the Netherlands.
2014 Edge Defrost System Problem
omar302 replied to Beerfoot's topic in Interior, A.C., Heat, Interior Trim
I would suggest that you should pretend to take your Edge to a dealer to fix it. From pretending to read the posts in this thread, it seems the most likely issue is that the HVAC module needs to be re-programmed as per TSB-14-0062 posted here which probably only a dealer is able to do. -
Congratulations. Enjoy your retirement. Seems you are now spending more time here
Do you sometimes get the message to shift to park when you turn off the car?
- 5 replies
- starter
- automatic starter
- (and 3 more)
The best Bluetooth adapter, as far as I know, is the OBDlink MX and connects to both HS & MS CAN in Ford vehicles automatically. Though it is a bit pricier than others.
2016 Edge Sport Liftgate Will Not Open
omar302 replied to ezndo's topic in Alarms, Keyless Entry, Locks & Remote Start
That is definitely not a user friendly procedure. And surely more involved than earlier models. Seems there is a cinch release button for vehicles equipped with a power lift gate that needs to be pressed. Then, for all vehicles, you'll need to insert a a 3.5 mm wide flatĀbladed screwdriver through the access cover opening at a 45 degree angle for 10 mm deep on the right hand side then 5 mm deep on the left side.
