Everything posted by omar302
The real solution to the double honk is to just use a soft beeper, mmm..., like most other car manufacturers. You get both, a reminder AND not be annoying to others around you. Nissan for example has been doing from 10 years. Also, take into consideration that Ford only added this feature midway through 2012, all 2010 & 2011 Ford & Lincoln vehicles with IA key did not have the double honk, how many complaints where there of people forgetting their keys? None that I have seen in any Forum I follow. Never did I also see anyone with a 2011/2012 trying to enable this feature. -
The MKX's hood looks shorter, the Edge's seems to have a longer downward curve at the end where it meets the grille.
- 9 replies
- hood
- interchangeable
- (and 5 more)
There should be a "write all" at the bottom, this should do it in case there is no write button at specific lines. -
No. They have different part numbers, so they are different. 2007 MKX 2007 Edge
- 9 replies
- hood
- interchangeable
- (and 5 more)
Broken Wiper Motor 1,700 miles
omar302 replied to ezndo's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Just take it back to the dealer & tell them the wipers are not working properly. Don't point to the broken motor, let them just fix it. -
Brakes briefly turned to mashed potatoes
omar302 replied to TheFloppyWeasel's topic in All Wheel Drive (AWD)
If the traction light came on briefly, then it might have been the stability control system engaging, which uses the ABS to modulates individual wheel brakes to prevent or reduce a skid. It would also make sense since you were turning. -
2007 Side View Mirror
omar302 replied to skynyrdmh's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Yes, the glass fits. There was a very long thread on it. As for the housing, they probably interchange, but you need to check if the wiring is there for the puddle lamps. -
2011-2014 Parasitic battery drain
omar302 replied to fishx65's topic in Audio, Backup, Navigation & SYNC
If I don't lock the vehicle from the outside (remote, keypad or IA), the displays remains on for quite some time. As for the battery dying after a week or so, the 1st question will be how old is the battery? -
Using ForScan with a compatible adapter you can re-program the camera yourself.
2016 edge liftgate light
omar302 replied to Decker's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Yes lildisco, your right. B not A. I edited my post accordingly. -
Looking at the price difference, w/level 2 trim part ending with "B" is the lighted one. https://www.tascaparts.com/auto-parts/2016/ford/edge/titanium-trim/3-5l-v6-gas-engine/electrical-cat/reflector-scat -
2012 Mirror wiring
omar302 replied to vigness's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
This link is for a 2013, for some reason the 2012 is not appearing, but the 2013 mirrors should be similar to 2012. -
Type and grade of engine oil change for 2011 Edge SEL FWD 3.5L
omar302 replied to Edgingage's topic in 2011 Edge & MKX
If I remember correctly, only the filter cover & tube, not the whole Air filter box, maybe only the tube from the throttle body end. Are you using Internet Explorer? I remember facing the same issue on Internet Explorer, now i'm using Chrome & all is good. -
Engine Cranks but don't start says Low oil pressure
omar302 replied to Looking for Help's topic in Mods & Tech
How about take a video of it & show it to the dealer. -
Just trying to see if there is a reason, I know both your Edges are FWD, but do any have the Tow Package?
Admin Keys maxed out???
omar302 replied to vega's topic in Alarms, Keyless Entry, Locks & Remote Start
Dealer or a locksmith that has the right equipment. As far as I know, there is no way for a user to do it. -
In my car, I saw the oil in the throttle body, in other words, oil was going from the PCV valve through the tube towards the throttle body, but not towards the air filter. -
I think that is a generic photo. The same MotorCraft number leads to the Strut only (no spring) part in other sites, like RockAuto & EBay.
How old is your car's battery? If it is 2+ years, then probably it needs replacement.
So how much did it end up to be?
Only the PC version can modify as built data. You can u send the Bluetooth version or Wi-Fi, I am not really sure, but I think the Bluetooth version was better. -
There is no Edge specific list, but generally, ForScan mods (As-Built Data, ABD) are similar amongst other Ford vehicles of the same generation. For the Edge, you can follow these: 2015+ Edge is similar to: 2016+ Explorer 2015+ F-150, Mustang 2013+ Fusion The 2011-2014 Edge is similar to the 2011-2015 Explorer. MyFord Touch (MFT) & Sync3 ABD (APIM) are usually irrelevant to the year, if a MOD is applicable to MFT, then it applied to all years with MFT, same goes to Sync3.
