enigma-2
    294
  1. Be very careful about which wheels you stick on your car. There is cheap junk coming in from China that may not hold up on the road (potholes and simular hazards in particular). https://www.tirerack.com/wheels/tech/techpage.jsp?techid=90
  2. From what's been discussed here, installing a catch can on these engines would seem to be beneficial. It doesn't appear to be a correlation between how hard you drive it and the carbon buildup. As the valves are not being washed by the gas spray there will be buildup. Driving harder will only cause more blowby, which in turn allows more oil and blowby to be drawn into the intake causing more buildup on the back of the valves and valve seats. As for using 91 octane, it would seem realistic to believe that Ford Engineering thoroughly tested this engine under all circumstances and found it acceptable. By reducing the knock, the computer may attempt to lean the mixture in an attempt to reach a point where the knock can be sensed. Years ago, Ford used to produce a magazine entitled Ford Times. I remember reading an article one month where they discussed the reasons you should NOT use higher octane gas. They (Ford Engineering) wants the engine to knock so the computer can measure it and compensate properly. Otherwise it will go lean attempting to compensate and the engine runs hot.
  3. https://www.tirerack.com/wheels/results.jsp?autoMake=Ford&autoModel=Edge+SE&autoYear=2012&autoModClar=AWD&package=false If kona blue is not selected, tap on the color wheel near the picture of the edge and select it. Then you can try out all of the different wheels and see what each would look like. (Note I tapped the SE instead of the SEL, and AWD instead of FWD, but I don't think it will make any difference.) PS forgot to mention, if you click on the arrows next to the 5 wheels shown, the next (or previous) five wheels will be displayed. Then just click on whatever wheel and it will be placed on the car.
  4. The NHTSA opened an investigation on the Edge door ajar issue in October. The dealer cost (I believe) is around $400. However it's an easy fix, abet time consuming and there are seveal videos on YouTube on how to remove the door panel and replace the switch attached to the latch. Looks like a two hour job.
  5. The rule I'm familiar with is a drop of 20% when you drive it off the lot. 50% seems high.
  6. Take it over to a reputable body shop and see what they suggest.
  7. I can't imagine 32's on 17" wheels. Love to see a picture when you get them installed. Must have one hell of a sidewall.
  8. I was hit from behind in January, knocked one sensor through the bumper cover, still attached electrically and faced the inside of the bumper; beeping constantly when shifted into reverse. These senders are very rugged and I would bet they are not damaged. As you are not getting any signal, my 'guess' is the harness was damaged.
  9. This may offer an understanding of the different types. http://www.ebay.com/gds/Truth-about-CANBUS-Error-Free-AutoLED-/10000000205123542/g.html http://store.ijdmtoy.com/Canbus-Error-Free-LED-Bulbs-FAQ-a/490.htm
  10. As it's been a year and you still haven't found the source, can you id the color of the fluid? This will tell you if it's automatic transmission fluid or power steering fluid (or something else). Here's a guide: https://blog.allstate.com/find-the-fluid-identifying-your-cars-drips/
  11. My guess after reading this is they seen something in the tread that indicates an alignment problem. Like cupping or excessive wear in one zone of the tread. If I were you, I would ask why they are recommending an alignment. If it's been more than a couple of years and the tires are worth saving, may not be a bad idea to consider this. (After all, all it takes is one chuckhole to throw the alignment off).
  12. Another way to try if you have MyFord Touch 1.Access your Settings Menu by clicking the cogs located next to the Home Button. 2.Select Settings from the list on the right side of the screen. 3.Select System at the top of the list. 4.Scroll down until you see Master Reset, then press it.
  13. .... and, as complex and interactive the electrical and mechanical systems are nowadays, often times its better to just bite the bullet and go with the pro. I remember rebuilding my 56 Ford Vicky automatic transmission when I was in high school. (Had to, my dad refused to pay a mechanic to do it). But the modern ones are a real trip compared to those. Now days you have to go to school for every little system else your just guessing. (Course at my age, auto mechanics is not worth the trouble ....).
  14. Phone should work, only problems (if there are any) will probably be in the messaging area. But the phone manufacturers generally catch up with an update in fairly short order.
  15. ?? http://www.discountfordpartsfromsoundford.net/product-p/yl8z-13a457-aa-5355581.htm
  16. This may be overkill but does a good job of covering the subject. http://www.autotap.com/techlibrary/about_flash_reprogramming_pcms.asp
  17. When I bought my car (used), it was obvious that it had not been changed in a long time (years). It was filthy, but it was not black. Full of dirt and bugs, but it was still mostly white. The only filter I've ever seen that was uniformly black was a charcoal filter. I can't imagine what kind of air you drove through that could turn a filter black (soot?).
  18. That looks exactly like the one in my MKX. That's a charcoal filter, it's supposed to look black. One way to tell how dirty it is, after you remove it, hold it up to the sun and look through it. A really dirty filter is difficult to see sunlight through it. This is the filter I use on my 2009: ATP Automotive FA-14 Carbon Activated Premium Cabin Air Filter https://www.amazon.com/dp/B004A6NBO2/ref=cm_sw_r_cp_apa_rhmVybTZX85QQ Notice it looks black right out of the box. I spray the filter with this filter spray to improve its efficiency: PuraClean Filter Spray https://www.amazon.com/dp/B0145I072I/ref=cm_sw_r_cp_apa_GkmVybXHJXJAJ I use this on my furnace filters to improve their efficiency.
  19. I may be reading more into this but you wrote that you "oiled" the roof tracks. If you are, I wold be surprised that you even got three months out of it. Oil is the worst lubrication you can use. (Oil forms a film and attracts dirt and grime, the worst combination for this type of service). If you have never viewed Mact's video (part 1 is above) I really recommend it. The Lincoln service manual recommends the use of silicone spray. But I would only expect this to last about 6 months up a year. I use a light film of Super Lube. It's a synthetic oil that contains PTFE. A good clean rail should remain (fairly) clean for a year. (And in warm weathe t, I open and close my roof several times a day, I open it as soon ax I get in, close it whenever I park and always close it at night in the garage. So you are not using your roof more than most.
  20. I switched to Philips X-tremeVision. Well satisfied, better than my Silverstar's.
  21. There are two different types use on Ford engines, the two pin are variable reluctance types and the three pin are Hall-effect types. But I have no idea what they would ohm out at. What codes are you getting?
  22. One possible explanation for loss of coolant is a faulty water pump. Immediately check your oil to see if it has a "milky color" on the dipstick. If it does, the water pump seal is leaking coolant into the oil pan, diluting the oil and will destroy the engine. It's also possible that you may be able to smell coolant in the oil if the amount of coolant is excessive. (Don't drive your car under these conditions, have it towed to a service shop.) Problems with a Vista Roof are usually traced to a lack of lubricant. MactFordEdge has an excellent YouTube video of how to properly clean and lubricate the tracks.
