enigma-2
    294
  1. If one of the low beam headlight bulbs have a problem, there is a symbol that looks something like a gear. (But I believe it's amber in color). The color of the symbol indicates the urgency of the warning/caution. Blue is an information color. About the only symbol that's blue is the high beam indicator.
  2. "The DTC sets in continuous memory and on-demand if the voltage supplied to the ABS module is less than 10 volts, if there is an open or high resistance on the ABS pump motor circuit between the ABS module and the HCU , or if the ABS module is faulted internally." I had a simular issue, finally traced it to the pins on the rear brakes not allowing the rears to apply properly. After they froze, the majority of the braking force was taken by the front pads. Very soft pedal. Also low pedal.
  3. Mirror tap comes with several size pins to fit any mirror connector. During the installation, you choose the correct size (there's a chart on their website). You make have bought one of the Chinese knockoffs. To secure the harness, it also comes with a plastic wire tie. I found It's more than adequate to secure the harness, including having my radar detector's windshield mount fail; causing the detector to drop.
  4. According to the charts, on the 2010, the center bore is 70.5 mm & on the 2013 it's 63.4 mm.
  5. If you still have the piece knocked loose, drop it in water and see if the plastic sinks or not. ABS sinks in water (specific gravity: 1.06), polypropylene floats (specific gravity: 0.946).
  6. Or mask it off and spray it with a coat of clear coat. (UV-Resistant Clear Gloss) https://a.co/d/guV1ZKJ
  7. Check with your local Auto Zone. As long as they have Instacode software, they should be able to program. Typ prices vary from $85 to $400 depending on the type of fob purchased.
  8. You go with OEM pads & rotors; or ?? Go with SS nuts, or stay with OE?
  9. Manual states its 18.4 gallons for FWD, 18.5 gallons for AWD. How far off is your gauge?
  10. This reminds me of a simular discussion on p&p connectors discussed back in the spring of 2021. It centered around how to remove the cowling surrounding the mirror and the two (or three) different connectors used because of different mirrors. If I remember there was a five pin (or may have been six pin) and sixteen or eighreen pin. (Tried to use the search function but couldn't find it).
  11. Mix and match the instrument cluster to your hearts content. Just popped up on YouTube today.
  12. Drop by you local dealer and ask them to printout whatever maintenance history on file with Ford. Granted the previous owner(s) may have used non-Ford service, or even did his own; but a well-cared for Ford is usually serviced through the dealership for the first few years, and the service history will be on file.
  13. May be better to take to car to a professional mechanic rather than fire a parts cannon at it. While a O2 sensor can cause this code, so can a faulty catalytic converter, engine misfire, leaking fuel injector, exhaust leak & an O2 sensor that has improper readings (not just voltage output but correct analog readings).
  14. Could always try turning off the lighting in settings and then back on. See if that would reset to module. If not possible a battery disconnect for a minute or two, to reset all modules and let them rediscover their connections.
  15. Try a relearn procedure for the sensor/module. On the HVAC panel controls, press the A/C and Recirc buttons simultaneously, then, release both. Within 2 seconds press the A/C button again.
  16. You could try entering the info for your edge in the Crutchfield site. See what they recommend. (Don't be surprised if they tell you there is no aftermarket recommendation). https://www.crutchfield.com/S-G3Dy9q9k1QB/car/outfitmycar/mycar.aspx
  17. This video shows a simular problem (latch intermittent). In his followup he reported he changed the latch for $151.
  18. Still would hurt to get the CCA rating checked (not just voltage as weak battery may show 12.4 volts after charge but can't hold charge). Does the latch click when you try to open? Strange that the shifter seems to affect whether it opens or not. Next time it doesn't open, try wiggling the shift lever (not actual shifting). There is a way to unlock & open the liftgate manually.
  19. Why not just wire to the mirror wiring? Slap in a Mirror Tap (or similar) harness. No direct wire connection (pins slip into harness connector, wire tie to wiring harness or mirror body. Took me 5 minutes). On my MKX, power goes on when engine starts and off when door open (after car shuts off).
  20. It would be expensive as hell. Harnesses, modules, programming. Possibly different motors (need feedback as to position). Keep in mind there is more than just the seats involved. Exterior mirrors, drivers window, select switch (not on non-memory models). You'd need to start by getting a hold of 2018 wiring diagrams for memory/non-memory setup and compare the differences.
