Everything posted by omar302
Can Instrument Cluster Screens Be Updated?
omar302 replied to kevin_ramoutar's topic in Accessories & Modifications
2017 Edge Brochure attached. 2019 is different because of the facelift. Ford Edge US 2017.pdf -
The Edge in Europe is more premium than in the US. You also get leather wrapped dashboard & carpeted cargo area (sides). For the US, people wanting a more premium 2-row crossover can go for the Lincoln MKX which is not offered in Europe. The only (and main) thing better in the US Edge is the 2.7 EcoBoost engine ?. -
See this this thread for some pictures and more details. -
It is good that they made some improvement, but was hoping they'd just use the 2016-2019 MKX style cluster. For your question, I highly doubt a dealer would be able to upgrade it. It probably will require flashing the 2021 Firmware on the older cluster which dealers wouldn't/can't do. -
It seems it is part number BE5Z-14A664-A. It's only $60 here and is shared with the Ford Fusion, Mercury Milan & Lincoln MKZ.
This recall is specific by Ford Motor Company which is usually responsible for vehicles sold in North America. There might be another recall by Ford of Europe. But since the Euro Edge had/has a different engines & transmissions, the front brakes might also be different and hence might not be affected.
If you are into DIY & mods, you can add it. See this post.
There is no filter to be changed. Only the fluid is changed.
Interior Bulb Sizes?
omar302 replied to CameronDouglas's topic in Interior, A.C., Heat, Interior Trim
I don't recall anyone here doing it. Dealers won't be able to help because this not a standard thing to do. -
2011-2014 models are completely different from 2015-2020. I'd stay away from that site if they don't know the difference. Also, as @enigma-2 stated above, they are not bulbs. You cannot replace them. You'll have to change the whole light assembly to one that has the color you want dissemble them and solder new LEDs on the circuit boards. Not a simple DIY. -
Tail light Condensation
omar302 replied to d0minicano's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
If you bought them new, check with the seller for the warranty terms. -
From the attached Super Duty quick guide, the Towing DTE uses the average mileage from the last 60 miles, while the normal mode uses the average mileage from a longer distance. Just as @Haz stated above. 2017-Super_Duty-QRG-Version-2_QG_EN-US_08_2016.pdf
Rearview mirror always dark
omar302 replied to BarryK3's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The auto dim mirror has 2 light sensors, one at the back that measures ambient light level and one in the front (behind the mirror glass I think) to measure the intensity of light that might cause glare. If the back sensor is blocked it will make it think it is night time and cause the diming function to come on whenever there is light inside the vehicle, even if it regular sunlight coming in from the side windows or if the dome light or map light is on. -
Might want to share your current vehicle details. Model/year/trim and wheel/tire sizes. Sport models and bigger wheels have stiffer rides.
I think it is a matter of different principles. In Europe, generally, they get more Fog and drive faster, hence the rear fog requirement & expectation that all other vehicles on the same highway also have their rear fogs on. Having one vehicle without the rear fogs on is a recipe for disaster. In the US, having no requirement of rear fog lights means people should drive at lower speeds considering they rely on regular taillights (less bright). The probability of encountering a vehicle with less bright lights is much lower. Then again, if fogs were mandated by law, people would have been more aware. But, living in a country where you have both types of vehicles (with and without rear fogs) is even worse! Especially when people drive 60+ mph in heavy fog and then use front and rear fog light on clear nights.
Does do the cycle on every startup or only the 1st after re-connecting the wiper blade? Compare the connectors from the arm's side, maybe the passenger side's is also damaged. What I had meant was regarding the wiper blades themselves. The OEMs are different, right & left, and the connectors should be slightly different to avoid installing them incorrectly. If you are still facing the issue, maybe post a few photos of how they are installed, someone might have other suggestions.
Might want to consider using K&N washable Cabin Air Filters, they will save you a lot if you replace the filters twice a year. As for the screws, the 2015-2019 Edge was the first I've seen with them, it felt strange for me especially as the plastic door closes securely without. Actually considered not re-installing them to avoid dropping them when cleaning the filter, but decided to keep them as they must serve a purpose. For the weather stripping, there are also upgraded versions for the ones at the back of the rear door openings. But a bit more expensive, ~$60 each if i remember correctly. Driver side: FT4Z-5828125-C Passenger side: FT4Z-5828124-D They were part of TSB 18-2339 (link) -
For the connector thing, I am not sure which connector you mean, but as for the wipers coming on for one cycle, I am guessing that when you are re-installing the passenger side you are positioning it above the driver side wiper, in this case, the wiper will do a single wipe to correct the positioning. The passenger side wiper should be at the bottom & the driver side on top. That is normal. For the connector, if you mean where the wiper blade connects to the wiper arm, with OEM wiper arms, the left & right sides are not interchangeable, they have slightly different connectors & aero spoilers since they are installed on opposite sides. Maybe they were mixed.
Cargo lid max opening height
omar302 replied to Edgingage's topic in Cargo, Hauling, Roof Racks & Towing
I can't really help. Maybe test it by helping the liftgate up a little by hand and as if the struts were stronger, see if it would still stop early or continue. -
This is only a guess, the current gear indicator on the dash simply displays information it receives. So when the transmission is in manual shift mode the PCM sends the current gear info to the cluster. The Tuner would program the PCM so it sends this info all the time, not only during manual mode.
