If you have serious concerns, why not running it through a local (good) mechanic for a road worthy inspection. The look of the car reveals nothing as to what condition the mechanical aspects are really in. A simple failed part can cause a multitude of problems when you least expect it. Tell the service rep that you are planning a long trip and want to be certain that its in good condition. (Ford dealers offer a multipoint inspection with their oil change and tire rotation. Ask for The Works. $40.)
Replacement Options for 21" Pirelli P-Zero Performance Tires
enigma-2 replied to roots57's topic in Wheels & Tires
TireRack reviews. (Remember they are reporting with only a couple thousand miles on them). https://www.tirerack.com/survey/SurveyComments.jsp?reload=true&tireMake=Bridgestone&tireModel=Alenza+AS+Ultra&category=tire&sortBy=1&wantsDescending=true -
If your husband replaced the fan assembly with an aftermarket unit, it's been found that they are often wired wrong. (Rewiring has been discussed in the forum in the past).
I occasionally flip on the windshield defroster as it not only directs airflow onto the glass, it also runs the a/c. The refrigerant flow relubricants the seals. Most common place that leaks are the Schrader Valves (where the high and low hoses connect). One way to possibly tell is to remove the dust caps and see if you can see the residue of leaking refrigerant and oil. Valves are cheap and should be changed whenever the system needs service.
Need Help!!! - 2010 & 2011 no start just 5 long beeps
enigma-2 replied to Tony Higgins's topic in Lounge
In the F150, if the air bag warning light malfunctions, it will beep 5 times. (Without a warning lamp, there's no way the system can inform you of a malfunction with the restraint system). A simple way to verify this is to turn the ignition ON and check the cluster. The airbag lamp should illuminate. If it doesn’t, you will receive an alarm of 5 beeps. (Believe it's 5 long beeps for 5x.). Another reason you could get 5 beeps is a fault in the TPMS lamp. Again look at the cluster and see if the warning lamp comes on. If "yes" its not the problem. If "no" lamp, check tire pressure are adjust on all 4 tires. Then get TP.S circuit repaired. (Believe its 5 long beeps over 3x). Neither of these should prevent starting. If it happens again, try leaving the car in ON position, open drivers door and remove key. Then close door and try restart. Or wait until the beeping stops are try again. May be a change if Ford warning to get your attention and not just ignore. (With cluster warning lamps out, there's no way the car can get your attention that there is a problem). -
Now, that's interesting. Didn't know there was a 15.5" screen.
Problem with Edge AWD - vibration when turning the wheel
enigma-2 replied to lesnal's topic in All Wheel Drive (AWD)
Bent rim? Usually shows up at higher speeds. As the vibration isn't in the steering wheel, its probably coming from the rear. -
Paint coming off wheels. Modified or lousy stock paint?
enigma-2 replied to OahuEdge's topic in Wheels & Tires
Is that the Ford Sparkle Silver WP-20-00-61 color? -
New airbag recall, 2009 Lincoln MKX
enigma-2 replied to enigma-2's topic in Recalls, TSBs & Warranty
They sent me a letter stating that replacments were in stock. Called dealer and he scheduled 6 weeks out. Asked why, and he said they only have one technician who's certified on air bags and they had to order stock. (Lincoln thinks dealers keep these in stock). (I sort of wonder if this particular technician moves between local dealers, and is only in once a week or so). -
2011 Gearshift selector lights
enigma-2 replied to jcouture812's topic in Interior, A.C., Heat, Interior Trim
With the information Haz supplied, you can pull the LED and see if something like this will work. (Clear of course, not amber, but you get the idea). Read the information in the description. All comes down to the specific base for the LED. https://www.ebay.com/itm/174261350606?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=TzqfdFWNTBi&sssrc=2349624&ssuid=Snv36mbbRk2&var=&widget_ver=artemis&media=COPY -
Air conditioner question
enigma-2 replied to mrmikesdeuce's topic in Interior, A.C., Heat, Interior Trim
Did you check the fuses? Try checking fuse #22 (10a) in the engine fuse box. It controls the compressor clutch. No clutch engagement, no cooling. Its been so hot lately, the car's a/c may have over pressured when you started and blew the fuse. (Just thinking outloud). -
This may or may not be useful, but would an universal assembly work? It's cheap enough ($17.99 USD) and as it ships from China, should also ship to Brazil. https://www.ebay.com/itm/384633138493?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=m_gmg0f6sps&sssrc=2349624&ssuid=Snv36mbbRk2&var=&widget_ver=artemis&media=COPY
Threads are corroded. Try spraying some penetrating oil (I like PB Blaster) on the threads and allow time for it to soak in. Tapping sometime helps. https://a.co/d/i14TYX7
How to do a "speaker walk test"
enigma-2 replied to Davidoo's topic in Audio, Backup, Navigation & SYNC
Try this. Put the car in accessories mode. Using the information Haz provided (mainly the corrected image), press AND HOLD the on/off switch. While holding it, press the seek down button. HOLD until the system goes into diagnosis mode and the speaker test starts. About 5-10 seconds. -
Ford states that the fix costs a little over $1,000. (Replace the entire shifter mechanism). Don't see a LED replacement detail, but worth a try. See attached to remove shifter. https://www.justanswer.com/ford/33558-replace-lamp-gear-shifter-ford-edge.html?r=impact|27795|Online Tracking Link|&clickid=yqi3f5Xq%3AxyIT-2Wt41wdxdNUkD2NpU%3APVzIVE0&aff_sub_id=&aff_sub_id2=l4aplytk0z00b4bt0mj0u&aff_sub_id3=&aff_sub_id4=&chat_text=&irgwc=1 -
Had the airbag changed out yesterday (06/10/2010). Showed up at 7:45 & was out by 8:15. -
What a great idea. Knowing Ford, what could possibly go wrong? Like press the button and your check engine light comes on, "engine not available" pops up in the information panel, you coast to a stop on the 5 freeway, in afternoon traffic and your car dials the Count Clara's Castle of Conspicuous Courtesans. With your wife sitting in the passenger seat. You know, with "that" look. Kind of reminds me of Ford's Vehicle health report where it sent a complete report of your car to the Ford (Lincoln) website, and when you looked it up it said "nothing to see here, keep moving". Cue the replies ....
blindspot system fault/cross traffic fault
enigma-2 replied to jasoneg's topic in Audio, Backup, Navigation & SYNC
See if this helps (simular problem) -
The stated purpose is to "protect the bottom part of the car, especially the engine, from water, mud, rocks, and road debris always and from all angles. It also ensures that noise coming from the roadside does not penetrate the interior of the vehicle." About the only thing I can think of is that it may affect the active noise cancelation. Part of it is tuned to cancel road rumble which may get louder without the panels. #mrmikesdeuce we have selected you as our guinny pig. Report back in two weeks as to any negative side effects. lol -
Backup camera says "full view not available" ?
enigma-2 replied to Razrburn's topic in Owner Impressions
The recall for the 2021-2022 Ford Edge is for a blurred image, no image, or a “camera not available” error message. -
AC blower fan odd humming noise
enigma-2 replied to Gustafa's topic in Interior, A.C., Heat, Interior Trim
Shouldn't be a big deal to pull the blower out and check inside the housing for some foreign material. Something got into the duct, probably through the dash vent. -
I ?think? the light is triggered when the reservoir gets low on fluid. Peddle going to floor is usually a leaking master cylinder.
Need to pull the codes to figure out where the fault lies. Continuous codes indicate either a shorted or blockage of one of the sensors.
