omar302
    197
Everything posted by omar302
  1. Few questions: How was the install? Can you post the link to the eBay listing? For the turn Signals, can't you just use the wiring for the stock turn signals? They are immediately above those lights at the bottom of the headlights. Might want to disable the stock front parking lights first as they operate on a dual voltage setup (link to how I did it). Couldn't you have used the stock signature lighting's wires for input for the DRLs?
  2. What surprised more is that on my 2016 Sport, the 1-2-3 shift happens just below 60 mph, the ST has a shorter final drive, so the 1-2-3-4 sooner than the Sport's 1-2-3, hence no wonder it has a slow 0-60 time with all those shifts.
  3. The Edge's door will not unlock unless you put you hand inside the door handle opening (while the fob is close). If it is still unlocking, it might be that the fobs buttons are being pressed accidentally, or there is an issue with the Edge's locks. Edit: A feature worth looking into is the Auto Relock, but it does not come by default. You'll need to enable it with ForScan. What it will do is auto re-lock the doors if they were unlocked with a fob but a door was not opened within 45 seconds.
  4. PCM is the "Powertrain Control Module", basically the computer controlling the Engine & Transmission which has a software, this software is what is updated (and tuned in aftermarket tuners) just like how phones' software is updated. Reading all these issues with the ST's 8-speed, it seems the concern is with the 2-3 shift, also noteworthy is that the 2nd gear is one of the two added gears compared to the previous transmission in the Sport. The second added gear is the 8th, a 2nd overdrive ratio. So the issue could be as simple as software related for how it deals with the extra ratios (compared to the old 6-speed unit) or hardware with the new components they added to convert the 6-speed to a 8-speed.
  5. Try to disconnect the Edge's battery for 10 minuted to force a reset of all electronics. Or only a master reset in the settings menu of the main display.
  6. omar302
    Edge ST MPG
    @jamie1073 Did you also manually calculate it or is it only based on the trip computer?
  7. Horns usually are made up of two pieces, low & hight tone. Ford stated skipping on one of two in recent models. If it bothers you can add the other one.
  8. There is a Ford procedure for draining & refilling the PTU foe Gen 2. Install the PTU drain plug. Torque: 33 lb.ft (45 Nm) Transfer Case Draining and Filling.pdf Sorry, @WWWPerfA_ZN0W, didn't see your post with the torque specs. By the way, our Dealer here is aware & they spec the drain/refill every 32k km. But it is probably because our region had higher failure rates that prompted the drain plug to be factory equipped from 2013 Edge models and also the extended 1 time replacement warranty for previous years with a drain plug equipped PTU.
  9. The battery terminals are available separately. P/N foe the positive is BT4Z-14450-AA and costs ~$13
  10. This feature was added in later builds of 2013 models. Not sure if it can be added or not.
  11. omar302
    Edge ST MPG
    Can you show a picture of this view? I don't believe this would be for 2019.
  12. Congratulations. The Nautilus is a nice vehicle. Hope you enjoy it to the fullest.
  13. OEM replacement fan? There have a lot issues with people when using aftermarket fans on the Edge.
  14. Center (hub) bore diameter is different. I think 2007-2010 are 70.6mm while 2011-2014 are 634mm. So it is not a direct swap.
  15. That means the noise is from the back seat. Check if the seat cushion and back are loose. Try reclining the back seat to see if it affects the rattling.
  16. Fords warranty would not cover it, this is whats stated in the warranty booklet: But you can check the tire manufacturer's warranty if they have something, I know at least Vredestein does include the a Road Hazard Replacement Program during the first year.
  17. Just found there is a SSM for 2015-2016 the Edge Cooled Seats:
  18. Here is the procedure for a 2015, the 2019 will probably be the same. Front Door Upper Moulding.pdf
  19. Hi Jason, Any details on the reasons for this recall? What are the symptoms or safety concern? Also the remedy is only changing the steering?
  20. Check this post/topic, there is a TSB to fix (or try to, don't think anyone reported post fix), note that the fix is applicable for front & rear doors:
  21. Next time try to forces reset (restart) of Sync, no need to turn off the engine or wait longer. From the owners manual : SYNC System Reset The SYNC system in your vehicle has System Reset feature that can be performed if the function of a SYNC feature is lost. This reset is intended to restore functionality and will not erase any information previously stored in the system (Such as paired devices, phonebook, call history, text messages, or user settings). To perform a System Reset, press and hold the Seek Up (>>) button while pressing and holding the Radio Power button. Release both buttons after 2-3 seconds. Please allow a few minutes for the reset to complete. After a few minutes has passed you can resume using the SYNC system.
  22. The Explorer being developed with Police duty in mind and much higher sales actually has Ford's attention. The Police Utility version outperformed the police Charger V8s (AWD & RWD) in all performance tests of the Michigan State Police (0-60, Top Speed & Lap times).
  23. I don't think that would be the case here because as per OP even the intelligent access did not work (unlocking the door when the fob is close and pulling the door handle). You can find blank keys online, like eBay (link) or Amazon (link), and then have any locksmith cut it using the other key.
  24. I'll add 1 more point to @onyxbfly, how are you with buyer's remorse? I know for me I will regret not getting the newer model because of all the new features, new chassis & engine.
